I think they got caught off-guard by the track changes. Some corners got faster because of the more forgiving kerbs and there is now more "track" available on both entries and exits. That means a little bit more downforce now actually helps out more than before in terms of laptime.Mcl_G10 wrote: ↑31 Aug 2024, 14:32I think it's a slight concern if the rw and fw they bought here aren't on the car as it would suggest they did not pay the intended dividends. I'm not sure spa spec downforce is quite enough for monza although we should in which case be faster through the higher speed corners. This coupled with mclarens fantastic slow speed cornering should bode well overall.
We will find out soon enough
Couple that with a green track which increases tire wear, they probably saw the extra-low df package wasn't the way to go.
