Maybe you should stay a little more relaxed. Since Leclerc's skid blocks were obviously perfectly OK, I don't see it as a general problem for the time being.Mansell89 wrote: ↑23 Mar 2025, 13:25If it is about plank wear not being legal at their optimum ride height, that’s a bad setback.
To those of you much more technically minded than I, is it even possible to change a suspension philosophy mid-season or is it a case of it just taking too long and not worth it in the final year of regs?
Charles was 1kg underweight which would help to not wear out the skid plank..chrstphrln wrote: ↑23 Mar 2025, 13:33Maybe you should stay a little more relaxed. Since Leclerc's skid blocks were obviously perfectly OK, I don't see it as a general problem for the time being.Mansell89 wrote: ↑23 Mar 2025, 13:25If it is about plank wear not being legal at their optimum ride height, that’s a bad setback.
Only when it becomes clear that they no longer comply with the regulations on his car would it make sense to think about it.
No, that one kilo alone shouldn't have such serious consequences.Dee wrote: ↑23 Mar 2025, 13:37Charles was 1kg underweight which would help to not wear out the skid plank..chrstphrln wrote: ↑23 Mar 2025, 13:33Maybe you should stay a little more relaxed. Since Leclerc's skid blocks were obviously perfectly OK, I don't see it as a general problem for the time being.Mansell89 wrote: ↑23 Mar 2025, 13:25If it is about plank wear not being legal at their optimum ride height, that’s a bad setback.
I disagree.chrstphrln wrote: ↑23 Mar 2025, 13:40No, that one kilo alone shouldn't have such serious consequences.Dee wrote: ↑23 Mar 2025, 13:37Charles was 1kg underweight which would help to not wear out the skid plank..chrstphrln wrote: ↑23 Mar 2025, 13:33
The aerodynamic load produced by these cars makes 1kg of weight negligible.Dee wrote: ↑23 Mar 2025, 13:37Charles was 1kg underweight which would help to not wear out the skid plank..chrstphrln wrote: ↑23 Mar 2025, 13:33Maybe you should stay a little more relaxed. Since Leclerc's skid blocks were obviously perfectly OK, I don't see it as a general problem for the time being.Mansell89 wrote: ↑23 Mar 2025, 13:25If it is about plank wear not being legal at their optimum ride height, that’s a bad setback.
The hit was way too light to damage suspension in any way. Otherwise we'd have those DSQs left, right and center every race.Hammerfist wrote: ↑23 Mar 2025, 13:59Wonder if the contact with Charles caused Lewis suspension to be slightly damaged and lowered the car a bit too much. As for Charles, could the missing end plate have caused this underweight issue?
Anyways, horrendous start of the season regardless.
