Sub 2lt NA V8? God no…vorticism wrote: ↑21 Aug 2025, 01:06It will if the displacement is reduced enough. Sub 2 litre V8?McLarenHonda wrote: ↑19 Aug 2025, 10:34A 500hp [NA] V8 probably wont need to go to 18K rpm to produce that...
Unless we get V10’s then there will always be someone shouting that they want the return of the V10’s. And iff we got them back there would be someone complaining that they don’t sound right.PlatinumZealot wrote: ↑21 Aug 2025, 00:59Well not really. It will be more than 500bhp for a number of reasons. The heavier V6T will charge more from the braking so those will have more powerfull electric motors than the lighter NA V8 - if we are maximizing energy re-use)... The other thing is torque fill.. The NA V8 will have a narrower power band for acceleration and still needs higher velocity for brake regen so it will end up with a higher rev range. I don't have the answers but could very well be 18k rpms!!McLarenHonda wrote: ↑19 Aug 2025, 10:34One thing nobody mentions about the return to V8s (V10s are already out of the window) is efficiency!
The 2026 V6T will only produce around 500hp while now it’s producing over 800hp alone without KERS! If we go back to V8 I assume they’ll also be producing around 500hp so that we keep the 50/50 split! A 500hp V8 probably wont need to go to 18K rpm to produce that which means it won’t sound like they used to back in the day!
Also it won’t be anywhere near as efficient as the V6T which also means the fuel tank will have to be much bigger! Thoughts?
I am sad bout FIA seemingly scrapping the V10... Maybe because they dont want too much power.... And I really don't want us to settle on the V8 then hear people crying about wanting a V10 after that point. They should just go V10 and be done with it.
A poll of 40,000 people already proved this nonsense claim wrong.
Another terrible strawman.WardenOfTheNorth wrote: ↑21 Aug 2025, 22:09Unless we get V10’s then there will always be someone shouting that they want the return of the V10’s. And iff we got them back there would be someone complaining that they don’t sound right.PlatinumZealot wrote: ↑21 Aug 2025, 00:59Well not really. It will be more than 500bhp for a number of reasons. The heavier V6T will charge more from the braking so those will have more powerfull electric motors than the lighter NA V8 - if we are maximizing energy re-use)... The other thing is torque fill.. The NA V8 will have a narrower power band for acceleration and still needs higher velocity for brake regen so it will end up with a higher rev range. I don't have the answers but could very well be 18k rpms!!McLarenHonda wrote: ↑19 Aug 2025, 10:34One thing nobody mentions about the return to V8s (V10s are already out of the window) is efficiency!
Basically, you’ll never please everyone.
In. Your. Opinion.Seanspeed wrote: ↑22 Aug 2025, 01:50Another terrible strawman.WardenOfTheNorth wrote: ↑21 Aug 2025, 22:09Unless we get V10’s then there will always be someone shouting that they want the return of the V10’s. And iff we got them back there would be someone complaining that they don’t sound right.PlatinumZealot wrote: ↑21 Aug 2025, 00:59
Most people just want a return to good sounding engines. They dont need to achieve the absolute pinnacle of engine sounds(ala V10 engines), just anything better than the incredibly lackluster current engines.
I literally cant stress enough how enlightening it is to sit 10m away from a huge line of F1 cars giving it full beans in front of you(at Goodwood Festival of Speed) to make it clear how utterly lifeless the modern engines are. Every F1 car in history pre-2014 sounds like 5x better than the current engines. It's not just a subtle difference, it's genuinely night and day.
It doesn't need to be V10's. But when many road cars are literally louder and more impressive sounding, something is terribly wrong.
A poll with a sample size of less than 0.1% of the global audience taken by one outlet - I assume you have never been involved in any kind or research study, because the inherent bias in that poll renders it of zero value when talking about the wider fan base.Seanspeed wrote: ↑22 Aug 2025, 01:38A poll of 40,000 people already proved this nonsense claim wrong.
What is YOUR evidence that nobody cares about engine sound at all? It's always like this with folks like you. We have to prove the entire world, but all you have to do is say 'Nuh uh!' and expect that to be some worthwhile rebuttal. smh
And at no point has any of us claimed it's the primary concern of anybody. This is a ridiculous strawman. People like you are claiming that fans just dont care about engine noise in general. But they do. Even if it's not a deal breaker to have lackluster engine noise, it doesn't mean they wouldn't PREFER to have better sounding engines. I am obviously an example of such a person. I still watch F1 quite religiously, it does not mean I'm happy with the current engines/engine noise and wouldn't prefer better engines.
Do you really think F1 is perfect in every way? Because again, that's like the argument you're trying to make here. That unless viewership declines, literally everything and anything F1 does is good and justified.
