2024 Scuderia Ferrari F1 Team
sunny1304r
sunny1304r
falonso81 wrote:
09 May 2024, 15:52
So the updated car did not run today?
The updated car will run tomorrow.
yooogurt
40
According to formula uno
Ferrari will revise the floor in its entirety in relation to the internal drifts of the Venturi entrances
If everything goes to plan in Maranello, the step should be around 15 overall load-efficiency points, which would mean 3 tenths per lap, with an even more ambitious target in terms of race pace.
https://formu1a.uno/it/esclusiva-ferrar ... sf-24-2-0/
3 tenths only by floor sound very encouraging
FORZA FERRARI SEMPRE!
matteosc
matteosc
32
Re: Ferrari SF-24
Jakxy wrote:
09 May 2024, 11:39
Vanja #66 wrote:
09 May 2024, 11:18
Please let's not post old cars in latest car threads, thanks
today’s test with last year's car?
They tested both 2022 and current 2024 versions, but without the Imola update.
They will test the Imola update tomorrow.
F1NAC
173
yooogurt wrote:
09 May 2024, 16:48
It is a package as whole
yooogurt
40
F1NAC wrote:
09 May 2024, 17:24
I don't think so, 3 tenths was written specifically about the floor. If there was a total package, this information should have been in a separate paragraph.
"The body will be a consequent evolution, and the chutes above the bellies will also undergo a consequent revision. The interior relatively to the arrangement of the radiant masses will undergo no change in the placement of the heat exchangers. The bottom-which to call new is not an understatement-will carry much of the extra load.
The floor will be revised in its entirety, with some solutions that could be called "interesting" relative to the internal drifts of the venturi inlets. If all goes as well as they hope in Maranello, the step should be in the neighborhood of 15 points overall load-efficiency, would mean 3 tenths per lap, with an even more ambitious target in terms of race pace. The so-called "base" version of Cardile's car was created to offer a wider sleeve in development, and the one we will see at Imola will be a more pushed version of the concepts initially adopted on the SF-24."
dialtone
dialtone
139
yooogurt wrote:
F1NAC wrote:
09 May 2024, 17:24
The title of the section in the italian article is that both will amount to 0.3s but I’ll just wait and see it on track as the time gain is track dependent anyway.
yooogurt
40
dialtone wrote:
09 May 2024, 17:44
I think that not even the overall pace is important, but the aero efficiency to finally start to get the advantage of the 066/12 on the straights, and normal tire warm up, because even in hot Miami, there were heating problems at the beginning of the stints.
ps. and speed improvements in the slow cornes, of course.
The article is well put and comprehensive, but hopefully the hopium thins down. Vasseur was clear - there can't be big steps in car development any more. :) Red Bull are well in the lead and Imola will be more like Japan and China most likely, since they too will bring a set of updates
The interesting bit will be seeing what kind of change will they make on the rear wing :lol:
yooogurt
40
interesting analysis from Formula Data Analysis
AmateurDriver
AmateurDriver
-6
Vanja #66 wrote:
09 May 2024, 18:03
Very underwhelming indeed. Let's hope they'll end up second best in WCC (difficult). And let's acknowledge Vasseur's intellectual honesty nevertheless. He's not saying we're playing catch up, we're just one tenth behind, in the second half of the season blah blah... He's already saying "no way" even before traditional turning point of Barcelona.
yooogurt
40
Vanja #66 wrote:
09 May 2024, 18:03
I mean with -3 tenth pace and better aero efficiency and normal tire warm up, we could put some serious pressure on RB20 in Suzuka.
But yes, it remains to be seen what RB will bring to Imola, but i somehow doubt that they have managed to prepare the notional 2 tenths from Suzuka to Imola in such a short period of time. Realistically sounds one-tenth at most.
yooogurt wrote:
09 May 2024, 18:10
https://i.imgur.com/JIiyPZk.jpeg
Highly unlikely. The more reasonable explanation is Max going under the car's limit there to prevent tyre overheating, since it was very hot with no clouds and the day before saw McLarens get caught out by this. While Red Bull did not go over the Top Speed of Ferrari, they did accelerate and reach it quicker. Perez had 340kmh Top Speed and same 229kmh T5 minimum speed.
Vanja #66 wrote:
09 May 2024, 18:03
You said the same thing before Miami.
Beware of T-Rex
Vanja #66 wrote:
09 May 2024, 18:03
Mclaren.
Beware of T-Rex
LM10
LM10
127
AmateurDriver wrote:
09 May 2024, 18:23
Vanja #66 wrote:
09 May 2024, 18:03
Why on god’s earth is it difficult for Ferrari to end up second best in WCC?
Sempre Forza Ferrari
