2024 Scuderia Ferrari F1 Team
jambuka
jambuka
3rd best over 1 lap ?
SoulPancake13
SoulPancake13
Charles really struggled in SQ2 with front tyre temps. Hopefully SQ3 goes better.
Xyz22
Xyz22
125
SoulPancake13 wrote:
29 Nov 2024, 20:04
This small tyre window has been a problem since the start of the season, crazy.
Anytime Sainz does better, the plethora of excuses come out for Leclerc...
Beware of T-Rex
yooogurt
40
Damn
FORZA FERRARI SEMPRE!
SoulPancake13
SoulPancake13
That's a bit ---.
Track temps drop and we are nowhere, both drivers complained about understeer on their final runs. I hope 2025 can fix this issue because it is just plain annoying at this point.
.Bole
.Bole
-1
Bad quali again, bad prep for this weekend. We are experimenting too much.
Too much understeer
Xyz22
Xyz22
125
This is what i expected lmao...
Probably way less fuel in FP1.
ScuderiaLeo
The drivers were only 0.027 apart. I think they were on low fuel loads earlier, plus track temp dropping and soft tires may have made things more difficult.
Honestly we're much closer to pole than I expected coming into the weekend, so...
Anyways, we knew this would be a tough track though and McLaren would be stronger. Points are tomorrow, let's hope they can make up ground there.
Cs98
Cs98
Another statement from Sainz, not getting the upgrades but still putting it ahead.
SoulPancake13
SoulPancake13
Cs98 wrote:
29 Nov 2024, 20:24
I don't think it was really an upgrade if they only decide 30 minutes before SQ to put it on. Still, credit where credit is due.
MV8
Bad preparation for this SQ, let's see if they can do some work for tomorrow's qual.
Cs98 wrote:
29 Nov 2024, 20:24
You people are pretty boring around here. #-o
Just posting
SoulPancake13
SoulPancake13
Front suspension change needs to be good, can't handle another year where the drivers can't express the pace of the car due to no temps. I have a feeling race pace will be strong here.
SoulPancake13
SoulPancake13
29 Nov 2024, 20:16
No excuse here, just stating what Charles said on his radio. It is clear at this point that Sainz is doing a better job with tyre warmup than Charles is, which you can see in their driving styles, hence why Charles has better tyre management.
Cs98
Cs98
29 Nov 2024, 20:27
Cs98 wrote:
29 Nov 2024, 20:24
I doubt Leclerc or the team would want to drive a new floor in the dying moments of a WCC battle if they didn't think it was an upgrade. He was clearly enjoying it in FP, but Sainz hadn't showed his hand.
