McLaren MCL38
michl420
michl420
Re: McLaren MCL38
This rear wing has a flap which leading edge curves down on the end (outer 5 cm) now. Similar to the version of mercedes has. Is the benefit more outwash from the under side of the wing or whats the benefit?
mwillems
46
Re: McLaren MCL38
michl420 wrote:
22 Aug 2024, 14:53
If you mean the DRS Flap leading edge(top flap), then it will be loading the rear wing more I believe. Because of this configuration, when DRS is open, the main plane is still pretty loaded, which I suspect is in part down to the fact that the biggest DRS zone starts on a curve which still requires some downforce. As I mentioned, it is interesting because of the way the Main Plane is huge and the DRS flap overlap, but I do suspect that this is to do with the configuration of the DRS "Straight", which is not straight.
You'll often see some DRS Flaps being larger and the main plane smaller to reduce drag under DRS conditions, but the DRS flap is simply larger for load purposes, and the main plan large enough that it produces enough downforce/extracts enough air from the diffuser when the DRS is engaged, something that isn't usually a consideration on a proper "straight"
-Bandit
FittingMechanics
FittingMechanics
16
Re: McLaren MCL38
Upgrades in Zaandvoort.
mwillems
46
Re: McLaren MCL38
Two wings have been brought to Zandvoort. This is courtesy of Amus
This appears to be a lower DF configuration than the new wing and lower DF than what was used at Monaco.
Edit: I see Vanja had posted this pictuire already, although I don't think this is the new wing, is it? I think it's the Very High downforce wing I posted from Fabrega that is new.
-Bandit
michl420
michl420
Re: McLaren MCL38
mwillems wrote:
22 Aug 2024, 15:06
michl420 wrote:
22 Aug 2024, 14:53
I mean actually that part of the flap that stays when the DRS is open (not the main plane). I do not think someone cares about downforce when DRS is open, the only interest is cutting drag. And maybe that´s the reason for this design, that this rounded "edge" reduces inducted drag also/mostly when DRS is open?
I mean that difference between the mclaren/mercedes version and red bull version.
https://pbs.twimg.com/media/GVlAKtVXEAA ... name=large
Lucky
Lucky
157
Re: McLaren MCL38
Emag
Emag
Re: McLaren MCL38
First look at the new floor edge
Developer of F1InsightsHub
CjC
CjC
Re: McLaren MCL38
Emag wrote:
23 Aug 2024, 11:01
https://i.ibb.co/nfRddPh/IMG-6010.jpg
First look, looks like they have gone a different way than Red Bull, Merc and now Williams with the double stacked winglet at the front on the floor edge?
Just a fan's point of view
mwillems
46
Re: McLaren MCL38
mwillems wrote:
23 Aug 2024, 10:52
https://imgr1.auto-motor-und-sport.de/M ... 134820.jpg
Why is this rated negatively instead of an actual reply? It is a picture posted by Amus of the Zandvoort wing posted on the 22.08.24? It's clearly different.
Edit: Ahh, I missed that Vanja had posted the pic, but still, not worthy of a downvote, this seems a bit childish.
-Bandit
mwillems
46
Re: McLaren MCL38
michl420 wrote:
23 Aug 2024, 10:54
mwillems wrote:
22 Aug 2024, 15:06
michl420 wrote:
22 Aug 2024, 14:53
Because the DRS Zone opens before the start of the final high speed corner (Turn 14), I think at Zandvoort it may be a consideration that the Diffuser is having enough air extracted and the rear wing producing enough downforce so that exiting onto the straight isn't an issue. The last corner that leads to the straight is very much rear dependant. Would you get enough downforce and have a stable enough rear if the main plane was smaller in that DRS Zone?
Back to why, I can only think they are trying to efficiently get more load onto the wing when closed, when open, do you mean DRS flap will form a horizontal spoon shape like the main plane when the DRS is open? It would be more efficient to be a flatter profile, surely? I thought the spoon shape was an efficient means of creating downforce, if that is indeed what you refer to.
-Bandit
SSJ4
SSJ4
Re: McLaren MCL38
f1rules
f1rules
623
Re: McLaren MCL38
I think this is the new brake inlet design
And floor edge
You can see how much clear space they freed up under the inlet, before they tried to free up space above
and since this is landos car, it should be the new high df rw also on the picture
Luscion
Luscion
119
Re: McLaren MCL38
https://x.com/AlbertFabrega/status/1826953918326219233
New McLaren floor with smaller edge wing support brackets
Emag
Emag
Re: McLaren MCL38
Luscion wrote:
23 Aug 2024, 14:06
https://pbs.twimg.com/media/GVqk5wKXkAA ... name=large
That thing is almost floating. Surely it’s more flimsy and it would flex down under high load?
nicolas
nicolas
Re: McLaren MCL38
