2024 Belgian Grand Prix - Spa-Francorchamps, July 26 - 28
Re: 2024 Belgian Grand Prix - Spa-Francorchamps, July 26 - 28
Big Tea wrote: ↑
31 Jul 2024, 12:02
PlatinumZealot wrote: ↑
31 Jul 2024, 05:32
You would not want your car to trap more water than other cars would you? πŸ˜‰ it would be a disadvantage. So it all falls back to square one.
As I said, when moving it would blow/suck off, but standing in the rain before weighing? I wipe my car over not to get the garage floor wet sometimes and get a inch of water in the bowl I wring out into looks not far short of 1ltr sometimes, and a F1 car is big.
Anyway, not really relevant as when Merc would have checked (if they had) it would be freshly wiped down.
I agree that scenario is possible. I am just saying that there is no need for a special way to make sure water drains from the car so that the car does not gain weight. Just put a few weep holes here and there ot leave small gaps. Not worth spending development money on making special body shapes to drain the car. It might be a problem solved decades ago.
Paa
TFSA wrote: ↑
31 Jul 2024, 08:42
AR3-GP wrote: ↑
31 Jul 2024, 02:01
The intermediate tires have a larger rolling diameter and are probably heavier than slicks. It's impossible to speculate since it would have depended on the tire strategy.
Cars aren't weighed with Inters or Wets. If they have those tires fitted, the Technical Delegate will have the tires replaced before weighing.
https://i.imgur.com/3vJKoXL.png
It would make even more sense to set a minimum weight without tyres and measure the cars without those at all times.
vanburin
Big Tea wrote: ↑
31 Jul 2024, 12:02
31 Jul 2024, 05:32
I'm more interested in what material your garage floor is made of, that makes it rainwater averse! :lol:
Big Tea
vanburin wrote: ↑
31 Jul 2024, 21:09
Big Tea wrote: ↑
31 Jul 2024, 12:02
31 Jul 2024, 05:32
It does not matter what its made of, it you kneel on it, and I do as I have bikes, you get wet knees lol (im a wuss)
TFSA
Paa wrote: ↑
31 Jul 2024, 14:59
TFSA wrote: ↑
31 Jul 2024, 08:42
AR3-GP wrote: ↑
31 Jul 2024, 02:01
Not really, because it's hard to move a car without tires, and you generally don't want an F1 car sit on the floor, so you'd have to have movers under the car, which would the also factor into the weight. And in addition, they sometimes weigh cars during non-race sessions (including qualifying) with tires fitted.
A baseline tire is really the best approach for weighing after a full racing session.
Zynerji
112
TFSA wrote: ↑
01 Aug 2024, 00:38
Paa wrote: ↑
31 Jul 2024, 14:59
TFSA wrote: ↑
31 Jul 2024, 08:42
A calibrated set should def be used for weights.
Zynerji wrote: ↑
01 Aug 2024, 01:11
TFSA wrote: ↑
01 Aug 2024, 00:38
Paa wrote: ↑
31 Jul 2024, 14:59
The cars don't race on weight-calibrated tyres so why check them with such?
The teams have their tyres in the garage and will doubtless weigh them and then set up the car according to the lightest set. Although new sets of tyres are all going to be within tens of grams of each other, not 1 or 2 kg difference.
Zynerji
112
Just_a_fan wrote: ↑
01 Aug 2024, 07:45
Zynerji wrote: ↑
01 Aug 2024, 01:11
TFSA wrote: ↑
01 Aug 2024, 00:38
Min weight being car + calibrated tyre allows the teams to NOT be responsible for the FOM mandated flaky tyres that Pirelli provide.
Someone running a George strategy shouldn't be penalized for his ability to manage the tyres for extended stints. Saying that, Mercedes should have thought of the pit entry after checkered, and compensated for no rubber pickup.
chrisc90
That’s if the tyres were to blame. There could be other factors, but tyre usage is the easy β€˜PR response’
basti313
basti313
32
Zynerji wrote: ↑
01 Aug 2024, 01:11
TFSA wrote: ↑
01 Aug 2024, 00:38
Paa wrote: ↑
31 Jul 2024, 14:59
Why? They simply gambled too low. Every one gambles on this.
If you want to remove any gamble, you need to strip every car after each race, clean off all dirt, dry it, replace the floor and put it on new wheels. Also the question is if the driver just sweats, pees or bleeds into the car...what to do with this? How to accommodate the weight loss? Sorry, this is all nonsense. They have a minimum weight with which they need to enter the pits after the race...and if they are too low, they are too low.
Don`t russel the hamster!
Dunlay
Dunlay
basti313 wrote: ↑
01 Aug 2024, 15:58
Zynerji wrote: ↑
01 Aug 2024, 01:11
TFSA wrote: ↑
01 Aug 2024, 00:38
I think a good suggestion is a good suggestion. After all, F1 has been evolving through the decades in it's regulations. I think baseline tyres are a good idea. Let's not have any bias blinding away from good considerations. Pirellis have been pathetically low in their product quality. So a basline tyre would eliminate the on track stupid behavior of Pirelli compounds.
What happens when a car has puncture and misses part of the tyre, but wins like Lewis did in 2020 British GP?
Polite
Polite
the weigth limit rule doesnt affect the car that (for crashes ...) losts parts..
In the russell case, the car was perfect.
cplchanb
cplchanb
Dunlay wrote: ↑
01 Aug 2024, 16:08
basti313 wrote: ↑
01 Aug 2024, 15:58
Zynerji wrote: ↑
01 Aug 2024, 01:11
https://preview.redd.it/irx5sot7yhb61.j ... 4d0cc87558
in that case the fia has the discretion to fit a similar tyre to the car to compare.
Zynerji wrote: ↑
01 Aug 2024, 14:46
Just_a_fan wrote: ↑
01 Aug 2024, 07:45
Zynerji wrote: ↑
01 Aug 2024, 01:11
As they say "it's the same for everyone" and Alonso only did 3 fewer laps than George and wasn't underweight. And does anyone buy the idea that 3 laps is 1.5kg of rubber? The tyres would have lost 10s of kilos over the stint if that were the case i.e. they'd have lost more than they started with.
The tyre wear thing is a red herring to cover up a simple cock-up by George's side of the garage during car set up. I bet something silly like a tool being left in the car when it was being weighed prior to the race and then picked up after the weighing and the person not thinking about the consequences.
basti313
basti313
32
Dunlay wrote: ↑
01 Aug 2024, 16:08
Nothing. Just look at the 2020 British GP results. There is a rule for damages.
Just_a_fan wrote: ↑
01 Aug 2024, 17:48
Well, I think they just forgot about the missing pick up. According to Merc Lewis had the same starting weight, so I guess he is just lucky...does anyone know how much he was over the threshold?
And actually it is surprisingly clean on the start/finish straight. In the on-boards after the race I can not spot any marbles on the track there.
