Luscion
Luscion
136
mstar
mstar
I think its desperation adding higher DF. Not optimum as you need high speed on this track lets see.
maygun
maygun
Luscion wrote:
08 Mar 2024, 14:57
Interesting that last year George was the one generally with the higher df setting.
r85
r85
Bernie Collins said that Mercedes was splitting the downforce levels between the cars to find a balance between race pace and quali pace.
It would be a surprise if Lewis ends up going for more downforce because it's usually him who goes for a smaller wing (Spa '23, Canada '22...)
j_ste
j_ste
If you dont trust the rear on this track, you are screwed. Seems like last years issues, have carried through so far.
Luscion
Luscion
136
r85 wrote:
08 Mar 2024, 16:59
Toto said they're going through the data to see which setup is going to be the final one before quali. But seems like Lewis has been struggling all weekend even though he said he's happier with the car, he's a good bit off George again
Luscion
Luscion
136
Lewis back on the lower downforce wing
mkay
mkay
16
That makes sense. Higher downforce on this track carries a heavy penalty, particularly given lack of tyre wear and the amount of full throttle sections.
DGP123
DGP123
7th & 8th. Poor show. Not many positives to take from that one.
j_ste
j_ste
Not to worry. Toto said they have 4-5 tenths of race pace to come...
The first sector shows they still cant get downforce in this car
Hammerfist
Hammerfist
j_ste wrote:
08 Mar 2024, 20:08
Yup. That new floor is still garbage, just like last year. They still are dependent on wing level to stabilize the rear. Unbelievably no progress has been made in efficiency at all.
CouncilorIrissa
CouncilorIrissa
This raises questions whether firing Elliott was a good decision.
pantherxxx
pantherxxx
It wasn't a good decision to fire Elliott. Toto is a mediocre team principal, Brawn had more to do with the success of Mercedes.
Toto says to Sky Germany, when asked if it's true Max has a clause that allows him to leave RB if Marko does, that they don't have a "mascot" anymore and even though Marko doesn‘t have a red cap (referring to Niki), Marko can come to them.
So Toto is essentially opening the door to Marko if he leaves red bull which seems quite likely to be imminent
CouncilorIrissa
CouncilorIrissa
Like why'd you fire a good engineer? He may have made mistakes, sure, but Mercedes aren't exactly swimming in top tier personnel at the moment. This kind of performance shows that Merc's issues run much deeper than whatever mistakes he may or may not have done.
