saviour stivala wrote: ↑12 Sep 2025, 18:24
The energy recovery is performed by the motor generator unit - kinetic (MGU-K) when the driver brakes by applying the brake pedal, not by lifting foot off the throttle. Lifting foot off the throttle engages the engine's natural engine breaking, which is separate effect from the ERS-based energy recovery, though both reduce the car speed.
the driver can only lift his foot off the accelerator pedal - this doesn't have a fixed relationship to the throttle
the ICE doesn't have the traditional engine braking - it has only engine braking due to friction
because there is no throttling of the air being sucked through
using such throttling would greatly reduce the amount of regeneration available to the ERS
the F1 ICE can/will do what our road cars did 40 years ago - be fuel-off accelerator-off throttle-open
