Flexiwings 2025
SiLo
144
Re: Flexiwings 2025
101FlyingDutchman wrote:
27 May 2025, 10:42
Jurgen von Diaz wrote:
27 May 2025, 10:06
So, was it Barcelona where the flexi-wings were banned? Is it going to hit hard for McLaren?
Yes and no
We won't know until Barcelona to be honest.
Felipe Baby!
Re: Flexiwings 2025
All teams will lose something. There is a tradeoff between straight line speed and wing downforce at minimum. If you just make the parts stiffer, you'll be slower on the straights. If you make the new wing less loaded, you lose load in the corners. Then there can also be more complex effects. Aero balance could be disrupted. That can cause more slip and tire wear. It can also make the car more difficult to drive.
Beware of T-Rex
Rikhart
Rikhart
38
Re: Flexiwings 2025
SiLo wrote:
27 May 2025, 15:55
27 May 2025, 10:42
27 May 2025, 10:06
Yes and no
Exactly this. And you can already at least theorize, looking at the videos above, that teams with these spaghetti wings will be indeed hit quite hard. We already had some hints, courtesy of Mercedes.
SiLo
144
Re: Flexiwings 2025
Rikhart wrote:
27 May 2025, 17:44
SiLo wrote:
27 May 2025, 15:55
27 May 2025, 10:42
Yes and no
Depends if those wings are already able to pass the new tests.
Felipe Baby!
Gaara
Gaara
Re: Flexiwings 2025
What are the new rules considering the flexi wings? I can only say people talking about it. But what are they?
Re: Flexiwings 2025
Gaara wrote:
27 May 2025, 17:58
Note the language highlighted in pink.
Beware of T-Rex
Seanspeed
Seanspeed
Re: Flexiwings 2025
Said it before, but back in 2011-2013 the FIA was frequently chasing down Red Bull's flexi wings with harsher load tests and they never made any difference at all. Red Bull found a way to keep passing the tests with their wings still noticeably flexing on-track beyond what was intended, and the competitive picture never changed. Heck, Red Bull ended that set of regulations more dominant than ever.
So I'm still quite dubious this will have any notable effect on the competition when it's only being regulated by static load testing.
vorticism
vorticism
449
Re: Flexiwings 2025
27 May 2025, 18:44
Are the "From 28 May 2025 onwards" items the same thing as TD018?
I wonder if we'll see a see a return of inboard flap adjusters. Edit- it was the Williams that had inboard flap adjusters in '22, not RB. If the FIA want to limit flap deflection, demanding that the adjuster be placed inboard could help with that.
Re: Flexiwings 2025
vorticism wrote:
28 May 2025, 03:25
Yes.
Beware of T-Rex
vorticism
vorticism
449
Re: Flexiwings 2025
Thanks. Have there been any explanations of the 28 May date? And not setting it for, say, 28 April, or 28 March, or 28 February...
Watto
Watto
Re: Flexiwings 2025
vorticism wrote:
28 May 2025, 03:56
Believe the explanation is the time it takes to design validate and produce a front wing was 6 months?
I tend to things it's BS if they failed an inspection post race I think you could bet your bottom dollar they would come up with at least a temporary solution before the next race.
SiLo
144
Re: Flexiwings 2025
60N doesn't seem like a lot of force for a wing?
Felipe Baby!
F1NAC
173
Re: Flexiwings 2025
SiLo wrote:
28 May 2025, 11:08
It's a load on a trailing edge of a flap. Based on it's size and thickness it it something
Re: Flexiwings 2025
Seanspeed wrote:
27 May 2025, 18:50
Mercedes have made a TD compliant wing and it is visibly much stiffer, but anything is possible. Mclaren may be able to figure out how to undermine the new test better than Mercedes did or Mclaren could develop in a different direction to have a faster car without the wing.
Beware of T-Rex
bluechris
Re: Flexiwings 2025
28 May 2025, 18:05
Seanspeed wrote:
27 May 2025, 18:50
And we all saw how good they were in Monaco.
Some how people believe that suddenly McLaren after so many years with nothing, they became magicians and aero Guru's.