That poll could have been 5,000,000 people and you'd still somehow find a way to dismiss it. It's saying something you dont want to acknowledge, therefore it's not valid.WardenOfTheNorth wrote: ↑22 Aug 2025, 02:01A poll with a sample size of less than 0.1% of the global audience taken by one outlet - I assume you have never been involved in any kind or research study, because the inherent bias in that poll renders it of zero value when talking about the wider fan base.Seanspeed wrote: ↑22 Aug 2025, 01:38A poll of 40,000 people already proved this nonsense claim wrong.
All you can legitimately say as a result of that poll is that the vast majority of respondents on a social media channel with a podcast called “Bring back V10’s” want a return to V10’s.
Again, it is NOT JUST MY OPINION. You keep trying to shut this down as like some rare minority opinion. It is very much a common stance among fans. In no world have racing fans ever disliked louder and more impressive sounding engines.WardenOfTheNorth wrote: ↑22 Aug 2025, 01:57In. Your. Opinion.
You are equally bad at ignoring that your opinion does not represent everyone.
F1 cars currently are 120dB. That is louder than a rock concert. Show me a road car that is that loud…In the UK the legal limit for an exhaust is 72dB.
So “many roads cars” are demonstrably NOT louder than an F1 car and I have yet to find any road cars that are as impressive sounding.
Now you, and many others, may prefer the sound of even louder V10 cars, but you are presenting just as much of a strawman argument as I (that is, not at all strawman).
Don't waste your time arguing with these two.Seanspeed wrote: ↑22 Aug 2025, 02:12Again, it is NOT JUST MY OPINION. You keep trying to shut this down as like some rare minority opinion. It is very much a common stance among fans. In no world have racing fans ever disliked louder and more impressive sounding engines.WardenOfTheNorth wrote: ↑22 Aug 2025, 01:57In. Your. Opinion.
And modern F1 cars are definitely not 120db from actual viewing distances. Maybe when you throw a microphone up their spout, but many cars would be very loud via 'db' in that sort of test. Doesn't change that basically all other F1 cars are much louder.
And yes man, I literally sat there watching all these cars in person, right in front of me, from closer than most every F1 fan at F1 tracks get to see - there are quite a number of road cars that are louder and more impressive sounding. Of course I'm not talking about Nissan Altimas or whatever, but it doesn't matter - F1 is a pinnacle of motorsports and should elicit the sort of auditory vibes to represent that.
Lastly, please stop with the strawman that I'm talking only about V10's. Even the V8's were wildly better sounding and louder. Or literally any other engine prior to the hybrid V6's from 2014.
Yes. Some people, like myself, actually prefer the complex sound of the current cars and don't want to have to wear ear protection just to be able to do their job or where in ear radios to hear Race Control.bluechris wrote: ↑22 Aug 2025, 05:10Really guys? The discussion is if the cars before 2014 sounded better? Is there objection to that? To feel the noise of the damn car and not only hear it?
You care for the birds so much and other woke agendas that you are annoyed from the power of sound? Sorry but i think you never heard a proper f1 car chilling you out from noise which was the epitomy of f1 and we lost it so many years.
I don't think any real F1 fan likes the current situation.
Nope. If it was a representative sample across multiple sources to avoid bias then I'd accept it.Seanspeed wrote: ↑22 Aug 2025, 02:06That poll could have been 5,000,000 people and you'd still somehow find a way to dismiss it. It's saying something you dont want to acknowledge, therefore it's not valid.WardenOfTheNorth wrote: ↑22 Aug 2025, 02:01A poll with a sample size of less than 0.1% of the global audience taken by one outlet - I assume you have never been involved in any kind or research study, because the inherent bias in that poll renders it of zero value when talking about the wider fan base.Seanspeed wrote: ↑22 Aug 2025, 01:38
40,000 is a pretty dang large sample count. The idea that you need extraordinarily large numbers for polling to be valid shows you are the one who doesn't understand these these things.
"Most people dont like pizza".
At what distance?WardenOfTheNorth wrote: ↑22 Aug 2025, 01:57F1 cars currently are 120dB. That is louder than a rock concert. Show me a road car that is that loud…In the UK the legal limit for an exhaust is 72dB.
Roger wilco!!hollus wrote: ↑22 Aug 2025, 22:33Guys, agree to disagree. Horses for courses and everyone is entitled to its own opinion.
Acknowledging that others see things differently, without trying to shut/shout them down is an art.
An art that avoids this circular past-each-other discussion.
This is the internet, you cannot win if that forces others to “lose”. The target is too mobile.
You all made your point, loud and clear. Now move on, please.
