Cs98
Cs98
Red Bull have two sister teams so why not use that to their advantage. People get caught up in the drama and media narratives, I don’t think this move is outrageous in the least. Sitting and idly waiting whilst your second RB car qualifies last is not an option. Let Tsunoda have a go, he deserved it more anyways. Liam is still in F1 and has a chance to prove himself in an environment he is more comfortable in at Racing Bulls. He’ll feel embarrassed, but deep down also relieved. As for Tsunoda he literally cannot do worse than Liam, even making it to Q2 would be an improvement.
Cs98
Cs98
Alexf1 wrote:
26 Mar 2025, 09:45
Sergej wrote:
26 Mar 2025, 09:26
26 Mar 2025, 02:29
couple of quotes from Erik van Haren the past few days:
doesn't really bode well for verstappen remaining for much longer in this team, to be honest
Well I believe whoever thinks that Max will stay in Red Bull for long is deluding himself. For me it's clear his future is elsewhere.
Well, Benetton '96 situation incoming then. Berger and Alesi were experienced and quite close as teammates against Senna and Prost. But they were nowhere in the Schumacher style Benetton. Shows you pointy car with looser rear is fastest but only for the generational talent drivers.
Except the RB21 looks neither pointy nor loose. Look at Liam’s laps in the car, it’s understeer and lack of commitment that kills the time for him.
Henk_v
Henk_v
88
I like the decision.
If they'd put yuki in immediately, they would not have had a clear indicagion of the vcarb progress. The vcarb is an experimental platform to improve the rb21.
Now they know. Lawson did not pull a rabbit out of the hat, so swapping is a clear benefit.
Lawson did 50+ clean Laps in China with an experimental setup with no hope for points. That was his final audition. If you can not show your team you are able to master a corner and just complain, the conclusion is there I guess?
SirBastianVettel
SirBastianVettel
Henk_v wrote:
26 Mar 2025, 09:58
That's quite the accusation.
FittingMechanics
FittingMechanics
16
What a knee jerk reaction. Once again. How long until Hadjar gets the seat?
I understand the need for results, but two races is really a slap in the face. At least give the guy a chance for 6-12 races this year and then make a decision.
ali623
ali623
I'm surprised they didn't at least keep him till the end of the upcoming triple-header. Give him a couple of weeks to go away and reflect, and come back to some circuits he knows well like Suzuka and Bahrain - if it's the same story there, then the swap makes sense, but this just seems like a strange decision all round.
Gillian
Gillian
Cs98 wrote:
26 Mar 2025, 09:48
Alexf1 wrote:
26 Mar 2025, 09:45
Sergej wrote:
26 Mar 2025, 09:26
I don't get it either. Look at the McLaren, that's a pointy car.
Alexf1
Alexf1
A car can be driven in many ways, a nervous rear trends to make you more cautious/slower on corner entry which results in less downforce and a different car behaviour. Patrese in '92 active Williams and '93 Benetton are good examples. He just didn't dare to do what Mansell and Schumacher dared on corner entry which has a knock on effect on the rest of the corner. Trust the grip to come and send it on corner entry. Lawson was 30km/h slower in T1 than Max in China. Says enough..
Cs98
Cs98
Gillian wrote:
26 Mar 2025, 13:17
Cs98 wrote:
26 Mar 2025, 09:48
Alexf1 wrote:
26 Mar 2025, 09:45
It's an old narrative from the last regulations where the RB was very sharp on the front, largely due to its high rake philosophy. Since 2022 this hasn't been the case. Out of all the top teams you'd have to say the RB looks the least responsive on the front, especially in medium and low speed corners. Max still manages to rotate the car with some trickery, that is his secret relative to his teammates in this car. I suspect it's a combination of adding a lot of front wing (and tolerating it in high speed), braking early and prioritising the exit, knowing the limit of grip on the front precisely, and insane consistency.
The real issue here is not the second seat, it's the fact that RB can't produce a balanced car anymore, the second seat is a symptom. Max can drive around the issues better but they are losing competitiveness compared to the other teams. We saw what Max could do in a car that had a lot of downforce and good balance in 2022 and 2023, and Perez was winning races and being a decent driver then because the car had reasonable balance.
Vettel165
Happy with the change, lets go Yuki. :D
Rumours of special livery for Japan . Maybe only special racesuits/helmet though idk.
Sergej
26 Mar 2025, 14:19
what's to celebrate ?
Sergej wrote:
26 Mar 2025, 14:25
26 Mar 2025, 14:19
Thanks to Honda for their years with the team.. 4 WDC + 2 WCC in 6 years (so far) isn't bad :|
Vinyl Lap
Japanese driver in a Honda-powered car in Japan? :lol:
deadhead
76
It’s perfect
