2026 Aerodynamic & Chassis Regulations
lio007
327
Re: 2026 Aerodynamic & Chassis Regulations
Some teams play the secret game: interview with Tombazis
https://www.auto-motor-und-sport.de/for ... rview-fia/
About 2026 in general:
Not all teams and engine manufacturers are equally transparent with their data. Some are quite secretive about what they do. Others are very open and support us with suggestions.
About lap time:
To be fair, I have to admit that we haven't received data from all teams about the expected downforce of their cars.
michl420
michl420
In this regulation, is there a chance that we can get DRS away? I would suggest they should try it for 3 or 4 races in a row and than see if the drivers had learned to overtake again.
670
I thought the 2026 cars were to be in a low-drag mode for most of the lap
the fuel (energy) allowed being far less than in 2025
or has this target been abandoned ?
Holm86
261
michl420 wrote:
14 Aug 2025, 09:30
There's no DRS in the 2026 regulations
vorticism
vorticism
449
Holm86 wrote:
14 Aug 2025, 15:47
...and it’s being replaced by an “adjuster system” (AS).
Per issue 13:
-There are front wing and rear wing versions of the adjuster system (FWAS & RWAS).
-FW: up to 3 profiles, one or two of the rearmost of which can comprise the FWAS.
-RW: up to 3 profiles, the rearmost of which can comprise the RWAS.
-If using 2 profiles in the FWAS they can rotate along their own axis, with a max deviation of 30 mm for the “Primary Flap” and 60mm for the “Secondary Flap.”
-FWAS flap pivot axis can be angled up to 30 deg from transverse, meaing (I take it) there can be one continuous flap with a 0* axis (like current RW DRS) or one flap per side with up to a 30* axis (like current FW flaps)
-FWAS can have one or two actuators, one centrally with a fairing, or one per side faired with the FW pylons, and be driven electrically (new) or hydraulically
-Two positions like DRS: “corner mode” and “straight-line mode” with a maximum 400 ms transition time.
-There will still be “activation zones” defined by the FIA similar to the current DRS zones--presumably comprising any applicable corners and straights per track.
All told I see one major potential differentiation available across teams: a FWAS that has either one, two, or four rotating flaps. Another less visible one will be the choice to use a hydraulic piston or an electromechanical actuator.
From this section of the regs I’ll leave everyone with a word of the day: fishplate.
lucafo wrote:
13 Aug 2025, 09:46
But, with all that restriction, why do not standardize floor and cockpits? A lot of cost savings on crash test and blinded developments!
That might reduce the cost of a car, but all the teams pride themselves on being constructors. I doubt any of them would want a spec chassis, because it would be at odds with their business plan. They’re aerospace companies, vehicle fabricators, etc. They could become assemblers only, but that would be a downsizing to the point of becoming another type of business venture. They might seek other markets if that occurred, as an alternative to selling their manufacturing infrastructure. Once teams start doing that, they might form a breakaway series...
dren wrote:
12 Aug 2025, 19:50
Thanks again for the sketches and descriptions. I was not expecting the differences at the start of the last set of regulations so I am hoping I am pleasantly surprised once again with this new set, but there doesn't seem to be much wiggle room.
Lots of boxes each with varying amounts of dev potential. We may see a repeat of '22 onward. One team gets it right and the simplicity forced by the regs means they can be quickly emulated. Given that Newey, an artisan who intuitively knows what won't work, has been technical director on the team that got the aero regs right at the start twice in a row ('09 and '22; '17 was an evolution of '09/'14) it stands to reason we may see a repeat of that. A result of these more prescriptive regulations is that it seems to force one optimal solution due the limited amount of geometry that can used, whereas previously you could argue that two or three distinct dev paths could yield competitive results. It only took one season (or less) for teams to start emulating RB's '22 floor philosophy, suspension, sidepods. McLaren are the only one who took all the details in totality and said, "I'll have that, thank you," and took them even farther--now they're on to be WCC champs two seasons in a row.
michl420
michl420
Holm86 wrote:
14 Aug 2025, 15:47
michl420 wrote:
14 Aug 2025, 09:30
Yes, you are right, stupid from me.
I'm so used to DRS that I didn't even think about it.
mzso
mzso
76
michl420 wrote:
15 Aug 2025, 16:44
Holm86 wrote:
14 Aug 2025, 15:47
michl420 wrote:
14 Aug 2025, 09:30
Well, they don't call it DRS anymore, but in actuality we have constant automatic DRS for both wings.
By the way, I wonder will the active aero be disabled in the wet like it is now?
Anyway we'll have push to pass instead. But since I expect following and on-track action to get even worse, I doubt they'll elect to not use it.
mzso wrote:
15 Aug 2025, 18:44
michl420 wrote:
15 Aug 2025, 16:44
Holm86 wrote:
14 Aug 2025, 15:47
The slip stream will be Monza levels of worthless. So that push to pash will be the only way to overtake.
#ReleasetheADUO
Zynerji
112
15 Aug 2025, 19:58
mzso wrote:
15 Aug 2025, 18:44
michl420 wrote:
15 Aug 2025, 16:44
The slip stream will be Monza levels of worthless. So that push to pass will be the only way to overtake.
I'm going into 2026 with the expectation of a total ----show. If any part of the product is just outside of bearable, I will just skip it and let the backlash fall where it may. Then i will simply catch up with Drive to Survive for another try after they implement fixes for 2027.
mzso
mzso
76
15 Aug 2025, 19:58
mzso wrote:
15 Aug 2025, 18:44
michl420 wrote:
15 Aug 2025, 16:44
Provided they can get anywhere near with all the dirty air and more sensitive cars.
mzso wrote:
16 Aug 2025, 13:12
15 Aug 2025, 19:58
mzso wrote:
15 Aug 2025, 18:44
The dirty air should be less than today. The cars will have less downforce and the inverse bargeboards are forcing the car to use the front tire wake instead of sending it out to other cars. If they got rid of the active aero, then we would see the slip stream working again. For now, every car goes into Monza downforce on the straights which means little to no tow. The push to pass will be required unless driver makes mistakes.
#ReleasetheADUO
WardenOfTheNorth
mzso wrote:
16 Aug 2025, 13:12
15 Aug 2025, 19:58
mzso wrote:
15 Aug 2025, 18:44
Every expert says the cars will have less dirty air. More sensitive cars surely mean they’re harder to get the maximum out of, so drivers have more opportunity to make the difference?? Surely that would make for better racing??
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
mzso
mzso
76
16 Aug 2025, 14:31
There's less downforce because they went back to flat floors. So we get more wings that produce more dirty air.
So let's hope the bargeboards work out, and they are able to cancel out and improve on the negative effects of more wings. (And no-one immediately finds a way to shove the front tire wake out the side, like Red Bull did in 2022)
Sure the push-to-pass is a must, I just have doubts whether it will have near enough of an effect. I'm not optimistic.
WardenOfTheNorth wrote:
16 Aug 2025, 16:44
That's the desire anyway. All we can do is hope.
More sensitive cars would mean (in this case) that they are not able to follow as closely, because they are affected more by dirty are and loose more downforce.
If the dirty air expectations fall flat, we can forget on track action... Drivers won't be able to do a thing.
mzso wrote:
16 Aug 2025, 19:18
That's possible. We won't know until Bahrain. I suspect in any case that 2026 will be the best year in terms of dirty air. As teams increase the downforce in 2027 and 2028, then the dirty air will increase again.
#ReleasetheADUO
deadhead
81
Not sure if this is someone that already posts here
