Yes, and cost per kg is half.
So where do the problems still lie?
liquid is unlikely
Combustion itself is high temperature, which creates pollutants.Tommy Cookers wrote: ↑24 Apr 2025, 15:44hydrogen may be available as fuel for motor vehicles
there is nothing immutably high temperature about hydrogen combustion
Not really. You need very high temperatures, any waste heat won't do.Tommy Cookers wrote: ↑24 Apr 2025, 14:51not so much if you use the production waste (heat) for co-located industry or other heating
not so if your (windfarm) electricity would otherwise die unborn yet (as now) still be charged to the (non) consumer
We were talking automotive applications. Combusting hydrogens just wastes a lot more of it.Tommy Cookers wrote: ↑24 Apr 2025, 15:44decarbonisation of steel making (ie iron smelting) is the burning of hydrogen
decarbonisation of fertiliser making is by the use of hydrogen
these would eliminate 10% of global carbon emissions
A practical and economic hydrogen achitecture/infrastructire is fantasy. I see more potential for success in some sort of bio/synthetic fuel. Utilizing some agricultural waste and used for niches where batteries are not viable because of weight. But even that with fuel cells.ispano6 wrote: ↑24 Apr 2025, 08:52You can call it fantasy. I call it vision. Have you even researched blue and green hydrogen and ammonia? It's a byproduct we generate already.
Your description of understanding of hydrogen seems archaic to me.
Here's an AI summary for you:
A hydrogen-fueled rotary engine (HRE) is a type of internal combustion engine that utilizes hydrogen as fuel, offering potential advantages like lower emissions and higher power density compared to gasoline engines. Rotary engines, particularly Wankel engines, are well-suited for hydrogen because their design features separate intake and combustion chambers, which can mitigate backfire issues often associated with hydrogen in piston engines.
Hydrogen is often referred to as the "fuel of the future". It's a clean-burning energy source that produces water vapor as a byproduct, unlike fossil fuels which release greenhouse gases. Hydrogen can be produced from various sources, including water, and used to power vehicles, generate electricity, and even heat homes.
There's a ton more research articles you can find from AI search.
I would have a K in there, so all of the excess recovered energy can be used. It would be small and light. I imagine it could fully replace the rear brakes. Preferably with little or no weight penalty..poz wrote: ↑24 Apr 2025, 14:04The electric compressor is to have zero turbo lag and mostly to greenwash the engine so Honda, Mercedes etc are happy
V6 is for sound and for Ferrari (originally the actual ICE project was a 4 cylinder in line, Ferrari asked for V6)
an electric turbo can work at 48v, so you don't need high voltage cables and is al lot lighter than a kers
Note that it would have remained a 4 cylinder had VAG committed to F1 back then.mzso wrote: ↑29 Apr 2025, 00:09I would have a K in there, so all of the excess recovered energy can be used. It would be small and light. I imagine it could fully replace the rear brakes. Preferably with little or no weight penalty..poz wrote: ↑24 Apr 2025, 14:04The electric compressor is to have zero turbo lag and mostly to greenwash the engine so Honda, Mercedes etc are happy
I wonder what would the straight four formula would have been like. Would it have been better in some regards than what we got? (I also despide Ferrari's toxic influence)
For Ferrari, a V4 is probably still an option as well: https://www.carandbike.com/news/no-cons ... la-2506392wuzak wrote: ↑29 Apr 2025, 04:54Note that it would have remained a 4 cylinder had VAG committed to F1 back then.mzso wrote: ↑29 Apr 2025, 00:09I would have a K in there, so all of the excess recovered energy can be used. It would be small and light. I imagine it could fully replace the rear brakes. Preferably with little or no weight penalty..poz wrote: ↑24 Apr 2025, 14:04
Also, Ferrari were not alone in asking for a V6 (and only after VAG had dropped out).
that's what was once said about most of the oil and gas that has now been used
