Sergej
P2 should be a good position with a dry race and that setup.
venkyhere
43
search wrote:
22 Nov 2025, 08:11
biggest problem was the timing, I think. The McLaren started their final lap at the very end, Sainz and Verstappen with around 1:30 to go.
I don't think so. Norris was 1s faster than Max, in his final Q3 lap, just that his mistake at T14 reduced it to 3 tenths. The McL39 isn't 1s faster than the RB21 on dry tyres. This quali session was all about 'who warms up their tyres best even before hitting T1 on a flying lap' - Norris and Mclaren did a superior job than Max and Redbull. It's that simple. Remember, Max had to do double-warmup laps in the FP sessions before his quali sim run, others didn't have to.
search
euv2 wrote:
22 Nov 2025, 08:30
search wrote:
22 Nov 2025, 08:11
Eh, that was the 2nd biggest problem. It's been a trend since the first race in Australia. Intermediates overheat very quickly if the racing line becomes dry and MCL is the best at keeping them in check whereas, RBR and MERC started losing pace relative to them.
yeah, sure, but if you want to take pole on an improving track, you can't start your final lap with 1:30 to go.
Not that the lap was particularly good anyway, with Sainz setting the same lap time even earlier, but it of course played a part in the battle with Norris.
euv2
euv2
search wrote:
22 Nov 2025, 09:06
euv2 wrote:
22 Nov 2025, 08:30
search wrote:
22 Nov 2025, 08:11
Because the original plan was the do 2 consecutive push laps at the end, but quickly into the 2nd last lap they released that 1 push 1 cool was the best. So, max aborted the 2nd last lap at the end of sector 2 and had just sector 3 to cool the tires.
The pitwall should have seen what the others were doing, instead they followed the same run plan as they did on wet tires and kept pushing but intermediates start to overheat quick.
Sergej
more people to leave
ME4ME
82
euv2 wrote:
22 Nov 2025, 09:10
As the laps got faster they probably reached the cross-over point of having to do recharge laps. I don't think the slow laps which we saw people doing had anything to do with tyres overheating. It was damp and cold. Smooth track, low abrasiveness.
FittingMechanics
FittingMechanics
It was strange to see Red Bull drop the ball with Max not being last on track. Usually they are very good with that.
Maybe they felt the risk of a red flag or yellow is too high and Verstappen was not on the pace from the start of Q3 so they had to compromise a bit of potential for guaranteed "good" position.
Probably their car just doesn't work as well on inters. Max said as much in post qualy interview.
euv2
euv2
ME4ME wrote:
22 Nov 2025, 09:43
euv2 wrote:
22 Nov 2025, 09:10
But GP said they had enough battery for push on both laps at the lap times they were doing, even said he could push and hold overtake button on the straights, so I'm assuming that'd be the case for others too. Cold conditions would mean double push was the better option but that wasn't the case.
Valeo
Valeo
On a drying track with Inters the Mclaren is simply unmatched.
Even in those cool conditions the surface temp for all others go through the roof lol
Vettel165
Well done old boy Max with a mega Q3 lap. P2 is very good today, he might fight for a victory tomorrow.
Badger
Badger
46
Solid session from Max, just built it without making many mistakes, you could tell early on in Q3 that the RB wasn't getting heat into the tyres. Timing was really bad from the team, getting one less lap in these conditions cost any chance of pole, lucky to have that yellow flag.
tinuva
https://x.com/formularacers_/status/199 ... QB_UGukLhQ
Sent from my Pixel 8 using Tapatalk
f1isgood
f1isgood
Badger wrote:
22 Nov 2025, 11:34
Operationally the team has been showing cracks since last year. Pitstops are not their excellent point anymore, they are losing staff. Next year even if the car is good they need to improve significantly elsewhere.
venkyhere wrote:
22 Nov 2025, 09:00
search wrote:
22 Nov 2025, 08:11
Not quite.
Lambiase:
Max, if you want to cool the tyres now to turn 14 you can do and there’ll be one more lap. Can let Fernando through if you want to.
Worn inters on drying track = Mclaren dominance. Same as Australia, Silverstone, and Spa. They had already driven 7 laps on the tire with a dry line forming. The inters overheat for everyone except Mclaren.
In Q1 and Q2 he was quick on the full wet tire. The water cools the tires in full wet conditions.
Beware of T-Rex
