Red Bull RB20
Re: Red Bull RB20
chrstphrln wrote:
22 Feb 2024, 16:38
Apparently Newey was inspired by Ferrari.
I wouldn't read into that. The engine cover is clearly W14 inspired
chrstphrln
Re: Red Bull RB20
22 Feb 2024, 16:39
chrstphrln wrote:
22 Feb 2024, 16:38
Yes, of course. The shape of the HALO is very similar.
What I meant are the bathtubs with the outlets.
It's basically identical to what Ferrari had on the sidepods, just one floor higher.
But that’s not meant to be derogatory at all, quite the opposite!
It is something Newey has always excelled at.
Adapting good ideas and integrating them into his own unique concepts.
Re: Red Bull RB20
chrstphrln wrote:
22 Feb 2024, 16:45
22 Feb 2024, 16:39
chrstphrln wrote:
22 Feb 2024, 16:38
W14 has the high shoulders and also for the same aerodynamic purpose. Not to mention they ran louvres there as well like RB. Bathtub sidepods.. completely different form, purpose etc
tmoneyr007
tmoneyr007
Re: Red Bull RB20
I’m not marking/mocking this up but what IF.
You directed the vertical cooling ducts, halo, roll hoops into “one” big internal cooling/exhaust plenum and then had the S-Ducts trigger a mechanism to exhaust gases out the side (over side pods) or down the shark fin valley exists based on speed/yaw?
Cooling Exhaust (switch)?
Airflow over side pods to floor or out the back to interact with beam wing DRS?
Re: Red Bull RB20
tmoneyr007 wrote:
22 Feb 2024, 16:47
We can already see the entire ducting of the halo inlets
And it's very likely they're using the vertical inlets to cool electronics
chrstphrln
Re: Red Bull RB20
22 Feb 2024, 16:46
chrstphrln wrote:
22 Feb 2024, 16:45
22 Feb 2024, 16:39
https://cdn-7.motorsport.com/images/amp ... tail-1.jpg
You're right, I remembered the shape of the Mercedes incorrectly. My bad. :oops:
Re: Red Bull RB20
https://formu1a.uno/la-red-bull-rb20-e- ... ltra-cosa/
As understood by Formu1a.uno , we will never see a real zeropods concept on the RB20 , although in cooler races the bodywork could be even more aggressive.
venkyhere
venkyhere
22
Re: Red Bull RB20
I've lost track... just how many air inlets and outlets does the RB20 have ?
Air Inlets :
1. Roll-hoop middle
2. Roll-hoop sides x 2
3. Sidepod horizontal letterbox inlets x 2
4. vertical slits on the chassis side, under overbite 'eagle-beak' of sidepods x 2 (or x 4 ? )
5. engine cover elephant trunk x 2
6. Nose top driver cooling ducts x 2
Air Outlets :
1. Sidepod rear bottom outlet (blowing into coke bottle area) x 2
2. Engine cover sidefacing triple/quadruple louvres x 2
3. Engine cover skyfacing bathtub channel louvres x 2
4. Engine cover rear conventional big outlet
what else am I missing ?
kediown
58
Re: Red Bull RB20
Re: Red Bull RB20
It looks like perfectly attached flow.
BigBeansBoy
BigBeansBoy
Re: Red Bull RB20
It's super cool to see the effect the high pressure zone in front of the inlet has on the airflow coming off the front suspension
PhF1x
PhF1x
Re: Red Bull RB20
22 Feb 2024, 16:36
Seems the gullies have not only the louvres but a large outlet there as well. Markup not by me
Did the car run on track like this? :shock:
https://i.imgur.com/xtAtqSe.png
I was wondering if they could use the Ferrari bathtub solution there. They might have deemed it too complicated for the little if any benefit it provided.
Henk_v
Henk_v
87
Re: Red Bull RB20
There are several ways to get a car quick around a track and teams make different choices weighing straightline speed, downforce, tire usage etc.
It is reported that RB is focussing on low drag.
Might that be in preparation of the '26 ruleset? The rules are not to be changed significantly and low drag becomes paramount when they go 50% Electric. Might be a smart move!
Re: Red Bull RB20
More great reporting from Rosario & Formu1aUno
CHT
CHT
-6
Re: Red Bull RB20
venkyhere wrote:
22 Feb 2024, 17:14
Air Inlets :
1. Roll-hoop middle
Air Outlets :
if proven to be beneficial in performance, we could see more cars adopting.
Wonder how difficult it will be to teams to switch to multiple cooling duct system
