HP, TQ, RPMs
Re: HP, TQ, RPMs
POWER IS EVERYTHING
Torque is useless without Power to move it.
Torque is immaterial.. It can be multiplied and divided at he flick of a wrist.. (gearbox)
Power is Energy in motion and time.. Can not be created or destroyed.. You only use it while you have it..
POWER....
Is more important.
:mrgreen:
010010011010
Re: HP, TQ, RPMs
Power is more important
but MAX power isn't the most important (i you think that then you should go back to reading your tuning mag)
the power all the way through the rev range is
which has a lot to do with the torque of then engine
which means torque is important
which means were back to square one :)
ah no, power is more important :) power all the way through :)
Giblet
Giblet
Re: HP, TQ, RPMs
Error: Malformed binary. Your binary code is must be divisible by 8.
OMG who are you? :)
Before I do anything I ask myself β€œWould an idiot do that?” And if the answer is yes, I do not do that thing. - Dwight Schrute
ISLAMATRON
Re: HP, TQ, RPMs
I saw that same binary code in on of bender's dreams... I think I saw a 2 in there somewhere too :o :o :o :o :o
010010011010
010010011010
Re: HP, TQ, RPMs
ha ha ok bad code so
but to be honest its not meant to mean anything
its a rhythm, of 1s and 0s
speedsense
speedsense
Re: HP, TQ, RPMs
Recently witnessed something that was very eye opening. A car here in Calif. is a lower class that runs in ALMS series and the motor has been replaced by a fully electric motor. The car is faster than the gas motor it replaced.
We recently put this car on a chassis dyno, and unlike the gas motor, the torque was 100% from the instant it started to turn and continued that way through most of the rpm range.
As someone who is used to seeing numbers on HP and torque (on race engines), the first thought was something was wrong with the dyno. Threw another gas powered car on it, and no not the dyno. Pretty wild to see that.
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
Scotracer
Scotracer
Re: HP, TQ, RPMs
speedsense wrote:Recently witnessed something that was very eye opening. A car here in Calif. is a lower class that runs in ALMS series and the motor has been replaced by a fully electric motor. The car is faster than the gas motor it replaced.
Yet the mileage the car can travel is far shorter and the weight of the energy storage system can ruin the handling. But hey, let's ignore those annoying facts and look at the pretty peak Torque and Power figures ;)
Powertrain Cooling Engineer
010010011010
010010011010
Re: HP, TQ, RPMs
Yeah, electric motors pull at 100percent torque from the very start.
because the electric energy going through it is at full straight away and theres no valve timing or exhaust/intake tuning that needs to be running up to speed to work right.
but as Scotracer said, its the battery or fuel cell systems that need developing badly
Ciro PabΓ³n
106
Re: HP, TQ, RPMs
Giblet wrote:Error: Malformed binary. Your binary code is must be divisible by 8.
OMG who are you? :)
What do you mean by malformed? It's equal to 1178. Why should a binary number be divisible by 8? The joke escapes me. Damn, where is my sense of humour today? ;)
Ciro
Re: HP, TQ, RPMs
010010011010 wrote:Power is more important
POWER POWER POWER..MORE POWER EVERYWHERE!! low down, middle up high... more power! It's doesn't matter how you want to twist it.
