PapayaFan481 wrote:
28 Oct 2024, 18:51
Were you watching a different race??
Guys, honestly, I'm not interested in redditing and twittering here. Driver ying yang does not interest me. I watched the race and rewatched both cases multiple times
If you have specific arguments to counter my point, by all means write them down and lets discuss :)
langedweil
FittingMechanics wrote:
28 Oct 2024, 19:38
langedweil wrote:
28 Oct 2024, 19:22
Mattchu wrote:
28 Oct 2024, 19:10
Well the other two stewards were French and a Mexican and they fully agreed with the ruling, but I suppose there`s some bias in them as well! I mean, have some of you even read the what they said.
https://i.postimg.cc/YqvHs5Dq/t8.png
How do you gain a position if you're already ahead ?
You haven't completed the overtake, you were just entitled to the space but since you didn't manage to stay on track, the overtake is not complete and you need to give back the position. It's quite simple.
Yeah well, as Lando was ahead after T5 he already had his position.
So what is there to give back then !?
There was no issue as Nor gained his position ..
HuggaWugga !
Emag
Emag
137
This is what would have happened if Max was a normal driver. The only reason Lando could not complete the overtake is because he was pushed off completely.
Developer of F1InsightsHub
Jurgen von Diaz
-1
Yes, Max isn't a normal driver. He is soon to be a 4x champ, becoming a legend like Senna and Schumacher by being a dick like them.
Vettel165
Emag wrote:
29 Oct 2024, 00:41
Yeah agree, he is much better than being normal. This is what I like about him, he is always on the limit/edge, just like Senna, Michael were. Normal is boring. Sometimes it doesnt work, but when it does it looks amazing. Lets move on.
Watto
Watto
Vanja #66 wrote:
28 Oct 2024, 21:00
PapayaFan481 wrote:
28 Oct 2024, 18:51
I do think Lando worked the rules against Max here.
I think he would have just made T4 but would have been heavily compromised for T5.
Carried the extra speed into T4 to get to the apex ahead of Max knowing Max would push him wide - even to the point I agree Lando has gone in probably willing to accept he may not make the corner.
The only question I have - and this probably goes back to the point of McLarens protest, Was Lando considered the attacker here. Max did make the corner.
I think the penalty was there but I do think the the media making Max more a villan than he really was.
I think I understand why they are waiting until Thursday to decide on taking the engine. They are waiting for the weather forecast. If it's wet, they won't take the engine since laptime is less sensitive to engine power in wet conditions. If it's dry, they'll take it. If it's wet and they don't take the engine, they'll just take it in Las Vegas where it will be dry and there's long DRS straights.
#ReleasetheADUO
Watto
Watto
29 Oct 2024, 01:37
Makes sense having a quick look at the forecast. But I wonder if the potential for rain makes it more or less likely to upgrade this weekend?
Watto wrote:
29 Oct 2024, 01:46
29 Oct 2024, 01:37
If it's wet, there will not be DRS to help with overtaking. Visibility will be poor. Risk for a 1st lap crash in the wet starting from the middle of the pack is also very high.
They should have taken the engine back in Monza.
#ReleasetheADUO
Watto
Watto
29 Oct 2024, 01:56
Watto wrote:
29 Oct 2024, 01:46
29 Oct 2024, 01:37
Yeah that was what I was thinking. Just wondered ever so slightly if it was going to be a wet/dry race if the extra pit stop might hide the penalty a little
PapayaFan481
PapayaFan481
Vanja #66 wrote:
28 Oct 2024, 21:00
PapayaFan481 wrote:
28 Oct 2024, 18:51
OK. T4: Lando was 100% making that corner until Max forced him off the road. If Lando didn't open up his steering to avoid Max then they collide. It is that simple and someone has already kindly provided still frames of the corner in the other thread to support this. T5 UNDER THE CURRENT RULES, is a separate corner and has no bearing.
T8: Even Max has offered no defence there, only complained about the penalty. So you seem to disagree with even the driver you're defending. When experienced F1 drivers up and down the grid are calling the T8 move "dangerous" and crossing the line, why do you think you know better than them?
If I come across as blunt, I apologise, it's my ASD. Sometimes, like an F1 car aqua-planing, it gets out of my control.
PapayaFan481 wrote:
29 Oct 2024, 07:51
In T4 Norris opened up his steering wheel and immediately turned right to cut T5 to overtake Max. He had no intention of making T5, but I can't say of his intention to leave track right after T4 even though he'd have to apply brakes a lot more to have any hope of making T5.
As for T8, Norris was 50m earlier on brakes than he was the next lap (Max was on brakes at about the same place as usual, though couple of meters early as well) and instead of going wide to switch back he keeps himself alongside Max.
How did Max force Norris off track if Norris was so far back by the time they reach the track limit? What prevented him going right and wide a bit to turn left (yellow line) and let Max look like a total amateur for going off on his own? Nothing at all, it was his own choice to stick alongside Max and run wide, he was completely behind Max and therefore couldn't have been pushed wide because Max was already ahead. 10s penalty for Max has no legs to stand on, other than steward bias
I have no idea what you're on about all drivers calling the move dangerous, no one was asked. And if they were, they had no access to full telemetry or full video recordings like stewards do when they make their decisions
PapayaFan481 wrote:
29 Oct 2024, 07:42
So Horner argued that Lando should have gotten a penalty for basically doing what Max did last week without getting a penalty?
Seems about right for Mr Horner.
Not sure what you're on about mate. Lando got a (reduced) penalty for overtaking outside the track last week and should have gotten it now too. It was cut by 5s in Austin because stewards acknowledged he was forced outside the track, but still got 5s because he decided to stick with an illegal overtake. Did he not make an overtake outside the track in T5 in Mexico?
FittingMechanics
FittingMechanics
Vanja you are really destroying your credibility with these nonsensical arguments.
In T4 Norris and Verstappen touch wheels as Max drifts over the white line (ensuring Norris can't stay on track). It is utterly ridiculous to claim that Norris "opened up the steering" and "immediately turned right". He did so after they touched. Norris was pretty much full lock while Verstappen was the one who "opened up the steering" to drift to the white line.
Your T8 argument falls apart because Verstappen got the penalty for T8 because he gained an advantage off track, not because Norris was forced wide (even though he was).
deargodhelpme
deargodhelpme
Even Jos said T8 was too much from Max...
FittingMechanics
FittingMechanics
Btw Norris probably braked 50 meters earlier for T7 because his tires were still dirty from grass. The car definitely looks skittish on braking into T7.
