Red Bull RB21
euv2
euv2
Re: Red Bull RB21
29 May 2025, 20:33
29 May 2025, 20:28
I think this is a new rear wing for Barcelona, not the Monaco one :wtf:
The infamous RB cutout behind the DRS actuator is gone.
https://i.postimg.cc/281zxS3h/image.png
Correct yea
Here's supposedly the "new" directive-legal front wing. I spent about 2mins looking for geometry/connection differences but couldn't see anything. Maybe this is still the old spec idk.
📸 Alessandro Sala
https://i.imgur.com/gEteBzI.jpeg
https://i.imgur.com/DyFwtMW.jpeg
https://i.imgur.com/vh13Q4I.jpeg
Yeah, even the carbon fibre weave looks to be the same, whereas on the MCL and FER front wings it has changed.
f1isgood
f1isgood
Re: Red Bull RB21
29 May 2025, 20:33
29 May 2025, 20:28
Correct yea
📸 Alessandro Sala
The cars in the background don't have a front wing I think? It looks like the same wing was just placed at the front from the initial photos, again due to Allesandro Sala. I don't think there's any change but Vanja will probably notice something that I didn't even know :)
Call a spade, a spade.
Re: Red Bull RB21
Why would they put the new rear wing on the car, but then put dummy front wings on the car? What would be the purpose? New parts can have a different weight distribution which affects the setup of the car. I don't see any logic for those wings to not be TD compliant versions.
venkyhere
Re: Red Bull RB21
29 May 2025, 20:33
29 May 2025, 20:28
Correct yea
📸 Alessandro Sala
I think the front wing is brand new too, since the nose tip seems to be less 'duck billed platypus' (like Alpine) and more 'conventionally tapered towards the front'.
Re: Red Bull RB21
venkyhere wrote:
29 May 2025, 22:05
29 May 2025, 20:33
29 May 2025, 20:28
Correct yea
📸 Alessandro Sala
I agree.
Farnborough
Farnborough
125
Re: Red Bull RB21
29 May 2025, 21:52
FP1 could be considered "wind tunnel" time such that they can check old with new for load figures .... ultimately to drive feedback and correlation loop. It's quality real time and application data to support in factory analysis really, if they run with it.
Farnborough
Farnborough
125
Re: Red Bull RB21
21 May 2025, 06:53
Also raced in Imola with different front wings. I assume due to parts shortage from qualifying crash. Higher angle front flap on Verstappen nose, among other things.
https://i.postimg.cc/T3B14zqn/image.png
the Imola MV wing APPEARS to have the lowest element detached from nose structure (unlike Yuki example) which COULD by being less supportive be method of rotating the whole assembly backward to give something in replication of just the top two flaps moving as we've seen on most cars so far this season.
Possibility of having a different load curve in testing regimen application.
venkyhere
Re: Red Bull RB21
Farnborough wrote:
29 May 2025, 22:30
21 May 2025, 06:53
That aside, the letterbox opening between the nose and lowest element is to provide some sort of 'clean air' to the lower tea-tray at the floor entrance, right ?
Re: Red Bull RB21
It's a combination of ideas which they have tested previously. The fat nose cose remains, but evolved with a spoon-less mainplane profile.
Farnborough
Farnborough
125
Re: Red Bull RB21
venkyhere wrote:
29 May 2025, 22:38
Farnborough wrote:
29 May 2025, 22:30
21 May 2025, 06:53
I'm unsure of purpose now as they look to be excluding/controlling floor entry volume by use of strakes at entry to tailor volume and pace at the entrance area.
This slot gap between level one and two (going up from bottom of stack on front wing) SEEMS to feed the "spoon" effect of that first element in producing downforce (from the underside surface) furthermore if it can attract that lower surface to something of a ground effect relationship in generating load at front most extreme of chassis.
The Centre appearing more useful,as the outer reaches of wing are more focused on outwash management for front tire mitigation.
Re: Red Bull RB21
I'm not sure that Red Bull's front wing is different. It still has the spoon.
Spain:
Imola:
Re: Red Bull RB21
Brahmal
Brahmal
27
Re: Red Bull RB21
venkyhere wrote:
29 May 2025, 22:38
Possibly, but the main purpose is probably to control the amount of ground effect the front wing generates. Running the nose all the way to the first element will increase the surface area on the bottom of the wing that will generate suction as it gets closer to the ground.
You will also notice that some cars have their second wing element meet the end-plate about half-way down it's length (Red Bull) whereas others have the second element curve all the way to the corner of the end-plate in front of the wheels. This decision, in addition to changing the outwash characteristics of that end-plate corner, will also change the surface area underneath the first element and how much ground effect it generates.
Cs98
Cs98
Re: Red Bull RB21
Looks like the Verstappen wing is actually a completely new design. I previously thought it was the same as the Tsunoda wing (old) with a new upper element, but it's not. Here we can clearly see it's a new medium downforce wing (Tsunoda medium-high), more optimised for top speed with DRS closed.Image
This wing will be a strong option for all 4 upcoming races. Spain, Canada, Austria, Silverstone.
Re: Red Bull RB21
Cs98 wrote:
01 Jun 2025, 13:41
Looks like the Verstappen wing is actually a completely new design. I previously thought it was the same as the Tsunoda wing (old) with a new upper element, but it's not. Here we can clearly see it's a new medium downforce wing (Tsunoda medium-high), more optimised for top speed with DRS closed.https://autogear.pt/wp-content/smush-we ... d.jpg.webp
https://www.grandprix247.com/wp-content ... a-2025.jpg
Very hard to see, but it seems that the nosebox is narrower.
