2025 Scuderia Ferrari F1 Team
Waz
Waz
Re: 2025 Scuderia Ferrari F1 Team
yooogurt wrote:
13 Aug 2025, 21:59
Hammerfist wrote:
13 Aug 2025, 18:59
That would be wild. With the mclarens around them you’d think they would expect plenty of clean air. Mclaren was expected to pull away from them if not at the start but at the pit stops with an undercut. Sorry but I’ve heard all sort of theories I just don’t buy this one at all.
Driving in clean air behind the McLarens and in front of them are two different things. In the first case, you can slow down, use lico and other methods to protect the plank. In the second, you have to drive at full speed.
ps.
Still doesn't make sense. There isn't a constant amount of turbulent air at the level of being right behind another car. It would have been the same for Charles if Oscar had got ahead and pulled a 5+ second gap.
And I don't believe parc ferme applies to tire pressure, which is set on the grid. Easy enough to adjust for the swing in temperature.
ScuderiaLeo
Waz wrote:
14 Aug 2025, 17:04
Someone can correct me if I'm wrong but I believe what they're saying is that the team just made a mistake when choosing tire pressures mid-race. The AR article said Ferrari had low correlation across the weekend so a larger swing in temperature means even more chance for them to make an error (because it's an even further deviation from what they'd planned for.)
dialtone
dialtone
122
ScuderiaLeo wrote:
Waz wrote:
14 Aug 2025, 17:04
Everyone had bad correlation that weekend, not just Ferrari. MCL was 0.5+ ahead of everyone before Q3, then they are back in line. 1.5psi is just not enough to unsettle a car to that degree, there have been races with 2+ psi changes from day to day, just look at post 2021 Baku when Max tire exploded.
Pretty simply they don’t really know the car they are dealing with, more so than others. The window of this car is shockingly small, and when it’s out of window it’s a very steep cliff. When it’s in window it’s close to MCL, even with the plank wear issue. As the article states the chassis and suspension platform isn’t built to work with this aero platform well enough.
deadhead
72
dialtone wrote:
14 Aug 2025, 20:50
been the case since TD039
Fakepivot
Fakepivot
why does everyone point towards TD039? imo they should have switched to downslope side pod in 2023 starting year itself, imagine if first sf24 was introduced in 2023 they would have more to learn about new concept and maybe could have been stronger this year
Emag
Emag
Fakepivot wrote:
15 Aug 2025, 21:24
I think 2023 was a massive failure by Ferrari too. As far as I remember, they tried some extreme fix for the 2022 car’s weaknesses and ended up creating something that was draggy, hard to set up and still not kind on the tyres. The SF23, in hindsight, looks like a confused design direction. It's not a clear evolution of the F1-75 and it is also not really a step toward what became the SF24.
A lackluster car which had a narrow operating window and obviously never really offered a strong development path considering it was scrapped. It was only the second year of the new regulations and I guess Ferrari were set on doing things their own way, since back then there was no obvious “superior” solution. Flash forward to 2025 and pretty much all cars have converged sidepod-wise, so there is definitely a correct way of doing things in this regulation cycle and Red Bull managed to crack it right from the start. With hindsight, of course it would have been better for Ferrari to have gone the SF24 route with the SF23. But you have to consider their position at the time. They were taking risks, because they wanted to beat RedBull. Unfortunately, didn't work out.
Developer of F1InsightsHub
Andi76
Andi76
451
I think Ferrari generally has a fundamental problem with the car, which is "built-in." Either the entire suspension and springing are not stiff enough,
or even the chassis (the stiffness of the chassis is unfortunately often not taken into account, but it is extremely important). I personally think Ferrari has a problem with the stiffness of the chassis. This causes the floor to bend down under load, especially when the tank is full, in fast corners or on uneven surfaces. This means more
bottoming down, more sparks and ultimately -->wear on the planks.
Added to this are tire wear (which lowers the rear), thermal effects, and the usual bumps. Then you have a car that scrapes the ground, even if it looked good on paper before the race, and then what happened in Hungary happens, and you generally have to make big compromises everywhere. Whats basically the story of the SF25. The chassis' lack of stiffness explains everything that has happened to Ferrari this year.
Xyz22
Xyz22
124
Emag wrote:
16 Aug 2025, 18:07
Fakepivot wrote:
15 Aug 2025, 21:24
The SF 23 was a colossal disaster. Awful car.
catent
Xyz22 wrote:
16 Aug 2025, 21:19
Emag wrote:
16 Aug 2025, 18:07
Fakepivot wrote:
15 Aug 2025, 21:24
A "colossal disaster" of a car which managed 9 podiums, 1 win, and finished 3rd in the WCC (3 points behind the 2nd place team).
Goes to show that expectations are everything when it comes to forming subjective opinions about the team's success (or lack thereof).
Ferrari's 2023 performance - while perhaps disappointing in the sense they fell short of their goals of competing for a WDC and WCC - did not constitute a "colossal disaster". Yet, we still get such comments, since expectation very much colors perception. Everything is relative, I suppose.
