2024 Scuderia Ferrari F1 Team
ing.
69
F1NAC wrote:
14 Dec 2024, 10:33
JPower wrote:
14 Dec 2024, 05:24
Seanspeed wrote:
14 Dec 2024, 02:48
This year's car had some very clear foundational weaknesses that prevented the team and drivers from having anything that could be considered the 'best' car. And having the best car is always the goal.
If 2025 were to start where 2024 left off, Mclaren would be massive favorites for both WDC and WCC. Ferrari has a great driver pairing, but we cant rely on Mclaren and Norris having mess-ups all season long. We need to produce an equal or better car to actually grasp the title chances in our hands, rather than just hoping it slips through Mclaren's fingers in our favor.
And to get such a car with a higher performance floor and ceiling, we clearly need to take some more chances on design. It's risky, but it must be done.
It's also pretty crucial to get the 2025 foundation as good as it could be, because no team can afford to devote development resources to the 2025 car all season long for a title battle.
I understand all of that, just saying that developing a new front suspension with all of the risks that entails is almost a leap of faith at the tail end of a regulatory set. No do-overs or revision like 2023 to 2024. Of course, it could very much payoff and put Ferrari in a place where they can explore new avenues of development. But there's significant downside risk as well.
I'm no F1 engineer though and I'm sure they have more than enough data support the decision. Fingers crossed it works out.
It’s not like the kinematics of the front pull rod had changed. They have experience from 2012-2014 period.
Not to mention the rear pull rod they’ve been using all these last few years.
In any case, the modelling of the suspension—either kinematics, stress analysis, or wheel spring rates—will be the least of their problems since these can easily be modelled and assessed. Same for the aero impact of the choice of suspension linkages configuration, using CFD and WT.
The one area they potentially can go wrong is in the choice of target parameters like camber gain, rising rates, etc., though I would expect that they could build in some adjustability—even through use of new parts—so they’re not painted into a corner with their choices.
mstar
mstar
Henri wrote:
13 Dec 2024, 11:10
https://formulapassion--pro-ey-r-appspo ... r_pto=wapp
Fred saying the sf25 is a beast but on paper. Hope it matches the simulations 😊
Gives me Mercedes vibes every Dec/Jan/Feb.... :shock:
mstar
mstar
I must admit i am a little skeptical how the new front end change works. Charles is so dependant on the front end feel, i guess if your going to do it. its now.
What is the main reason? Aero gain??
ing.
69
mstar wrote:
14 Dec 2024, 13:27
Ultimately the choice of push/pull configuration—apart from weight and CG considerations—is driven by aero compatibility, as explained by Newey here:
https://www.formulapassion.it/f1/f1-ana ... lta-perche
As regards front end effectiveness and feel, this is mainly determined by kinematic geometry and spring/roll rate choices that can be tailored into either push or pull configurations.
deadhead
86
It seemed like LEC was really comfortable with the launch F1-75 front end so if they want him to go fast I guess lean towards that end of the spectrum. I’m sure it’s not that simple, of course, but at least they have a reference point of some sort.
HAM is an enigma, some say he likes strong rear (so like Vettel?) others say front so..
Hopefully their styles aren’t too different because that would sucks for the engineers.
ScuderiaLeo
deadhead wrote:
14 Dec 2024, 16:41
I doubt Ferrari has been making cars with weak front ends on purpose. They seem to unintentionally loop back to it every season while chasing other development goals.
But this is why getting new, young engineers who can bring other perspectives is so important.
dialtone
dialtone
139
ScuderiaLeo wrote: I doubt Ferrari has been making cars with weak front ends on purpose. They seem to unintentionally loop back to it every season while chasing other development goals.
I don’t think that’s how it happens practically.
Through the season they go look for aero efficiency, weight savings/distribution and increasing downforce around the car. If you are limited on the front downforce development you will eventually have balance moving to the rear just by virtue of finding it more easily there, and you typically never refuse to add it.
Farnborough
Farnborough
152
Interesting that the two most successful chassis of this era in rules have both been of same basic suspension orientation, RB & McL taking the various championship.
It's certainly no guarantee that its core reason, but this must produce enquiry within the Ferrari design team as to what they can see in that with their own evaluation and measured against their own known data accumulation of internal performance.
At a guess, they've identified something that they feel brings performance by commitment to change front layout.
Newey stated that he favoured the pull layout for measurable front end flow potential, I believe.
ScuderiaLeo
Excuse me if it was posted and I missed it, but was the rumor of Ferrari moving away from Brembo true?
Z-one
Z-one
ScuderiaLeo wrote:
15 Dec 2024, 00:32
not true,just a fake news
Seanspeed wrote:
14 Dec 2024, 02:48
"We" ??
Next year will be fun..
Farnborough wrote:
14 Dec 2024, 22:37
Yeah. That little arrangement of front pull rod does seem to be giving that tiny percent better airflow to the front of the floor and is worth pursuing.
Farnborough
Farnborough
152
15 Dec 2024, 05:16
Farnborough wrote:
14 Dec 2024, 22:37
Making it clear that it's my perception in this view, the flow path from outer edges of front wing flap (inside tire face) through past the brake duct, then over the "foot" on rear of that duct, onto "primary" outside located barge board, is all enhanced by removing that push rod strut. This to shed more wake outboard of sidepod to amalgamate with flow pushed outward in front of tire by those twisted front wing end plates.
This may make the whole flow structure there less susceptible to wheel turning and yaw effect, ultimately to give improvement in linearity of front end flow structure.
As I've noted, they'll have comprehensive data from their own pushrod layout as competent baseline against which they can model (in cfd etc ) to give valid predictions in making this decision. They seem to have noted this earlier in the season, with claims made indicating a change here was their direction. Certainly enough time to comprehensively evaluate and not just jumping onto something else of another's design that some comments seem to imply.
Seanspeed
Seanspeed
JPower wrote:
14 Dec 2024, 05:24
Seanspeed wrote:
14 Dec 2024, 02:48
JPower wrote:
13 Dec 2024, 18:28
Have some faith in Fred lol
Although, I do wonder why they’ve decided to redesign the front suspension when they are finally seeming to get the hang of their current design.
If you're playing scared, you're losing.
The current regulations were originally meant to come in 2021, but that of course got delayed. And at the time, it was largely expected that the 2021 cars would be fairly simple evolutions of the previous year's cars, which obviously were meant to be 'last in line' for that set of regulations. But it was clear immediately upon seeing the debuts of the new 2021 cars that the top teams were absolutely insistent on pushing. Perhaps nothing super radical, but absolutely teams willing to keep pushing hard rather than treating it like some lazy bridge year. And Red Bull ended Mercedes' reign of terror, retaking the title they hadn't won since 2013.
Red Bull not only pushed very hard with the base of the 2021 car, but they still managed to maintain a healthy development program for the new regulation 2022 car at the same time. And while Ferrari isn't exactly Red Bull(and there's no Newey involved here), the idea is still pretty clear - you have to aim high and cant leave opportunities on the table.
Seanspeed
Seanspeed
15 Dec 2024, 05:13
Seanspeed wrote:
14 Dec 2024, 02:48
"We" ??
You've been watching F1 and sports long enough in your life to know this is an extremely common way of talking about the team you support. Good lord. smh
