Tomba wrote:I don't quite understand why teams should push for bigger brake discs. It has been repeated many many times over the years that one of the causes for the overtaking problems is the strength of the brakes, or rather the short braking distances.
While one could argue this from a safety point of view, I'd even suggest to (slightly) reduce the size of these discs. Surely brake discs are expensive, and smaller discs would cost less, something that the FIA will no doubt like.
And picking in on the KERS topic here, once the teams are all under budget limitations equal to one another, the FIA should allow KERS on all four wheels.
It has been repeated many many times that:
-downforce should be reduced
-diffuser should be a bigger part of the total downforce
-tyres are harder
-H-pattern gearbox levelers should come back
-engines restrictions to be suspended
-Steel brakes should be re-introduced
-wider tracks (for tracks)
-wider track (for cars)
-and so on...
Would provide overtaking...
And none of that propositions has been studied throughfuly and when it was done, the conlusion were the opposite.
We need to stop with enthusiasts F1 rules remap..
LOOK at the races overtakings in F1, the vast majority is done on braking!
It is very easy to look at non present features and say they would help overtaking just because they're not there. It is so easy to slam current features and say they are the culprit.
The bigger brake pads would just to be able to withstand the heavier cars and races with less cooling time.
