Red Bull RB20
Cs98
Cs98
Re: Red Bull RB20
AbulafiaF1 wrote:
21 Feb 2024, 13:29
21 Feb 2024, 13:18
What a shock zeropod won't come
I would argue the exact opposite. This picture confirms what many people in here are saying. i.e. that the radiators have been mounted vertically and high, and now occupy the two channels running either side of the engine cover, leaving the sidepods with, mainly, empty space. It's not hard to imaging the sidepods shrinking to take advantage this empty space, in cooler races.
Vertically? The radiator looks to be in a similar position to last season. Far more interesting would be a picture of the "shoulders".
stewie325
stewie325
Re: Red Bull RB20
AbulafiaF1 wrote:
21 Feb 2024, 13:29
21 Feb 2024, 13:18
Agree, there seems to be sufficient space for the undercut to be even larger in the middle of the sidepod area, where it's currently very bulbous.
Henk_v
Henk_v
88
Re: Red Bull RB20
I think the perspective is deceiving. Look how much the SIS protrudes beyond the radiators. These look quite tucked in.
As many pointed out the zeropod was also not a true zeropod but had substantial volume.
Holm86
250
Re: Red Bull RB20
AbulafiaF1 wrote:
21 Feb 2024, 13:29
21 Feb 2024, 13:18
I would argue the exact opposite. This picture confirms what many people in here are saying. i.e. that the radiators have been mounted vertically and high, and now occupy the two channels running either side of the engine cover , leaving the sidepods with, mainly, empty space. It's not hard to imaging the sidepods shrinking to take advantage this empty space, in cooler races.
They definitely don't occupy the channels along the engine cover
Cs98
Cs98
Re: Red Bull RB20
Henk_v wrote:
21 Feb 2024, 13:51
You mean like this?
west52keep64
51
Re: Red Bull RB20
TimW wrote:
20 Feb 2024, 19:42
Note that according to Mark Hughes the car tested in Silverstone and in the studio is exactly what Helmut Marko describes (also see his replies in the comment section):
https://www.motorsportmagazine.com/arti ... ame-again/
A slim vertical radiator inlet, sited low and hugging the chassis sides, exposed a simply enormous undercut for the front of the sidepod. That sidepod itself was way smaller than before and the whole rear bodywork of the car stopped very short, revealing lots of volume for the airflows to the rear wing and diffuser to exploit.
Hi Rick. Yes the computerised renders had a few fake details notably the radiator inlet. But the car at the launch - which I was stood about 2 metres from - was the car from Silverstone testing the previous day and was very much real. Albeit with a fake floor fitted which just had flat edges.
Mark Hughes must have forgotten his glasses, because what's on track is nothing like what he has described.
Henk_v
Henk_v
88
Re: Red Bull RB20
Yes, the RB19 radiators were wider than the sis and then widened a bit more.
The RB20 radiators are substantially narrower than the sis and then quickly get narrower.
.poz
.poz
51
Re: Red Bull RB20
stewie325 wrote:
21 Feb 2024, 13:47
But this bulbous area is needed to outwash the front tires wake
FNTC
FNTC
Re: Red Bull RB20
Potential for a huge undercut here, pretty much all the way back, making the whole sidepod a sort of wing.
Cs98
Cs98
Re: Red Bull RB20
Henk_v wrote:
21 Feb 2024, 13:55
That's not what the pictures show. The SIS is clearly wider than the radiator on both RB18 and 19.
There's no zeropod in there:
nmoleiro
nmoleiro
Re: Red Bull RB20
"There's no zeropod in there:"
There never was... the mercedes just had the volume of the sidepod down on the floor...
I guess we can also call the mercedes "zero-undercut", but thats not as flashy is it?
OT: Wheres does the vertical slot feeds to?
Mattchu
59
Re: Red Bull RB20
It also looks like the vertical sidepod entry is split into to 2 seperate airflows.
Apexseal157
Re: Red Bull RB20
AbulafiaF1 wrote:
21 Feb 2024, 13:29
21 Feb 2024, 13:18
God why would they go to a concept which is proven to be poor at managing wheel wake, logic would suggest that the added bulk in the pods is a wake management choice as opposed to a tuneable element for certain races. We all know now what the team's are trying to do with the flow in that area, mainly increasing high pressure above the floor entrance, producing enough outwash to keep wheel wake outboard and to provide strong clean flow to the rear of the car (though watersides or undercuts) a zeropod or skinny pod just isn't the ideal solution to these regs, with no bargeboard the pods have a crucial role in wake control and I don't see redbull ditching that.
Re: Red Bull RB20
Henk_v wrote:
21 Feb 2024, 13:51
Indeed, radiator looks significantly tucked in and there seems to be 50-100 mm of empty volume right now. It wouldn't be a surprise to see RB20 feature radically shrink-wrapped sides in Japan, not too dissimilar from W14B sides basically.
Venturiation
Venturiation
102
Re: Red Bull RB20
Apexseal157 wrote:
21 Feb 2024, 14:39
AbulafiaF1 wrote:
21 Feb 2024, 13:29
21 Feb 2024, 13:18
The concept is proven to be way faster in the windtunnel
Marko confirmed it and sky f1 is saying they are bringing it in Japan
