Alpine A524
factory_p
22
Re: Alpine A524
I heard Alpine brought a lower downforce rear wing for FP3. Any images of that?
Marble
Marble
Re: Alpine A524
factory_p wrote:
09 Mar 2024, 13:56
Yes :
Ocon had the lower downforce for quali and Gasly higher DF
Re: Alpine A524
KimiRai
KimiRai
301
Re: Alpine A524
factory_p
22
Re: Alpine A524
Alpine is bringing a "new" (more like a track specific) rear wing this weekend.
Apparently an actual upgrade is planned too, centered around a new front wing (which also brings a welcome weight saving)
ANDY238
ANDY238
19
Re: Alpine A524
So far even with the same team
The shape of the front wing is different.
New front wing
JustAnEngineer
JustAnEngineer
Re: Alpine A524
ANDY238 wrote:
04 Apr 2024, 20:00
New front wing
Interesting. I wonder if mass savings have been realised by having a greater portion of the aerodynamic loading towards the FW-nose mounting points -> hence reduced moment to resist for same net aero load, allowing a less extensive structure to resist this moment (in turn lighter)... I'm sure the reasons for (and potential gains from) this wing are primarily aero though.
Re: Alpine A524
CaribouBread
CaribouBread
101
Re: Alpine A524
factory_p
22
Re: Alpine A524
So both front wing options available (might be due to a shortage of parts more than a setup choice at this point of the season) and a new floor for Ocon's car. Let's see what it brings to the party.
Ocon reached Q2 twice already, with 3 tenths better he could have started the race somewhere around P12 where you have a reasonable shot at points if something happens in the top 5 teams.
Luscion
Luscion
143
Re: Alpine A524
TeamKoolGreen
TeamKoolGreen
Re: Alpine A524
Ocon did ok with this new floor in FP1
yepp4
yepp4
Re: Alpine A524
TeamKoolGreen wrote:
19 Apr 2024, 07:23
According to french journalists from Canal+, the A524 is now under weight limit with latest evolutions. Let's see !
Edit: So they corrected in SQ1, they reduced by 3,6kg with the latest changes and are still 1kg above the limit, they will be under for Miami
Edit again : New floor needed a new chassis revision to be fitted on Ocon's car.
Re: Alpine A524
KimiRai
KimiRai
301
Re: Alpine A524
