Mercedes W15
Re: Mercedes W15
Hoffman900 wrote:
22 May 2024, 16:55
Luscion wrote:
22 May 2024, 14:53
Allison confirming Merc have upgrades in Monaco, "aero and others", bringing upgrades in Canada and again in the races to follow. Seems in line with what ted said James told him in imola of incremental upgrades and then a big one before summer break
Increment updates have always left me curious, because aerodynamics don’t occur in isolation. You change one part and you effect everything downstream of it.
Incremental updates more read to me like fixing things more so that an “upgrade”.
One could argue that the wind tunnel is an approximation of the full sized car, and in the wind tunnel they do test parts one by one at times, so it follows that brining incremental upgrades to the track is a more thorough way of testing a carefully selected group of parts as part of a big package, and feeding back data to the wind tunnel, so they can tune the whole package, and their tunnel in the most accurate way.
They parts they select first to bring to track might be the more "tweakable" parts or the ones that have easier adjustment in the tunnel, or the ones that have a stronger effect on downstream flow... Is what I'm gonna guess.
It's exaclty in-line with the "incremental" philosophy that they have commited to now.
maygun
maygun
Re: Mercedes W15
Matt2725 wrote:
23 May 2024, 09:57
maygun wrote:
22 May 2024, 19:11
clownfish wrote:
22 May 2024, 16:49
Courtesy of Adam Cooper:
https://adamcooperf1.com/2024/05/22/all ... r-footing/
Do we think there was a genuine improvement relative to Red Bull with the most recent update? I can't see it in my own notes (which are pretty mediocre, admittedly).
In Imola:
Lewis was +35s behind Ver, he made a mistake that cost him 5s, so it should be around 30s. Per lap difference 0.476.
In China George was +38s behind Ver, Per lap difference 0.679
Imola Pole/China Pole = 0.796
So normalized difference: 0.796 * 0.679 = 0.540
0.540 - 0.476 = 0.06, so congrats Merc for gaining half a tenth :D
I'll just assume you're making a simplistic comparison for fun rather than any serious discussion.
Yeah, it is a simplistic comparison, but probably close to accurate. No way without access to teams' internal data we can make a real comparison, similar to every comment in this forum, every comment is just a speculation.
Goblin42
57
Re: Mercedes W15
New High downforce rear wing on the W15
Luscion
Luscion
117
Re: Mercedes W15
Goblin42 wrote:
23 May 2024, 16:46
https://pbs.twimg.com/media/GORVFpmXoAA ... &name=orig
Lewis is saying they brought no upgrades this weekend, that rear wing also looks like the same one Lewis was running in pre season testing with some modifications to it
Re: Mercedes W15
Luscion wrote:
23 May 2024, 17:07
https://pbs.twimg.com/media/GG7HaB2XEAA ... =4096x4096
Completely new geometry all the way from the scoop to the endplate (and a completely different endplate and flap tip), this part is the main element and has to be constructed as integral carbon-fibre laminate. Everything points to an all-new wing
The new wing is definitely cutting a lot of inefficient drag in the area of endplate joint, the 2022 launch-spec wing was really unrefined there, very bulky and thick vertical transition
Cs98
Cs98
Re: Mercedes W15
Luscion wrote:
23 May 2024, 17:07
Goblin42 wrote:
23 May 2024, 16:46
Lewis may not consider circuit specific details to be proper "upgrades". But if you look at the corner of the wing, where the horizontal plane and vertical plane meet, you can clearly see this is a different wing entirely.
cplchanb
cplchanb
Re: Mercedes W15
Vanja #66 wrote:
23 May 2024, 17:29
Luscion wrote:
23 May 2024, 17:07
its shocking how long it took merc to thin the transition between endplate and mainplane. theyve always had this beefy thick construction since 2022. one would assume that would be one of the lowest hanging fruit to cut drag.
Goblin42
57
Re: Mercedes W15
Luscion wrote:
23 May 2024, 17:07
Goblin42 wrote:
23 May 2024, 16:46
The rear wing that they tested in day 3 of preseason test is the same double spoon rear wing from the W13
in Barharin preseason test
The new Rear wing looks like last year's aston martin RW
Goblin42
57
Re: Mercedes W15
Side note i'm curious would they use the lowered wishbone design for Monaco
Re: Mercedes W15
cplchanb wrote:
23 May 2024, 17:34
They've had quite a lot of bigger issues to sort out first. In any case, seeing a new high-load wing is a good sign foe the team, they are starting to pay attention to these details again
r85
r85
Re: Mercedes W15
Vanja #66 wrote:
23 May 2024, 17:29
Luscion wrote:
23 May 2024, 17:07
And it looks like they also got rid of that double scoop thing from the W13/W14 rear wing. Do you know what advantage it had and why they would remove it?
Luscion
Luscion
117
Re: Mercedes W15
Vanja #66 wrote:
23 May 2024, 17:29
Luscion wrote:
23 May 2024, 17:07
i stand corrected
Re: Mercedes W15
r85 wrote:
23 May 2024, 18:00
It wasn't really a double scoop (years ago there were actual M/W wings :mrgreen: ) but a geometrical shape that resulted from pronounced middle scoop at lower AoA turning to higher AoA mid-span, before going back to lower AoA around the endplate joint, to reduce the losses these wings are condemned to. You can see a similar, but less pronounced, feature on RB high-load wing too
The central scoop (lower AoA) is possibly there to either slightly improve efficiency (downforce/drag) or maybe there are some separation concerns for the flap (especially with swan neck pylon in front), so they reduce the AoA locally where this separation is most likely to occur.
Goblin42
57
Re: Mercedes W15
new High downforce rear wing rocking the same tip design as the medium DF RW that was introduced in imola last week, there's also some subtle modifications to the lower SIS cover
Re: Mercedes W15
Goblin42 wrote:
23 May 2024, 21:10
https://pbs.twimg.com/media/GOR85juXsAA ... &name=orig
https://i.ibb.co/rdf1ZqY/image.png
We can also see the more pronounced indent in the floor roof that was seen on Russell's car in Australia, right where the edge wing starts
