Mercedes W15
Goblin42
57
Re: Mercedes W15
Cooling vents on the W15 are kinda in the same place as the W14 , tho i'm curious would they make a WIDE engine cannon outlet for hot races like what they did last year
Re: Mercedes W15
Goblin42 wrote:
19 Feb 2024, 17:25
https://i.ibb.co/ysn3wRZ/image.png
I think the Bahrain test will have daytime running so I suspect we'll see a hot weather configuration as early as tomorrow's filming day. It won't be long now.
Luscion
Luscion
119
Re: Mercedes W15
Grosjean's opinions on the W15, specifically the front wing and sidepods
https://www.silverarrows.net/news/grosj ... -with-w15/
Stu
Re: Mercedes W15
j_ste wrote:
19 Feb 2024, 11:55
Sevach wrote:
19 Feb 2024, 11:50
They did what he asked.
That was the easy part...the rest, we'll see. Quite the difference though
Something like 5cm if those pics are from the same angle.
Re: Mercedes W15
I'm unsure if this is real:
Sieper
73
Re: Mercedes W15
Little marketing fun. Pretty sure these guys could thumb us an app while driving though.
mantikos
mantikos
35
Re: Mercedes W15
Stu wrote:
19 Feb 2024, 21:47
j_ste wrote:
19 Feb 2024, 11:55
Sevach wrote:
19 Feb 2024, 11:50
Didn't someone post it was 100mm previously based on more side-on 1:1 comparisons by a magazine?
Stu
Re: Mercedes W15
mantikos wrote:
20 Feb 2024, 03:27
Stu wrote:
19 Feb 2024, 21:47
j_ste wrote:
19 Feb 2024, 11:55
That is the big problem with trying scale from a photograph, it is a faulty method, but it gives an indication.
Venturiation
Venturiation
102
Re: Mercedes W15
Venturiation
Venturiation
102
Re: Mercedes W15
SiLo
139
Re: Mercedes W15
It really seems like they are running a lot more front wing than last year.
Felipe Baby!
r85
r85
Re: Mercedes W15
SiLo wrote:
20 Feb 2024, 13:28
Romain Grosjean said that Mercedes must be really confident in rear downforce if they're running more front wing. However it is common to see teams running high downforce setups during the shakedown and testing for initial data correlation.
Farnborough
Farnborough
125
Re: Mercedes W15
Looks far more resolved than the two immediate predecessor from them.
Whispers about getting rear suspension into their operating requirements, may take some effort and time to fully understand in running it for real.
You can see where the push rod enters the chassis, in comparison to last years pull rod...the two points effectively at opposite ends of the internal torsion bar spring inside the gearbox casing.
Looking from the side of the chassis it sits coming up from clutch area toward the top of the case reclined a little like the driver's spine in orientation.
There looks to be higher gearing on this iteration in respect of how "closed" the geometry and angles are from the components we can see. That would ordinarily shift the spring and damping medium used to "harder" rating as the wheel assembly has effectively more leverage over this control force. Quite a shift for them to firstly specify and then fully evaluate.
This chassis (after reality of "hacking" the old one about last year) just has an air of refined detail about it.
I dont feel it'll be a surprise if it performs well against competition, but may just take a while to really understand it across all of the support staff and driver's interpretation.
scuderiabrandon
111
Re: Mercedes W15
SiLo wrote:
20 Feb 2024, 13:28
They are missing half of it so...
Holm86
255
Re: Mercedes W15
Bahrain shake down
