2024 Chinese GP
Re: 2024 Chinese GP
Big Tea wrote:
19 Apr 2024, 19:08
CHT wrote:
19 Apr 2024, 15:54
all down to tires . teams gentle on tires were struggling
They are running ultra-high pressures here too
Why?
Beware of T-Rex
Big Tea
Re: 2024 Chinese GP
19 Apr 2024, 19:16
Big Tea wrote:
19 Apr 2024, 19:08
CHT wrote:
19 Apr 2024, 15:54
Why?
I dont know, it was mentioned on Sky. Probably due to the track sealant or roughness?
Edited later, its actually on the headline news page for this site ~Pirelli has mandated unusually high minimum tyre pressure, with the limits set at 26.0 psi for the fronts and 22.0 psi for the rears. Camber limits are -3.00 for the front and -1.75 for the rear tyres.
Spacepace
Spacepace
Re: 2024 Chinese GP
If this was an F1 video game that lap would have been deleted and the next one and the next one and...
Mchamilton
Mchamilton
Re: 2024 Chinese GP
LHamilton wrote:
19 Apr 2024, 14:51
Im OK with Norris time being reinstated. However, Id like to see 'track deletion'-rule implemented the same on every circuit. We had the track limit discussion of where you gain time and where you dont. And they ended up just doing the hard and fast rule of "when you are outside of the white line, you are off the circuit regardless of gain/lost time or what not". The same should be done to deletion of the next lap. If you go over the white line at the exit of the last corner, your next lap gets removed as well.
It's pretty logical to assume that a trip through the gravel even with 2 wheels equals an compromised exit, so theres no need for that rule in this instance. Would rather drivers get more chances to put a time on the board than have to circulate aimlessly again because of a mistake at the last turn that has compromised then anyway.
search
Re: 2024 Chinese GP
Mchamilton wrote:
19 Apr 2024, 21:49
yeah, I think so too. The "next lap deleted" rule makes sense when the track otherwise would allow drivers to gain an advantage by getting a better exit from their outlap. This is totally not the case in Shanghai, so there's no need for it.
But it's still something to look into, of course, as the lap should not have been deleted to begin with then. It only led to confusion, and can potentially also influence the result of others (if someone thinks that his lap is good enough, for example).
Re: 2024 Chinese GP
Imagine if they didn't have tire blankets for SQ3 yesterday.
Beware of T-Rex
Luscion
Luscion
143
Re: 2024 Chinese GP
Re: 2024 Chinese GP
Luscion wrote:
20 Apr 2024, 02:16
Convergence
Beware of T-Rex
langedweil
Re: 2024 Chinese GP
How do things look on the rain side ?
HuggaWugga !
dialtone
dialtone
139
Re: 2024 Chinese GP
How many laps before grass is on fire? Over/under 15 laps?
Is it on fire now?
Re: 2024 Chinese GP
langedweil wrote:
20 Apr 2024, 04:08
Looks cold, but no rain yet.
atanatizante
133
Re: 2024 Chinese GP
19 Apr 2024, 16:35
Cs98 wrote:
19 Apr 2024, 15:51
I think Lando is running slightly higher downforce. He was almost 10kph down on the back straight relative to the RB in SQ2, similar deficit to Ferrari. Probably helped him with the tyres in SQ3.
If that is the case, the first lap will be interesting.
According to Bono, interviewed by Nico Rosberg, here is more about font and rear tyres temperature balance and particular on the front left one. Norris was down on speed trap hence opted for a high downforce setup (probably expecting cooler/wet race) and did a push lap - slow lap qualy session as the majority of drivers. HAM changed the first sets of inters to a new one with higher pressure and did to warm up laps before the hot lap ...
Jesus
search
Re: 2024 Chinese GP
Norris, Hamilton, Sainz on new mediums, everyone else prioritising tomorrow. Russell on softs.
CaribouBread
CaribouBread
101
Re: 2024 Chinese GP
Looks like the tar paint coating is already wearing off on the racing line
langedweil
Re: 2024 Chinese GP
No one on Discord .. and here it seems quite as well.
Now the tires are coming into play ..
HuggaWugga !
