JordanMugen wrote: ↑Tue Jun 11, 2024 1:05 am
They were
nowhere near 1600hp at the 1987 and 1988 maximum boost levels!
It was only in earlier years that there was no boost limit. Weren't the the turbos around 650hp in 1988?
Tommy Cookers wrote: ↑Mon Jun 10, 2024 2:16 pm
1st or 2nd gear - (automatic and fault) flap positions A (highest Cdf:Cd ratio)
3rd or 4th gear - (automatic non-fault) flap positions B etc
5th or 6th gear - (automatic non-fault) flap positions C etc
7th or 8th gear - (automatic non-fault) flap positions D (lowest Cdf:Cd ratio)
flap positions (front & rear wings) would be car and venue-specific
what's not to like ?
You'd have "no" downforce in high speed corners?! :?:
Far from fixing Andrea Stella's concerns of the cars being too slow in corners and too fast on straights, won't your proposal make those characteristics even worse?!
not so IMO
eg the DF in eg 7th or 8th gear corners is due to whatever has been chosen as (front & rear wing flap positions) D
this scheme should make the car quicker everywhere (than it would be with fixed aero)
it could even give eg at slow speed more DF than Monaco and at high speed less DF than Monza ...
what it gives is due to whatever A B C & D positions were chosen by whatever team for whatever venue
its USP is that braking is longer in distance and duration (than if max Cdf was developed at start of braking)
ie the MGU-K spends much more time for max regen - so much more energy is harvested
the driver's braking task is no more difficult (than the present braking task)
re the turbo engines .....
yes 1986 was the last year without boost limits (or NA cars) ... but ...
for 1986 fuel was reduced to 195 litres (1985 fuel limit was 220 litres for turbo and for NA) ... but ....
the emergence of high-density fuels temporarily defeated the rulemakers (control of power by control of fuel volume)
(and early boost limit mandated hardware/rules were ineffective)
