gruntguru
gruntguru
569
mzso wrote:
03 Aug 2025, 21:56
Just thought of something. Is it possible to replace the MGU-H with a flywheel, maybe even a mechanical one?
Do the regulations ban this?
Going further, is using the exhaust this way to store and deploy power banned?
By the way. What did they add to the regs to ban so called "split turbos"? How long can turbos be?
Flywheel has been done in the early days of regen. Don't know if the current regs permit but it wouldn't compete with MGUK plus Li battery on energy density.
650
mzso wrote:
03 Aug 2025, 21:56
.. Is it possible to replace the MGU-H with a flywheel, maybe even a mechanical one?
imo 'everybody knew' it was banned wef 2013/2014 ie the current rules
the Williams CVT/flywheel group (Williams Hybrid Power) were then sold in 2014 to GKN
https://www.imeche.org/news-article/wil ... n-010414-2
another https://www.racecar-engineering.com/art ... tems-kers/
mzso
mzso
68
gruntguru wrote:
04 Aug 2025, 02:39
When I said "replace" I thought of a flywheel for the turbo to combat turbo-lag.
Tommy Cookers wrote:
04 Aug 2025, 11:24
banned wef 2012/2013
to keep out Williams
Typical... Is it banned for drive only, or universally?
Holm86
252
mzso wrote:
03 Aug 2025, 21:56
Referring to Drawing 4 of Appendix C3, the turbocharger compressor and turbine must satisfy the
following dimensional constraints. Only compressor and turbine wheels approved by the FIA
Technical Department will be allowed:
a. The compressor exducer blade outer diameter (A) must lie between 100mm and 110mm. For
the avoidance of doubt, no part of the compressor wheel (including blades, hub and any
blade/hub fillet radius) can have a diameter more than the upper limit and the maximum
diameter of the compressor wheel (including blades, hub and any blade/hub fillet radius)
cannot have a diameter smaller than the lower limit.
b. The compressor axial distance from the outside diameter of the inducer blade edge to rear
plane of exducer, at its outer diameter (B) must lie between 30mm and 35mm
c.
The turbine inducer blade outer diameter (C) must lie between 90mm and 100mm. For the
avoidance of doubt, no part of the turbine wheel (including blades, hub and any blade/hub fillet
radius) can have a diameter more than the upper limit and the maximum diameter of the
turbine wheel (including blades, hub and any blade/hub fillet radius) cannot have a diameter
d. The turbine axial distance from the outside diameter of the exducer blade edge to forward
plane of inducer, at its outer diameter (D) must lie between 35mm and 40mm
e.
The maximum distance between the rear of the compressor exducer and the front of the
turbine inducer (E) will be 175mm
mzso
mzso
68
Wow, reading something like this makes me think F1 should be renamed to Prescription 1.
wuzak
wuzak
475
mzso wrote:
06 Aug 2025, 15:51
It's almost like it is a formula of rules.
vorticism wrote:
14 Jul 2025, 00:28
“It’s just a bit of a shame we’re just – Formula 1’s just – taking that path of electric energy and we’ve had to shed all the downforce off the cars to support the battery power,” he said. “It should be fun to see some light, nimble, fast cars with a lot of downforce and just simplify the whole thing a little bit. Less so of an energy, battery, championship, science project and more of just a Formula 1 racing championship.”
What you think is a problem with the regs have nothing to do with electricity. It's just a choice they made on how to implement the regs. They didn't have to remove the MGU-H, they didn't have to ban regenerative braking on the front, they didn't have to limit regeneration per lap as low as it is now, and they didn't have to prevent using MGU-K while on throttle. They did all this cause this is what they wanted to do, under the gise of carbon neutrality. It wasn't the only route to "carbon neutrality". The 2026 regs is a choice by F1. I have my doubts about how exciting the regs will be but since I can't change them, I'll wait to see how they playout before criticizing.
vorticism
vorticism
340
diffuser wrote:
09 Aug 2025, 05:18
vorticism wrote:
14 Jul 2025, 00:28
Are you replying to me or to Stroll?
mzso
mzso
68
wuzak wrote:
09 Aug 2025, 04:03
mzso wrote:
06 Aug 2025, 15:51
It's almost like blueprint, you mean.
It was a formula even when there was hardly more than a displacement limit and a weight limit for cars.
