RB20 speculation
LM10
LM10
127
Re: RB20 speculation
chrisc90 wrote:
14 Feb 2024, 00:54
I’ve faith in Newey and the team.
I will literally roll on the floor laughing if this turns out to be a zeropod design
Ever since the the bargeboards got banned the sidepods became a critical part for outwash. Mercedes only managed to implement zeropods because of their SIP wing trick (at least in theory).
A zeropod design for RedBull would mean a major chassis overhaul. Too much of a risk and simply unnecessary when having an already perfectly functioning and fast car.
Sempre Forza Ferrari
K1Plus
K1Plus
LM10 wrote:
14 Feb 2024, 01:26
chrisc90 wrote:
14 Feb 2024, 00:54
Evet since the the bargeboards got banned the sidepods became a critical part for outwash. Mercedes only managed to implement zeropods because of their SIP wing trick (at least in theory).
This looks like they took the best of W14 and applied it to their already good chassis and internals packaging.
madsonit
madsonit
W14 style.
But W14A or W14B. Different angles suggest different inlets.
Chuckjr
13 Feb 2024, 23:57
BlueCheetah66 wrote:
13 Feb 2024, 23:56
13 Feb 2024, 23:51
I don't understand what Scarbs thinks is negative about the design (other than negative connotations because of a differenct car)
I guess the whole development path with the downwashing sidepods has been in maximising the undercut and flow into that region. An 'overbite' inlet would seemingly backpedal on that development, and I would be surprised if that is what the design actually is. It seems that people have just seen Dr Obbs theorize that its this design and people have just accepted it
I personally drew my own conclusion that it was overbite based on the photos.
This is very convincing:
https://i.postimg.cc/k4gN7ps2/image.png
I'm also confused by why you think the overbite does not support downwash.
Look at the O in the word Oracle.
Just above and to the left of the O, I’m assuming is a square mirror.
From the bottom of that square mirror there is a slightly bent horizontal dark line that runs to what would be the inside shoulder of the side pod.
Is that a shadow or an inlet edge beginning for an underbite?
Watching F1 since 1986.
Chuckjr
And here again. Just above and to the left of the O in Oracle. What is that dark — what looks to be— an opening? Maybe I’m just seeing shadows. 🤷‍♂️
Kalsi
Kalsi
31
Best shot i could take out of videos... Engine cover more similar to sf24 than last year mercedes.
Sidepod inlet are defenitely upside down, the cut under the mirrors is huge..... Skinnier airbox too?
Chuckjr
Kalsi wrote:
14 Feb 2024, 02:05
https://i.ibb.co/dk6NNLN/rb20.png
The two tubes that run alongside the centerline of the top of the car seem to form a small, high, Ferrari bathtub idea? To me, it looks like the centerline of the top of the car sinks down into a belly or v shaped gully. Don’t know what to call it. 🤷‍♂️
ing.
69
Kalsi wrote:
14 Feb 2024, 02:05
I’m seeing a Alpine-like P-opening: combination vertical slot—dare we say ‘22 Merc-style, or enlarged Ferrari S-duct opening—with a small horizontal opening at the top.
Kalsi wrote:
14 Feb 2024, 02:05
The way I see it, the SF24 has an RB18/19 engine cover and the RB20 has a W14 engine cover.
#ReleasetheADUO
bigpat
bigpat
From the pic, I can say there is definitely refinement, over evolution, a Newey trait.
The undercut area is very large in volume, the radiator inlet increasing in height over last year. This would allow the front corner of the floor to be worked a lot harder to produce load.
The intergration of the halo to the engine cover looks sleeker, and the pronounced bulges of the engine cover seemingly increases area for the 'waterslides' of the sidepods.
Perhaps the biggest change i see is the tip of the nose cone being raised significantly to where it finishes in line with the 3rd wing plane, with the 2 lower planes slung beneath, perhaps the 2nd on pylons, presumably to allow more air volume to flow freely under the chassis to feed the tunnels ( much like the previous generation of cars). This is much higher than others launched so far, and would be an expensive change for other teams to implement, as the nose cone/wing needs to be re engineered to re pass the frontal crash test, so this advantage may be fixed for the season.
Cant wait to see the launch images...
Is it possible that the new rear flap on the med-df wing provides an even larger drag reduction effect?
#ReleasetheADUO
Stu
Venturiation wrote:
13 Feb 2024, 23:14
13 Feb 2024, 23:11
Emag wrote:
13 Feb 2024, 22:57
This is what seems to be the more likely configuration based on the pictures we have. But how small exactly could the thing be? With the letter-box design, it was scooping some air from the top as well (SF70H style), so although from the frontal view, the slit was tiny, in terms of volume when you include the top as well it was more or less the same.
But by "inverting" the letterbox design and going more the W14 route, surely they wouldn't be able to keep the same inlet size. I guess a combination of A and B is possible too, giving more of an " ¬ " shape.
Edit:
On second thought, it could just be the angle combined with very low quality playing tricks on us. Looking at the W14 from a similar angle you can't really see an inlet:
https://i.ibb.co/3z5Qmrx/Screenshot-202 ... 220108.png
this image isn't as bad:
There is an inlet, and it's underneath the lip. It will be difficult to "see" without using your imagination at this point.
https://live.staticflickr.com/65535/535 ... 5e75_c.jpg
here it's easier to spot
https://pbs.twimg.com/media/GGPNy-7X0AA ... =4096x4096
I’m seeing a huge underbite, with the rear edge of the inlet maxing out the legality box rearward (front edge of the side-pod legality area forming the front edge).
Now, have they moved the SIS forward to fit inside the underbite (it is quite thick).
I’m looking forward to seeing decent pictures later, but as pointed out by others, RB did launch a ‘soft’ version of the RB19…
Feel like overbite inlet is visible in this sideview. It's definitely not an underbite - beyond photos we are sure of it
Markup by Rosario Giuliana
Uncrop
Alpine A522 did have a hint of overbite, but this solution seems like it was indeed inspired by W14's unfortunate and compromised B-spec sidepods. Bigger airbox could have lead to smaller side inlets, which would provide almost the same amount of space under the inlet itself as final RB19 spec.
I'd have to say RB would definitely want to open up a new development path, even if the first iteration is a compromise in one specific area. With a top side inlet already up there and high as possible, you can't improve that area further.
The one thing that surprises me is seemingly bigger width of the sides in the undercut region, so called g-line (the joint between floor and sidepod). I'd attribute that to being the compromised solution that resulted from switching to overbite inlet.
astracrazy
astracrazy
31
madsonit wrote:
14 Feb 2024, 01:38
W14 style.
https://i.imgur.com/ptInBZb.jpeg
https://i.imgur.com/4u8TFgP.jpeg
No, it's not zero pod
