Red Bull RB20
Mmgnt
Mmgnt
Re: Red Bull RB20
Looking at this picture, the sideways 'S' appears to hug the inside of the cannon bodywork, which means it would block all airflow front of it.
So does this mean that this is a duct exit? Which entrance is it tied to? Apologies if this has been discussed already.
vorticism
vorticism
327
Re: Red Bull RB20
Owen.C93 wrote:
23 Feb 2024, 13:09
I wonder what they are cooling in this duct. I know they have silver tape which makes it look like a radiator, but I'm not sure it is. You can even see how they've added more tape on the 2nd day.
Is this more of an aero feature that has something small technically being cooled in the duct somewhere to meet the regs?
Was thinking the same when I cropped the image. We can't see any tube/hoses connecting to the area yet.
Mmgnt wrote:
23 Feb 2024, 16:35
There shouldn't be any airflow in front of it; that small volume is all behind the monocoque. The surface with the sine wave edge has the main sidepod radiator outflow behind it, which combines with the centerline radiator as shown in that photo.
kediown
58
Re: Red Bull RB20
Not sure if these are meaningful but maybe someone can spot something meaningful
vorticism
vorticism
327
Re: Red Bull RB20
Zak Mauger / motorsport.com
Autosport
Edit of Diego Meija photo. The separation of horizontal and vertical sidepod inlets is clearly visible. It might be they simply connect in the main inlet plenum feeding the HXs (one of the current speculation options). Considered as either a two-entry inlet, or maybe as an S-duct that empties into the main radiator inlet plenum.
kediown
58
Re: Red Bull RB20
We have a reveal!
vorticism
vorticism
327
Re: Red Bull RB20
kediown wrote:
23 Feb 2024, 17:28
https://cdn.discordapp.com/attachments/ ... 40060df19&
We have a reveal!
+1 Source? Other photos from the same run will reveal if they ran simultaneously with the two small upper nose inlets or not.
kediown
58
Re: Red Bull RB20
vorticism wrote:
23 Feb 2024, 17:35
kediown wrote:
23 Feb 2024, 17:28
We have a reveal!
F1TV live feed. The upper nose inlets are still open. Seems like they will change the panel if they think they don't need extra cooling for the driver but who knows. In shakedown pictures they also tried this
Sieper
73
Re: Red Bull RB20
There is also a tube running from the nose into the main tub. They just struggled to get the nose back on someone finetuning in fit is still needed.
stewie325
stewie325
Re: Red Bull RB20
kediown wrote:
23 Feb 2024, 17:28
We have a reveal!
Would be disappointing if they're just using that panel to add/remove the usual cooling inlet on the nose. While everyone was expecting a front wing innovation for the last two weeks. :cry:
vorticism
vorticism
327
Re: Red Bull RB20
stewie325 wrote:
23 Feb 2024, 17:38
kediown wrote:
23 Feb 2024, 17:28
We have a reveal!
On testing day one they had a thin flat panel that was bending as though to test minimum bodywork thickness for that part. Only one small driver cooling inlet is permitted on the nose and must be ahead of 50mm behind the front tip of the CS, but it is not mandatory. The two small inlets on the front suspension bellhousing cover appear to be in a free region. As such, either three driver cooling inlets or something else is going on.
Re: Red Bull RB20
Some kind of blanking is visible inside the shoulder ducts
101FlyingDutchman
101FlyingDutchman
Re: Red Bull RB20
23 Feb 2024, 18:31
https://i.postimg.cc/90Wn0S4M/image.png
Looks more like one of those “vanes” to initiate a swirl and re-energise the air in an orderly fashion
vorticism
vorticism
327
Re: Red Bull RB20
RB20 has a Merc-type pretzel roll hoop yet the installation of the radiator it feeds is different. The RB20 rad is higher up and farther forward, sitting atop the engine as compared to the Merc type installation which has the radiator aft of the engine and lower than the engine intake plenums.
W11 or 12 (similar to 13 & 14 installation)
Sieper
73
Re: Red Bull RB20
Yep, so the weight is higher up, but the space it occupies is much less. Plus, it might be nearer to the center of balance, offsetting at least a bit of that disadvantage.
Espresso
Espresso
Re: Red Bull RB20
Very stable/undisturbed and controlled airflow in driving conditions.
2nd photo (horizontal stripes) shows how the thick lip is gently shaping the airflow.
