2025 Scuderia Ferrari F1 Team
nico5
25
Re: 2025 Scuderia Ferrari F1 Team
LurkingMostly wrote:
21 Feb 2025, 13:57
Even though the shakedown didn't have problems, the car could have a potential, specific problem.
According to this blog, an anomalous behavior of the car was noticeable during both Leclerc's and Hamilton's runs. Specifically, when the drivers pushed for pace in one specific right-hand downhill curve, the car exhibited noticeable nervousness, requiring strong and immediate countersteering corrections and resulting in time losses. The author of the posts points out that this particular kind of curve doesn't really exists on the calendar (except maybe at Spa), but he raises questions about potential mechanical issues with the suspension, or aerodynamic problems at the rear.
Lol he says negative camber causes oversteer, can't be a serious person
ScuderiaLeo
This article from Giulana is extensive in going over the car's changes, but the parts that stood out to me were:
  • There was a larger focus on braking stability this year as both drivers are sensitive to this
  • The SF-25 has a stronger front than the SF-24, more suitable to what Leclerc enjoys
  • Many little aspects that are clearly evolved parts of the F1-75
https://autoracer.it/it/analisi-ferrari ... iosa-f1-75
Xyz22
Xyz22
124
ScuderiaLeo wrote:
22 Feb 2025, 15:35
I'd wait for the first 3–4 races to understand how the car really behaves.
Very hard to say anything right now as they didn't even use proper race tyres in the shakedown.
Things to look for during test sessions:
- Performance in low/medium speed corners
- Performance over one lap
- Long runs consistency
ScuderiaLeo
Xyz22 wrote:
22 Feb 2025, 16:15
FWIW, Leclerc said something very similar to the 2nd point in a post-shakedown interview, so I do trust that the car's behavior in the sim and this week aligned with what he was hoping for.
We'll see if that translates to the problem areas from last year (ex: tire warm-up).
scuderiabrandon
111
Xyz22 wrote:
22 Feb 2025, 16:15
ScuderiaLeo wrote:
22 Feb 2025, 15:35
The thing about the shakedown was at some point during Leclerc's runs he was very clearly on low fuel with the car slammed to the ground, using DRS. It was very evidently a push run with a rather extreme RH setup. If it all went to plan, I think we can expect it in isolation to be a working well. Obviously it's all relative but in isolation, it does look like a promising start.
Xyz22
Xyz22
124
scuderiabrandon wrote:
22 Feb 2025, 19:53
Xyz22 wrote:
22 Feb 2025, 16:15
ScuderiaLeo wrote:
22 Feb 2025, 15:35
I remember in Bahrain during testing it was already quite clear how the SF 24 was a significant improvement over the SF 23 in race trim (not hard :D), so i hope we see similar improvements in other areas with the SF 25.
I also remember how shocked i was when i saw the SF 23 for the first time in 2023. It was absolutely awful on track.
deadhead
68
ScuderiaLeo wrote:
22 Feb 2025, 16:58
Xyz22 wrote:
22 Feb 2025, 16:15
But the car hasn't been pushed properly yet so they wouldn't know for sure until that happens at a few different tracks. I'm sure Fiorano give some indication, but it's far from ideal when it comes to these cars.
Xyz22
Xyz22
124
deadhead wrote:
22 Feb 2025, 21:41
ScuderiaLeo wrote:
22 Feb 2025, 16:58
Xyz22 wrote:
22 Feb 2025, 16:15
More than the track is the tyres. They can't user proper race tyres in these shakedows and are forced to use "demo" tyres. We know how sensitive the cars are to even a small change in tyres pressure, let alone completely different tyres.
scuderiabrandon
111
Xyz22 wrote:
22 Feb 2025, 22:22
deadhead wrote:
22 Feb 2025, 21:41
ScuderiaLeo wrote:
22 Feb 2025, 16:58
I think these "demo" tyres are just a really hard compound. Like a C-1 if that makes sense. They can't alter the construction, these demo tyres still need to hold up under the forces it gets put through on an F1 ar. So they are not representative, but they are also not completely irrelevant.
Xyz22
Xyz22
124
Anyway if you guys want to do some eye laptime/behaviour analysis ( :D ) here you can find all the last 3 seasons shakedowns (in 2022 there was a lot of fog so no good footage):
SF 23
SF 24
SF 25
*Crazy how "old" the SF 23 looks compared to the SF 25 by the way.
deadhead
68
Wouldn’t lowering the gearbox get in the way of the diffuser? I thought the idea was to get it out of the way.
Also, I remember Cardile saying how the suspension isn’t all the important with these cars and now it turns that it’s actually extremely important? It makes no sense.
Xyz22
Xyz22
124
deadhead wrote:
23 Feb 2025, 13:41
Cardile statement was translated out of context. Cardile said that the is "hard" to completely --- your suspension kinematics because it is something that is well understood these days. Ferrari issues have always been aero related as a matter of fact.
Newey explained perfectly why he decided for the pull rod layout --> He wanted to move the driver position as rearwards as possible to keep the front of the chassis as low as possible.
yooogurt
40
deadhead wrote:
23 Feb 2025, 13:41
Journalists took it out of context, he said it when asked about the tires.
FORZA FERRARI!
Fakepivot
Fakepivot
looking at other cars, ferrari seem to have most visible changes compared to last year... i really hope this does not destabilize and confuse them like Spain upgrade fingers crossed!!
ScuderiaLeo
Do we know who is running AM/PM for each day?
