What does Testing have to do with the first Grand Prix race weekend of a season?
Projecting where you might be to what transpires is not exclusive to this team, never has been and never will be.
Ross Brawn is retired and at nearly 70 years of age probably doesn't want the crap that comes with being a TP. Why risk your legacy as one of the great TPs at his stage of life?jrdls wrote: ↑23 Apr 2024, 07:08I think that, should Mercedes look for another TP, they should bring Ross Brawn back. He has shown that he's a good TP, he grasps the technical aspects of formula 1, has a good eye for technical talent and, IMHO, is a charismatic leader. I believe he could have the same effect that Fred Vasseur is having at Ferrari.
The team has a programme of things they do during FR such as long runs and the like in order to check cooling, tyre use, etc.. And he does sometimes change the setup between FP sessions. The issue is that he doesn't seem to want to go back to something that worked if the experiments don't work out. Maybe they just leave it too late because of the team's programme taking up the majority of the time.
Russell defended the split of set-ups: "We have to go different ways to learn more about our car." This is also the view of some engineers. They insist that the W15 is a better car than the W14. "We have improved compared to last year. Unfortunately, our opponents have improved even more, so we are now worse in relation."
Just_a_fan wrote: ↑23 Apr 2024, 13:24The team has a programme of things they do during FR such as long runs and the like in order to check cooling, tyre use, etc.. And he does sometimes change the setup between FP sessions. The issue is that he doesn't seem to want to go back to something that worked if the experiments don't work out. Maybe they just leave it too late because of the team's programme taking up the majority of the time.
His changing the set up in China did seem to be a dumb thing to do and quite why his engineers didn't tell him to leave it alone is beyond me. Maybe they also think the car can be magically set up to overcome its obvious issues.
Wolff takes this glimmer of hope by the scruff of the neck: "Everything is so close behind Red Bull that small improvements make a big difference." An upgrade in Miami should now fix that. It was planned for Imola, but will be brought forward. Mercedes does not want to drive in no man's land any longer.
I do wonder if the car has just too narrow a set up window unlike previous Mercs where they could play around to try to get the perfect set up. Lewis is trying to get perfection and is losing "good enough" as a result.chrisc90 wrote: ↑23 Apr 2024, 13:35Just_a_fan wrote: ↑23 Apr 2024, 13:24The team has a programme of things they do during FR such as long runs and the like in order to check cooling, tyre use, etc.. And he does sometimes change the setup between FP sessions. The issue is that he doesn't seem to want to go back to something that worked if the experiments don't work out. Maybe they just leave it too late because of the team's programme taking up the majority of the time.
I understand the brake cooling, tyres etc, but I think, personally, going extremes with setup with no testing before qualifying and the race it puts a tonne of risk on the weekend’s important sessions.
At one point, you might aswell make setup changes through the race and have a extra 2.5hrs of testing time.
Yeah, that could be the case. I don’t think we have seen bad deg on the W15 so far from memory??, just a car that seems to have either a loose front or a twitchy rear end.Just_a_fan wrote: ↑23 Apr 2024, 13:41
I remember HP splitting into Consumer and Enterprise, maybe even Software? And i think HPE sponsors Mercs so whichever HP company sponsors Merc it should not be a conflict with Ferrari. Just a bit confusing.
Which teams were perfect at Bahrain apart from your favoured Red Bull?chrisc90 wrote: ↑23 Apr 2024, 13:28
The fact you have 27 hours before the race to find an optimal setup? If your making radical decisions before the first race of the season between FP3 and qualifying, you have had more than enough time to set the car up to be perfect for that race.
In a vacuum, 0.8” is within noise of conditions only, even within the same day. Need to compare to the whole field.maygun wrote: ↑22 Apr 2024, 19:21They fixed 'a lot', It is not like W14 was slower than W13, or W15 is slower than W14.Hoffman900 wrote: ↑22 Apr 2024, 18:38I’m always reminded that there is no guarantee of a fix either, because the issues that caused it to be wrong in the first place (something like correlation) aren’t a given to be fixed.
People don’t design things to be “wrong” from the get go and unless the tools and knowledge on the front end of the design is completely understood, you’ll never fully correct anything.
Three seasons in, and it’s clear Mercedes is having big issues with their modeling, correlation, and engineering prowess. How many times now have we heard that they “fixed it” over the last three seasons?
For instance, George's Jeddah quali laps from 2022 to 2024,
1:29.104 (pole:1:28.200),
1:28.857 (pole:1:28.265),
1:28.316 (pole:1:27.472).
My speculation is that every team has a similar gap between their tools and reality, but they put harder targets to hit during development, while Merc set their targets based on the scores from their tool and think they will be champion based on the data that they have.
AMuS also has Russell mentioning him and Lewis having two different setups and it being neccessaryVenturiation wrote: ↑23 Apr 2024, 20:43First he says the setups were the same now he says they are completely different clown behavior
Maybe when he mentioned "we" in relation to having similar setups the first time he was talking about his side of the garage? sometimes drivers say "we" when they just mean their side, Perez does it as well.Russell defended the split of set-ups: "We have to go different ways to learn more about our car." This is also the view of some engineers. They insist that the W15 is a better car than the W14. "We have improved compared to last year. Unfortunately, our opponents have improved even more, so we are now worse in relation."
