McLaren MCL39
FDD
FDD
83
Re: McLaren MCL39
If I remember well that kind of geometry is anti anti-dive.
Different aero management/interaction that is for sure, AFAIK and based on many analyses made by You and some other guys on www.newsf1.it
mwillems
Re: McLaren MCL39
https://www.planetf1.com/news/mclaren-m ... 8-headache
As suggested previously, only small adjustments will be needed to ensure Mclarens flexing front wings remain legal when the new tests come in.
-Bandit
Re: McLaren MCL39
FDD wrote:
14 Feb 2025, 16:02
As far as I know, over 100% anti dive leads to jacking, ie hopping under braking. It's more than bad
However, this would be a very different geometry, as you can see on this illustration, not really what McLaren is doing I think
DJ Downforce
Re: McLaren MCL39
The increased anti dive will be for pure aero purposes only. You can even see it with one of the wishbones aligned with the pull rod.
Andi76
Andi76
476
Re: McLaren MCL39
Vanja #66 wrote:
14 Feb 2025, 19:47
FDD wrote:
14 Feb 2025, 16:02
https://livetodai.com/uploads/default/o ... 1e6d0.jpeg
And you are right. The percentage degree of anti-dive of the car does not depend on how low the attachment point of the rear leg of the upper wishbone is, as many journalists keep telling or "experts". One part of a wishbone does not work in Isolation and
it is simply wrong to think that you can simply lower the rear leg of the upper wishbone and get more anti-dive. The length and height of the side view swing arm, the wheelbase and the height of the center of gravity also play a role, as does the height of the lateral IC.
With this arrangement of the wishbones, the lateral instant center is very close to the ground level. If it was about anti-dive you would actually angle the WBs in the other direction and you could get a whole chunk more anti-dive with less restrictions whether structural or mechanical. There are some good explanations and illustrative examples in this forum that have already demonstrated several times that less a "Red Bull"-style inclined Suspension gives more anti-dive and your picture also illustrates it well. So what this is really is about is purely aerodynamics, not Anti-Dive.
Also, 100% anti-dive or more is not desirable even for a car with strong aerodynamics.If a car has 100% anti-dive then there will be no compression of the suspension at all due to braking forces. Nobody, at least in F1, wants that because it only brings disadvantages such as poor feedback to the driver, jacking and hooping under braking.
One thing McLaren could do here (but not with the rear leg of the upper WB in isolation!) would indeed be 100% anti-dive or more in static conditions. It is possible that they have developed a suspension that with the downforce generated by the aerodynamics, the geometry is then shifted to a new position where the anti-dive percentages drops below 100%, so they still have the maximum desired anti-geometry when it moves. Wouldn't be the first time and not unusual. But again - not with or because of the rear leg of the upper WB in isolation.
Re: McLaren MCL39
Andi76 wrote:
15 Feb 2025, 05:36
This would be a thing Marshal and Prodormu got from Newey, but didn't Newey do it at McLaren while there too? Hmmm
WardenOfTheNorth
Re: McLaren MCL39
Vanja #66 wrote:
15 Feb 2025, 12:06
Andi76 wrote:
15 Feb 2025, 05:36
The circle is complete 😂
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
Emag
Emag
137
Re: McLaren MCL39
Edit: Note how much "opened-up" the space between the suspension arms is compared to last year.
I also spotted this cooling "slit" similar to what the SF24 was using too.
Ferrari for reference :
Developer of F1InsightsHub
f1rules
f1rules
639
Re: McLaren MCL39
some pics extracted from video
f1rules
f1rules
639
Re: McLaren MCL39
this is the best picture yet, where did you find, from a video?
Emag wrote:
15 Feb 2025, 18:04
https://i.imgur.com/wdytvyR.png
https://i.imgur.com/FCI5fHc.png
Emag
Emag
137
Re: McLaren MCL39
f1rules wrote:
16 Feb 2025, 00:09
Emag wrote:
15 Feb 2025, 18:04
Yep, it's from the video F1 posted on their channel (around min 2:50 there's a couple of seconds showcasing the MCL39)
f1rules
f1rules
639
Re: McLaren MCL39
Thanks for sharing, so now they allowed for everyone to see
I know you cant judge anything from pics but i really really have a good sensation about this car and the adjustments made, and how on top things and full of confidence the team seem to be
FDD
FDD
83
Re: McLaren MCL39
Vanja #66 wrote:
14 Feb 2025, 19:47
FDD wrote:
14 Feb 2025, 16:02
First of all excellent drawing-scheme, saw somewhere somthing like this.
Yes, that was my point, they want smaller amount of anti-dive, that's why I said "anti anti-dive".
FDD
FDD
83
Re: McLaren MCL39
Andi76 wrote:
15 Feb 2025, 05:36
Vanja #66 wrote:
14 Feb 2025, 19:47
FDD wrote:
14 Feb 2025, 16:02
That's why I said it looks to me like "anti anti-dive" i.e. reducing the amount of anti dive.
PS Yes, the "story" for more anti-dive with rear leg att. lower came from the journalists "experts".
Andi76
Andi76
476
Re: McLaren MCL39
Vanja #66 wrote:
15 Feb 2025, 12:06
Andi76 wrote:
15 Feb 2025, 05:36
Most probably yes. In any case, the anti-dive value was very high with an instant center similar to that of the CoG (which was 22.5 to 23cm on the best cars at the time - F2004, R25), or even higher. With the known dimensions of the car, even without things like Castor etc, you knew that was probably something Newey and Oatley (who is still at McLaren since the 1980's) were doing here.
