Red Bull RB20
Re: Red Bull RB20
AMG.Tzan wrote:
21 Feb 2024, 09:51
There we go then!
Questions is, do both openings lead to the radiators or is the vertical one an S duct like Ferrari?
I think the vertical inlet is so narrow that it's almost certainly an s-duct type thing to trim off the boundary layer
Venturiation
Venturiation
103
Re: Red Bull RB20
CaribouBread
CaribouBread
101
Re: Red Bull RB20
Aston and RedBull have landed on very similar edge wing solutions for now :-k
Re: Red Bull RB20
I don't remember seeing that dip on the top surface in any launch photos.
#ReleasetheADUO
CaribouBread
CaribouBread
101
Re: Red Bull RB20
21 Feb 2024, 09:55
I don't remember seeing that dip on the top surface.
Look at the Venturation post right above you, the pod dips considerably and continues parallel, then dips again into a narrow gulley
F1NAC
173
Re: Red Bull RB20
Did they put inlets behind the drivers head? Where Merc style tube begins? Wtf
Re: Red Bull RB20
Louvres inside the gulley
Venturiation
Venturiation
103
Re: Red Bull RB20
Red Bull may start testing new parts in the coming hours. There are preparations at the back of the garage, some parts have arrived but I couldn't see exactly what came, if I get details I will share them.
Re: Red Bull RB20
The air behind the cockpit and around Halo is quite bad, it's almost as bad for radiator cooling as the front tyre wake. I don't think those openings above cockpit are used for radiator cooling, but rather for some internal flow conditioning, most likely complementary along with (internal?) S duct outlet. In theory, you can get away with smaller radiator inlets if you manage to increase the pressure difference between inlets and outlets and internal flow management is crucial for that. Introducing a bit more cool air also helps :mrgreen:
Re: Red Bull RB20
F1NAC wrote:
21 Feb 2024, 09:58
I see that as well. Clearly inlets behind the driver's head.
#ReleasetheADUO
kediown
58
Re: Red Bull RB20
Shakedown pic, the nose panel is different here but still suspicious
michl420
michl420
Re: Red Bull RB20
Generaly speaking they put as much cooling as possible in the centerline to reduce size/have sculpture option for the siepod.
Re: Red Bull RB20
#ReleasetheADUO
kediown
58
Re: Red Bull RB20
Nose cone still bending
Re: Red Bull RB20
21 Feb 2024, 09:24
High pressure in front of this inlet could help reduce cockpit losses?
https://pbs.twimg.com/media/GG1_FGdWIAA ... name=small
Are these cooling anything or are they just channeled inside the fat tunnels all the way to the rear?
Some cool ideas in this car, Red Bull didn't sit still.
