2024 Mclaren Formula 1 Team
mwillems
45
Emag wrote:
29 Jun 2024, 17:35
LionsHeart wrote:
29 Jun 2024, 17:33
mwillems wrote:
29 Jun 2024, 17:23
Mclaren challenging the call. Oscar says he was on the line and not in the gravel.
Looks marginal, I hope they made that call with a top down view otherwise it's just guessing.
What's the point of enforcing track limits in a corner wheren you've gone to the trouble to lay gravel?
https://i.ibb.co/vXTzRMP/3-B14-A0-A4-CD ... F7-FDA.jpg
https://i.ibb.co/7WwG14Z/0894-FE96-2254 ... B89-A2.jpg
He is over the white line though, so not much to protest.
Like in football, the whole tyre/ball has to be over the line which we can't see from these angles.
I'm used to this debate on football where it looks clear and obvious the ball has gone out, but when looked from above it is easily in. The curvature and angles being deceptive.
It may well be out, but I'd like to think they had an overhead shot.
-Bandit
Emag
Emag
111
Not a good job by McLaren though. All top teams managed to find more time than them from yesterday.
Actually McLaren found nothing. That was just Lando hooking up a slightly better lap than yesterday.
Developer of F1InsightsHub
Tomsky
Tomsky
29
Emag wrote:
29 Jun 2024, 17:43
Maybe you have tuned in for less tire wear in the race.
FittingMechanics
FittingMechanics
16
Emag wrote:
29 Jun 2024, 17:43
I'm wondering if they maybe moved a bit toward race setup? You can overtake here, why not make car a little bit better in the race.
Or at least I hope that is the reason they couldn't follow Verstappen in pace.
Mcl_G10
Mcl_G10
Perhaps they sacrificed some 1 lap pace to play the longer game tomorrow with degradation.
CjC
CjC
I think everyone changed their car.
I believe the laser scanner was set up at McLaren pre-quali does that indicate quite a large change in set up of such a tool is required?
Just a fan's point of view
mwillems
45
I don't think we are set up for the race more than others. Amongst other changes that would include more downforce.
In this qualifying session Max has actually matched the Mclaren in the lower speeds and increased the gap at higher speeds. He's faster than us on every straight and corner apart from turn 4.
I am afraid that they are just have a much better car in this session.
-Bandit
LionsHeart
LionsHeart
Emag wrote:
29 Jun 2024, 17:43
And yesterday you told me that if Lando had driven his first sector faster... but the main loss occurs in the third, where Lando loses more than two tenths compared to Max. There is no talk of thousandths.
I hope there will be telemetry, or maybe it already exists. I need to search and compare fast laps.
Maybe McLaren decided to reduce the wear on the tyres, I have no idea why the car has such a speed deficit. But it feels like we have lost some top speed.
mwillems
45
LionsHeart wrote:
29 Jun 2024, 18:24
Emag wrote:
29 Jun 2024, 17:43
There is.
It's bad.
We're slow.
Comparatively 😂
-Bandit
Everyone else found 3-4 tenths. How come Mclaren didn't improve?
Emag
Emag
111
LionsHeart wrote:
29 Jun 2024, 18:24
Emag wrote:
29 Jun 2024, 17:43
I didn't tell you anything. I just speculated that if he were to get a sprint pole, he would have had to do it in the first sector. The only place he was slower than Oscar.
Completely unrelated with what happened today. As I said, McLaren found nothing over yesterday and Max is ahead by a landslide.
LionsHeart
LionsHeart
Emag wrote:
29 Jun 2024, 18:30
LionsHeart wrote:
29 Jun 2024, 18:24
Emag wrote:
29 Jun 2024, 17:43
There was nothing to assume. Red Bull is faster and it was already evident yesterday.
The big losses start in the second sector, but even more in the third. Lando was 0.17 seconds behind in the first two sectors, and 0.225 seconds in the third. Turns 9 and 10 are just awful.
29 Jun 2024, 18:29
Could be that they're limited more by the overheating tyres here. Or they went more towards race pace than others
I think Norris did a very good lap for sq3 whilst not optimal in quali which can make up for some of the delta
Merc and Ferrari said they were much slower than expected in quali, so I think they had a lot to gain with setup changes
Emag
Emag
111
LionsHeart wrote:
29 Jun 2024, 18:33
Emag wrote:
29 Jun 2024, 18:30
LionsHeart wrote:
29 Jun 2024, 18:24
The big losses start in the second sector, but even more in the third. Lando was 0.17 seconds behind in the first two sectors, and 0.25 seconds in the third. Turns 9 and 10 are just awful.
The gaps weren't that big yesterday. I didn't say he should have had pole, I said his only chance at it would have been with a godly S1.
I don't know why you're bringing it up for no reason.
mwillems
45
  • Red Bull massively faster at the start of the lap (WHITE)
  • Red Bull faster along the straights as well as having a higher peak speed (WHITE)
  • Max now at least equal to us or better in most corners (RED)
  • Absolutely smashing us in the high speed, nearly 10kph faster for a large period of time (BLUE)
-Bandit
