it's definitely a very unusual approach to run only softs on Friday, and not one he'd go for without reason, I think.
Running mediums in Quali was an advantage in Imola already, and they certainly looked good for Russell and Albon today.
Teams have access to 13 sets of tires:
I think the mediums definitely look like the better qualifying tire and then they can combine that with a hard for the race
Was it really bad luck or a further example of bad judgement? There wasn't a need to take such a risk that early into the session.Otromundo wrote: ↑14 Jun 2025, 00:07Lance has had bad luck. Fernando seems happy, and his P2 time seems good to me. The mediums seem much better than the softs.
I've been looking into the dust because I found it curious. Apparently, the wildfires have left a lot of dust suspended in the area. I thought it was sand dust. I suppose it will improve if it's more ash than sand.
I'll check to see if I can find the updates/modifications AM has planned for this race.
Assuming ALO uses 2 more softs in FP3. It becomes critical to get through to Q2 in quali with 1 set of softs (which has not been the case this year) so that he can keep 1 new MED set for race.diffuser wrote: ↑14 Jun 2025, 00:02Teams have access to 13 sets of tires:
2 x Hard
3 x Medium
8 x Soft
The other thing is , the Tires Here are C6, C5 and C4(Hard) instead of C5,C4 and C3(hard) from last year. So the Mediums are the softs from last year and the Hard the Mediums from last year.
Interesting thought. Keep the 2 hards for the race. Use 1set of soft plus 3 sets of mediums for quali. Start race on the least used set of mediums used in quali with 2 more stints on Hard.vas_04614 wrote: ↑14 Jun 2025, 03:18Assuming ALO uses 2 more softs in FP3. It becomes critical to get through to Q2 in quali with 1 set of softs (which has not been the case this year) so that he can keep 1 new MED set for race.
You get a 14th set of tires if you make it into Q3, has to be softs.-wkst- wrote: ↑14 Jun 2025, 14:23ALO can save all hards and mediums and use 2 more softs in FP3, that leaves him with 2 set of softs for Q, but 1 set is reserved for Q3. Realistically he starts Q1 with the soft set, followed by a medium set. 2 set mediums in Q2 and the 2nd soft set in Q3 again, unless he can save a set of mediums, abandoning a lap at the end of Q1 or Q2. Don’t think they will save a set of mediums for the race.
2nd option is a one-stopper, in that case he will use one set hards in FP3 and has a third set softs in Q.
No, it's how -wkst- said:diffuser wrote: ↑14 Jun 2025, 15:08You get a 14th set of tires if you make it into Q3, has to be softs.-wkst- wrote: ↑14 Jun 2025, 14:23ALO can save all hards and mediums and use 2 more softs in FP3, that leaves him with 2 set of softs for Q, but 1 set is reserved for Q3. Realistically he starts Q1 with the soft set, followed by a medium set. 2 set mediums in Q2 and the 2nd soft set in Q3 again, unless he can save a set of mediums, abandoning a lap at the end of Q1 or Q2. Don’t think they will save a set of mediums for the race.
i) From the thirteen (13) sets of dry-weather tyres allocated to each driver under Article
30.2a)ii):
i) One (1) set of the mandatory Q3 tyre specification may not be used nor returned
before Q3 and, for the cars that qualified for Q3, one set of the same specification
must be electronically returned no later than the covers-on time defined in Article
40.6.
Thanks for the correctionkarana wrote: ↑14 Jun 2025, 15:42No, it's how -wkst- said:diffuser wrote: ↑14 Jun 2025, 15:08You get a 14th set of tires if you make it into Q3, has to be softs.-wkst- wrote: ↑14 Jun 2025, 14:23ALO can save all hards and mediums and use 2 more softs in FP3, that leaves him with 2 set of softs for Q, but 1 set is reserved for Q3. Realistically he starts Q1 with the soft set, followed by a medium set. 2 set mediums in Q2 and the 2nd soft set in Q3 again, unless he can save a set of mediums, abandoning a lap at the end of Q1 or Q2. Don’t think they will save a set of mediums for the race.
30.2a)ii):
40.6.
