Red Bull RB20
Mattchu
65
Re: Red Bull RB20
BorisTheBlade wrote:
15 Feb 2024, 22:04
I actually thought the little tag said "Remove before fun" :)
Even if this the real (which I doubt) layout of the intakes it`s far away from what Merc brought. The car still has wide sidepods with an undercut, water slide. I just don`t see how the airflow would get to the rads efficiantly!
Venturiation
Venturiation
103
Re: Red Bull RB20
Luscion wrote:
15 Feb 2024, 22:10
KimiRai wrote:
15 Feb 2024, 22:06
https://i.imgur.com/6Y5V2r3.jpeg
Seems like they are indeed vertical inlets, Tobi Gruner has a pic showing them as well
Yes this is it
SICK AL SPEEDSHOP
Re: Red Bull RB20
here it looks a bit like on the W15 imo, just flip the lips..
Re: Red Bull RB20
chrstphrln wrote:
15 Feb 2024, 22:18
SICK AL SPEEDSHOP wrote:
15 Feb 2024, 22:07
if you scroll down you can see an animation without intakes like on the pictures here and if you scroll down a bit more you can see W15 style intakes on the sidepods
https://www.redbullracing.com/int-en/
If you play with the 360 ​​degree view, you can see that there is no vertical inlet, just a small step and structural change in the monocoque.
And you can see the air inlets exactly where they make sense: on the front of the side pods, narrow and high up.
So, no W15 style visible.
You can see it nicely in the AR mode for what it's worth
Apexseal157
Re: Red Bull RB20
Venturiation wrote:
15 Feb 2024, 22:20
Luscion wrote:
15 Feb 2024, 22:10
KimiRai wrote:
15 Feb 2024, 22:06
Yes this is it
i think it's an s-duct not the main cooling inlet
Venturiation
Venturiation
103
Re: Red Bull RB20
Luscion wrote:
15 Feb 2024, 22:10
KimiRai wrote:
15 Feb 2024, 22:06
It looks real because we can see the bolts
levidrugi
levidrugi
Re: Red Bull RB20
kfrantzios wrote:
15 Feb 2024, 22:16
https://i.postimg.cc/9QHKCJhk/rb20inlets.png
There they are... if the model is correct...
Actually you can modify the renderer.
1. visit the page: https://www.redbullracing.com/int-en/cars/rb20/
2. hit F12
3. find the <model-viewer html element (or search for min-camera-orbit=)
4. change its value to min-camera-orbit="auto 124deg 28deg"
5. you can now see under the car
Re: Red Bull RB20
The problem is there are two different inlet styles showing. We are none the wiser.
The floor is completely fake on the render. Why believe anything?
#ReleasetheADUO
Venturiation
Venturiation
103
Re: Red Bull RB20
Apexseal157
Re: Red Bull RB20
levidrugi wrote:
15 Feb 2024, 22:23
kfrantzios wrote:
15 Feb 2024, 22:16
2. hit F12
https://ibb.co/x5hbycg
https://ibb.co/0XKtNPM
an there you are thats the inlet it just makes the most sense. that vertical slot could be an s-duct but i dont see how it would be big enough to provide suffecent cooling
Re: Red Bull RB20
It's much easier to "fake" a cgi model than the real deal
dialtone
dialtone
139
Re: Red Bull RB20
Apexseal157 wrote:
Venturiation wrote:
15 Feb 2024, 22:20
Luscion wrote:
15 Feb 2024, 22:10
Yes this is it
Where is the outlet of the s-duct?
vorticism
vorticism
449
Re: Red Bull RB20
If non-representative, it would not be the first time they do, essentially, a livery reveal--in '22 the reveal consisted something resembling a standard FIA '22 concept model with RB livery. This time around there is correlation to photographs so I wouldn't rule it out as at least partly authentic, which is pretty common across all teams pre-season.
In which case, they could have a faucet shaped inlet. See below.
Edit: looks like levidrugi beat me to the punch by a few minutes.
Emag
Emag
137
Re: Red Bull RB20
15 Feb 2024, 22:21
https://img.redbull.com/images/c_fill,w ... alityimage
The floor edge is creating the illusion of a lower lip from this angle. It is not like the W15
Developer of F1InsightsHub
Chmielinski
Chmielinski
Re: Red Bull RB20
MtthsMlw wrote:
15 Feb 2024, 22:25
I don't get why they'd put fake inlets on the 3D model if they could just pretend there's no inlets like on the launch renders.
