venkyhere
venkyhere wrote:
12 Apr 2025, 16:40
Vettel165 wrote:
12 Apr 2025, 16:33
Season over, Piastri WDC confirmed. Max has no chance, it was a miracle he won last year. Only because his driving was amazing. And it was the same when he won last weekend. On this circuit even a podium would be very hard. Mclaren are dominant. Game over lads. But nothing lasts forever, we had a good run of 4 years. Hope somebody proves me wrong, but I doubt it.
Will just relax and take it easy this season as a Max fan. But the gap in FP3 was more then a full second on low fuel.
Don't knee-jerk so much :)
That 1.2+ advantage of Piastri over the grid is because McLaren had turned up the wick to Q engine mode. Norris, however poorly he drives, isn't going to be 0.2s per sector behind Piastri - that leads me to believe Piastri simply went full engine mode OR it was a purely-by-chance perfect tyre prep for the given track temp.
1+ is the kind of advantage I expect in R trim, not Q trim.
oops !!! what a knob I was to call it 'knee jerk'. Sorry, @Vettel165. That said, 1.2+ deficit is looking real in race trim.
Car is really poor, understeering, heating up the softs and no brakes is the cherry on the cake.
Hope all the understeer helps rear tyre preservation without too much laptime loss on the M and H compounds tomorrow - it's all about damage limitation. Max will do well to finish P6 tomorrow, behind the McLarens, the Mercs and LeClerc. Will have to keep atleast Hamilton behind, to call it a damage limitation. However, starting from 4th row is 'par' for the course for this RB21. Tsunoda is sure to drop out of the points.
I think Tsunoda he will get his first points tomorrow but it's only a small victory given the more glaring issue...
It seems somehow baked into the philosophy of Red Bull cars. The Racing Bulls did not make Q3 for the first time. In Q2, Hadjar was only 2 tenths behind Max when he was eliminated. This is consistent with the gap in qualifying in Australia and China.
Vettel165
venkyhere wrote:
12 Apr 2025, 20:29
venkyhere wrote:
12 Apr 2025, 16:40
Vettel165 wrote:
12 Apr 2025, 16:33
No problem buddy. We really need to fix this tyre thing. On circuit with high-deg we are nowhere, but soon as this isnt a factor we are back on pace.
Will see how the hards will work tomorrow, I think better than softs for sure. But the question is why they didnt try to run for Q3 on the medium tyres. It happened in the past when deg was high, that you could be faster with the tyres which were harder.
napoleon1981
napoleon1981
I had that same thought, I assume they had the data to know that it wasn't going to work.
12 Apr 2025, 20:34
Oh well
"Let's start positively," Marko told Sky DE. "Tsunoda finished in the top ten, but Max was not satisfied. He had some problems in Q2 and huge brake problems in Q3. You could see that in the data. So far, we have no explanation for it."
...... First, we need to find out what is causing the brake problem. Then we have to discuss with the FIA whether you can adjust, grind off or install the brake pads."
bad parts...
https://racingnews365.nl/marko-onthult- ... gp-bahrein
12 Apr 2025, 21:49
bad parts...
It's fine. Damage control until Imola. This is round 4. 1 point we're behind Norris and he's what? 6th? Stop dooming
12 Apr 2025, 21:50
12 Apr 2025, 21:49
bad parts...
I mentioned the brake thing as it gives better chances since they can see an issue, and could attempt to make it better. They aren't going to win, but maybe P3/P4/P5. I really think the brake issue cost a 2nd row start. Leclerc and Antonelli were no better than the Alpine. Max was only 2-3 tenths away with a very conservative lap.
12 Apr 2025, 21:54
12 Apr 2025, 21:50
Agreed if they can fix it it's p4. If it goes well P3
AUTO MOTOR UND SPORT - What was wrong with the brake [for Verstappen]?
After the qualifying session, the engineers immediately put their heads together to solve the strange problem. It had never occurred in the first three races.
"We had it to some extent on Friday," Christian Horner said. There were two theories. One of them: It was due to the disc material. Red Bull had switched from Hitco to Brembo over the winter.
But that was considered rather unlikely. It made more sense that something went wrong with the brake adjustment. It is individually adjusted for the driver. It's about how the braking force builds up when pressing the pedal and then distributes from front to back.
That would match Verstappen's statement that he lost the feeling when braking.
Marko resident is sure that with an intact car, his superstar could have made it to the second starting row. He hasn't given up hope yet. "If it gets cool again in the evening and the wind picks up, there might still be a surprise." Provided that Verstappen's brakes work again.
https://www.auto-motor-und-sport.de/for ... ualifying/
It was always close between Red Bull, Mercedes, and to some extent Ferrari. There's no margin for not having the car working properly so that is why they are P7 instead of better.
Bill
Bill
At no point did the redbull look like a car that could challenge for high positions not in practice or quali q1 even during prac Max was aborting laps a number of times
Bill
Bill
12 Apr 2025, 22:13
redbull changed to brembo last year .Max had brake fire in Australia i thought in was related to lack of experience with that manufacture
ispano6
164
Lots of comments in this thread are off topic, this is the Red Bull team thread, not Piastri or Ferrari thread.
Bill wrote:
12 Apr 2025, 22:18
There was only 1 relevant practice session (FP2) and Max also had the brake issues at that time. FP3 was in conditions that least suit the Red Bull. The cars are very sensitive. There may be a point in the race tomorrow (towards the end) when the car comes to life on the hard tires as we have seen in the past. Track should be slightly cooler tomorrow and will be more rubbered in.
Max is the only one of the top cars with 2 sets of hard tires, which was the strategy that most used last year.
