McLaren MCL39
Farnborough
Farnborough
152
Re: McLaren MCL39
Interesting detail picture there.
It can be seen that the two holes with serated spline internal are the location of primary spring torsion bars, yet to be installed here. These support the main chassis load in suspension system.
The main spring visible horizontal there, should be the heave element (as both suspension squeeze in, that assembly
pushes both end inwards) the spring and damping within to control vertical pitching at rear of chassis.
Behind that a cooler matrix (transit shield with blue tape) looks like oil from pipe size, possibly tge transmission oil cooler in that location.
deadhead
81
Re: McLaren MCL39
I don’t know anything about suspensions but that looks a very robust structure and I guess it needs to be considering the loads but it’s still rather surprising
deadhead
81
Re: McLaren MCL39
Farnborough
Farnborough
152
Re: McLaren MCL39
deadhead wrote:
03 Apr 2025, 16:50
A perceptive view, nevertheless.
In effect, the design makes the suspension more compact to fit it in the space available. As example IF the wheel movement was 100mm (unlikely I know, for the incoming pedant :D ) and the system going to the suspension control element worked in a 4:1 ratio, then the internal component would move only 25mm in response (more compact) but slso "see" a magnification of absolute load in the opposite direction .... 100kg at the wheel, giving 400kg to deal with in those component we see in image.
As you correctly noted, those component are substantial, but not moving far.
f1rules
f1rules
634
Re: McLaren MCL39
Macklaren
Macklaren
Re: McLaren MCL39
Did we have any updates here? Saw some flowvis on Lando's front suspension in FP1
_cerber1
299
Re: McLaren MCL39
Macklaren wrote:
04 Apr 2025, 12:12
No
De Wet
Re: McLaren MCL39
That Rear Wing is a work of art. 8) 8)
SilviuAgo
129
Re: McLaren MCL39
MCL39 in Suzuka, photo by Mclaren:
And Albert:
SilviuAgo
129
Re: McLaren MCL39
De Wet wrote:
04 Apr 2025, 15:07
Indeed =D> Those shapes specially where the Dropbox name is :shock:
@photo by AlbertFabrega
Re: McLaren MCL39
SilviuAgo
129
Re: McLaren MCL39
And some info on RW. This weekend,, at least for FP1, we have same wing as in Suzuka:
Bahrain requires less loaded wings than Suzuka - Despite that, McL and Ferrari are using the same ones seen in Japan
Mercedes' top speed was the highest in quali; despite that, they've further reduced the wing load
RBR, instead, has increased it!
Many unexpected choices: expect some teams to change spec for qualifying
Analysis by Formula Data Analysis
Photo by AlbertFabrega
CjC
CjC
Re: McLaren MCL39
Supposedly McLaren have a circuit specific beam wing for Bahrain so I don’t expect McLaren to change the main element of their rear wing for quali
Just a fan's point of view*
SmallSoldier
SmallSoldier
488
Re: McLaren MCL39
We normally don’t get to see this angle:
Vía: @xavigazquez
Brahmal
Brahmal
75
Re: McLaren MCL39
SmallSoldier wrote:
11 Apr 2025, 00:42
https://i.imgur.com/tpGkv06.jpg
Vía: @xavigazquez
Very cool. Do all the cars have those cable-stays there?
