2025 Scuderia Ferrari F1 Team
K1Plus
K1Plus
Re: 2025 Scuderia Ferrari F1 Team
Luscion wrote:
04 Jul 2025, 21:02
according to motorsport.it Ferrari can finally run the car lower and with more consistant load generated because of the new floor, Silverstone also being smooth and front limited is helping them as well.
https://it.motorsport.com/f1/news/f1-la ... /10739278/
And if the new suspension helps us... 2nd half of the season is gonna be fun.
When I say us, I mean as a Ferrari fan.
FDD wrote:
04 Jul 2025, 16:01
Which Byrne's advice he ignored?
When you say "not up to the task of deciding suspension concept and performance targets", you mean in general or specifically for the front axle?
Advice on rear suspension layout and I guess performance targets too. I meant in general about Cardille, not just front or rear
DJ Downforce
Vanja #66 wrote:
04 Jul 2025, 22:40
FDD wrote:
04 Jul 2025, 16:01
Vanja, is it your understanding that the new floor has allowed them to run a little lower, as was reported my It Motorsport?
ScuderiaLeo
DJ Downforce wrote:
04 Jul 2025, 22:44
Federico seems to believe so too
Rare to see him so optimistic without a caveat at the end. Seems like the consensus is good, let's hope they can put it together tomorrow
deadhead
70
They are running the car closer to whatever they intended so it's working.
Track conditions are the only thing that might hamper them in quali
Cemzz
Cemzz
Does anyone know how the weather conditions affect Ferrari?
We know Mercedes favours the colder weather. McLaren seems to have an advantage in hot weather. What about ferrari? Are we better off having cooler conditions to look after the tyres? Or warmer conditions to get the tyres into operating range quicker in qualy?
venkyhere
I too noticed how low (similar to others) it was running, in FP2. In my mind, the new floor has reduced peak loading => rear suspension softness doesn't smash the plank => no need to raise ride height => more overall downforce at all speed ranges
atanatizante
125
venkyhere wrote:
05 Jul 2025, 06:19
https://postimages.org/
As you could hopefully see in the above picture, it seems that, at least in the first part in the FP2 session, both cars were bouncing and maybe the ride height was raised after, bearing in mind the wear plank checks...
Jesus
DJ Downforce wrote:
04 Jul 2025, 22:44
Not really, it allowed them to run higher and at different ride height change rate in the rear so they can setup the car according to plank wear limits
What allows them to run lower in Silverstone is good and flat track surface, but this is the same for everyone
deadhead
70
Looking great considering how wrong they usually are
Fakepivot
Fakepivot
think they are still using brakes to heat up, i guess we still going see our old friend " Lico "
Vinlarr89
Vinlarr89
Hello “LiCo” my old friend….
CjC
CjC
LiCo won’t effect the pole laps
Just a fan's point of view
r85
r85
Fakepivot wrote:
05 Jul 2025, 13:12
LiCo would be used for plank wear issues in Silverstone, not brake cooling. But seeing that they're competitive today could mean that they didn't have to raise the car like they did in the past.
dialtone
dialtone
123
r85 wrote:
Fakepivot wrote:
05 Jul 2025, 13:12
Plank wears during high load corners when the car rolls or as they attack kerbs coming out of corners. They do not wear because you go straight, LiCo is not about plank, it’s about tires, brakes, fuel savings.
