specifically referring to his Q3 runs. Which have not been good enough to do justice to the car, since Australia.
Sorry, this is the first time I’ve heard the front wing is TD compliant.geogate wrote: ↑25 May 2025, 23:17that didnt really sound like something Andrea would say even off the record, but they have been saying for some weeks that the front wing was already new TD compliant to much of the media, including Sky F1, and has been reported as having been said by Ted on the podcast. I dont think they would be quite so unequivocal to the media if it wasn't actually true. According to Ted they have said it had been compliant for several races already.
I am not sure about the MCL39 having a Spain TD compliant wing already, because it does seem to flex more than RB & Ferrari and they have both said they're bringing new wings for Spain, however the MCL39 appears to have quite a bit less flex than the MCL38 last year.CjC wrote: ↑25 May 2025, 23:21Sorry, this is the first time I’ve heard the front wing is TD compliant.geogate wrote: ↑25 May 2025, 23:17that didnt really sound like something Andrea would say even off the record, but they have been saying for some weeks that the front wing was already new TD compliant to much of the media, including Sky F1, and has been reported as having been said by Ted on the podcast. I dont think they would be quite so unequivocal to the media if it wasn't actually true. According to Ted they have said it had been compliant for several races already.
Last I heard Stella say about it was that only a small change would be required. Have they already made the ‘small change’ and if so… when?
In my opinion, they're close to being compliant with the TD, but not quite with the current wing. So that "small change" Andrea mentioned could simply be a slightly more rigid front wing, but exactly the same philosophy, i.e no change in DF balance, but slightly more drag. They're going to be forced to run with a big front wing anyway and just bite the bullet when it comes to whatever extra drag they have to deal with. As it has been pointed out by Vanja before, McLaren's front wing needs to be big, because their floor doesn't generate the same front-end downforce as the others. It's part of the concept.Emag wrote: ↑27 Feb 2025, 00:24https://i.imgur.com/INxZJbc.jpeg
It seems like there's less flex on the MCL39's front wing, but I can't be certain if it's due to the slightly different onboard angles or not. But even when looking at the onboard videos (not static images like these) of the MCL39, the flap movement doesn't seem as dramatic on the braking zone as it was with the MCL38.
Hopefully i got time stamp rightCjC wrote: ↑25 May 2025, 23:21Sorry, this is the first time I’ve heard the front wing is TD compliant.geogate wrote: ↑25 May 2025, 23:17that didnt really sound like something Andrea would say even off the record, but they have been saying for some weeks that the front wing was already new TD compliant to much of the media, including Sky F1, and has been reported as having been said by Ted on the podcast. I dont think they would be quite so unequivocal to the media if it wasn't actually true. According to Ted they have said it had been compliant for several races already.
Do you know if the current (start of the season) MCL39 wouldn’t pass the test as intended for Spain? If it indeed passes the test as is (as per McLaren), then there is no favours been thrown around… There is a narrative created by one team to deflect attention from their own struggles that has been eaten not only by the media, but also by a large population of the F1 audience…venkyhere wrote: ↑25 May 2025, 23:36FIA did a big favour to McLaren by 'allowing' (not increasing the flexi test loads) the flexi wings till end of 2024 ; and then further by not enforcing it until race 9 of 2025. What's the explanation for so much 'leeway' with wing flexing ? When other TDs have been enforced like a hammer in a short span of time ?
Interesting.geogate wrote: ↑26 May 2025, 00:17Hopefully i got time stamp rightCjC wrote: ↑25 May 2025, 23:21Sorry, this is the first time I’ve heard the front wing is TD compliant.geogate wrote: ↑25 May 2025, 23:17that didnt really sound like something Andrea would say even off the record, but they have been saying for some weeks that the front wing was already new TD compliant to much of the media, including Sky F1, and has been reported as having been said by Ted on the podcast. I dont think they would be quite so unequivocal to the media if it wasn't actually true. According to Ted they have said it had been compliant for several races already.
My recollection was that they said they voluntarily agreed to make a minor change to the rear wing last year
Ah that's right but I am not so convinced it was voluntary etc the FIA did come up with a tightening of the rules.
Yes, that would be about right to me, which I tend to think was a case of their hand was really forced if the FIA said its within the rules/load tests its okay then I very much doubt they choose to get rid of it.mwillems wrote: ↑26 May 2025, 02:39If I recall correctly, Mclaren did offer to make changes but if they didn't, the FIA would have mandated them.
Regarding the front wing, during testing Stella was quoted as saying they would bring FW changes to Spain, but that they are minor and wouldn't make much of a difference.
They've said several times it won't make a difference or be a big change since. Can't see a reason to doubt them.
Thank you. You nailed the stamp too.geogate wrote: ↑26 May 2025, 00:17Hopefully i got time stamp rightCjC wrote: ↑25 May 2025, 23:21Sorry, this is the first time I’ve heard the front wing is TD compliant.geogate wrote: ↑25 May 2025, 23:17that didnt really sound like something Andrea would say even off the record, but they have been saying for some weeks that the front wing was already new TD compliant to much of the media, including Sky F1, and has been reported as having been said by Ted on the podcast. I dont think they would be quite so unequivocal to the media if it wasn't actually true. According to Ted they have said it had been compliant for several races already.
