Mercedes W16
SB15
SB15
Re: Mercedes W16
vorticism wrote:
21 May 2025, 03:03
The shape of the inlet plenum has changed compared to what was seen in Nobu’s photos from Suzuka. Notice the shape of the door (highlight by AR3) has changed, also the expansion angle downward, and the now-shorter height of the forward region, and the undercut as well. The shape of the inlet mouth itself doesn't seem to have changed though, it looks the same in all of the pictures I've seen of the W16 in Imola. Main shark-mouth inlet + full height vertical slit, same as all year. Which implies there is now a steep upward slope within the vertical slit section of the plenum, to meet this now shorter neck region of the plenum.
Suzuka:
Lasssept wrote:
03 Apr 2025, 17:38
https://pbs.twimg.com/media/GnnkcxYbsAA ... =4096x4096
NOBU @n_mode_log
Look at how further rearwards the inlet is, matter of fact, the radiators within the package are very slinder.
I don’t know about you but the team can very easily bring back the W14’s mid-wing design as well as doing a hybrid with the W14’s sidepod inlet design from launch and Monaco spec inlet from 2023.
vorticism
vorticism
449
Re: Mercedes W16
SB15 wrote:
21 May 2025, 13:25
Note the opening in the more recent photo is from the plenum being in a state of disassembly. The old plenum also probably had a split in the same area, just behind the side impact structure. A vertical seam can be seen in the same region in the older photo, which is another good point of reference illustrating how much the height of that seam has changed. Yeah, the water radiators are slim, especially compared to RB's air-air intercoolers. Mclaren with the same power unit will have similarly compact radiators and this is one thing helping them to have thinner wide sidepods.
Also it seems that the W16 has a carat ">" shaped radiator assembly, with a smaller radiator located below the main radiators, just out of view. Would explain why the plenum body is so tall--why it dips so far below the main radiators. RB20 also had this carat arrangement, as well as a few other cars longer ago.
Re: Mercedes W16
From Imola by Xavier Gàzquez
Lasssept
126
Re: Mercedes W16
Monaco
@Fabrega
Re: Mercedes W16
Seems like Mercedes is trying to get more interaction between the rear wing/beam wing and the rear brake duct exit. The exit duct aims heavily inboard which is different to many other teams. Perhaps wanting to use the rear wing and beam wing to help reduce the exit pressure of the brake duct (increasing flow through the duct)
Beware of T-Rex
Lasssept
126
Re: Mercedes W16
@robertofunoat|@RmcMotori
Lasssept
126
Re: Mercedes W16
Autoracer
SB15
SB15
Re: Mercedes W16
As I predicted, Mercedes brung the older rear suspension design to Monaco and to be fair that is smart because it works tremendously good.
Lasssept
126
Re: Mercedes W16
Spain
@SalaStampRacing
Lasssept
126
Re: Mercedes W16
Spain
@SalaStampRacing
Lasssept
126
Re: Mercedes W16
@SalaStampRacing
Re: Mercedes W16
Lasssept wrote:
29 May 2025, 23:16
old/new ? :-k
https://i.postimg.cc/pdpt9mHS/Screenshot-4525.png
Imola
There are many more teeth on the floor edge in the photos from Spain. So new floor for Mercedes.
Beware of T-Rex
SB15
SB15
Re: Mercedes W16
29 May 2025, 23:20
Could be just the floor edge but, HOLY!
THAT'S ALOT :shock:
Lasssept
126
Re: Mercedes W16
Autoracer
Lasssept
126
Re: Mercedes W16
Xavi Gazquez / Vanja H
