2025 Scuderia Ferrari F1 Team
j_ste
j_ste
Re: 2025 Scuderia Ferrari F1 Team
The understeer at turn 5 is laughable.
Xyz22
Xyz22
124
We are very slow as expected.
Norris lapping in high 18 with the second set :lol:
mkay
mkay
16
Wasn't Ferrari meant to introduce a large upgrade package in Barcelona?
Xyz22
Xyz22
124
mkay wrote:
30 May 2025, 18:01
No. Also nothing will save this car (and by save i mean good enough to win).
Luscion
Luscion
119
mkay wrote:
30 May 2025, 18:01
that was scrapped a while ago due to their rear suspension issues, new floor in either canada or austria and the new rear suspension in silverstone.
Fakepivot
Fakepivot
Charles complained he had lot of marble on the Tyre which later effected the hole stint, not sure his medium or the soft.. but even in outlap Charles complained his medium were done. so can't really get much from that data.
cliffgamerz
cliffgamerz
Xyz22 wrote:
30 May 2025, 18:03
mkay wrote:
30 May 2025, 18:01
I think it's time they drop the development on this car and focus fully on 26 from now on, i still think they might hang onto P3 in constructors at the end of this year if Tsunoda struggles and Max has some bad races, but expecting anything more is a miracle.
Xyz22
Xyz22
124
cliffgamerz wrote:
30 May 2025, 18:06
Xyz22 wrote:
30 May 2025, 18:03
mkay wrote:
30 May 2025, 18:01
They just redirected the already allocated resources for aero development to this new suspension (will it work? I'm not so sure knowing Ferrari. Touching a suspension is critical so...). I would have stopped SF 25 development immediately because clearly the WDC and WCC are completely impossible to achieve (which was the goal of the season), but Ferrari is run by incompetents so yeah...
dialtone
dialtone
122
I'm obviously wrong because I appear to be the only one not confident enough to be able to run an F1 team, but the race pace times look pretty decent.
LEC/HAM came out 8-9 laps after VER to do their race sim, and particularly on the softs the times were comparable to RBR.
Merc did a long stint on the softs, probably to try and check a 1 pit stop strategy doing S-M, their times are a bit slow but mostly because of this.
MCL is just faster than the rest on either a 1 stop or a 2 stop.
Call me whatever you want but from FP2 times and setups, apart from MCL it looks pretty close across the top.
Xyz22
Xyz22
124
dialtone wrote:
30 May 2025, 18:29
I would be a terrible TP as well, don't get me wrong.
I said that Ferrari is run by incompetents, which is something backed by lack of results in the last i don't know how many years. When you account the resources they have, the drivers they clearly unperformed massively, which means something is wrong somewhere.
I also said that I would have stopped SF 25 development, which again is something that smart people like James Vowles are already doing with their teams and rightfully so because they know they won't win anything this year.
SB15
SB15
dialtone wrote:
30 May 2025, 18:29
Piastri is the outlier because he was running at the same pace as the Mercedes 1:20.8 - 1:20.9 on average. So, Mclaren were running a very aggressive long run program once again with Norris just to see how the tyres hold up.
dialtone
dialtone
122
SB15 wrote: Piastri is the outlier because he was running at the same pace as the Mercedes 1:20.8 - 1:20.9 on average. So, Mclaren were running a very aggressive long run program once again with Norris just to see how the tyres hold up.
Right, I think PIA was running a 1 stop sim, while NOR was the opposite.
MCL sort of gives the range of what it would mean to save the tires vs not.
Fakepivot
Fakepivot
Charles was bit ahead of max until turn 7 and 9 mistake, even against Oscar they were similar until that part. I guess in this track once you ruined your push lap there no 2nd, so each driver must make first lap count.
Not the end of the world, certainly for some people here it is but take a brake come back next year.
evered7
evered7
FP2 race pace was more in line with Sauber/VCARB than any of the lead cars.LH and Hulk listed next to each other had barely a tenth or 2 between them lap after lap.
Leclerc could've has a better soft tires lap if the mistake in sector two wasn't there.
Car still needs to be fixed. Nothing has changed for Ferrari. Bald guy lies will die soon. Nowhere to hide.
f1316
f1316
84
Xyz22 wrote:
30 May 2025, 18:09
cliffgamerz wrote:
30 May 2025, 18:06
Xyz22 wrote:
30 May 2025, 18:03
I think they need to confirm that they understood the mistake and can fix it - if not, they risk a repeat (and yes, I know, it’s not the first misstep over the past few years but they still need to correct each one to continue to learn). I doubt there’ll be much, if any, development on the 25 car after the new suspension arrives though, irrespective of how successful it is.
