2025 Scuderia Ferrari F1 Team
Re: 2025 Scuderia Ferrari F1 Team
Is Qatar considered a more or less favorable circuit for Ferrari?
Beware of T-Rex
Waz
Waz
27 Nov 2025, 15:46
Well, it's perfectly flat.
But it's seriously hot with mostly high speed corners.
And then the unknown effects of the limit of 25 laps per tire set.
Lots of Pros and cons. Gonna be interesting
Waz wrote:
27 Nov 2025, 17:18
27 Nov 2025, 15:46
That's true now that you mention it. Lots of pros and cons.
Flat = good for minimizing plank wear
Hot = bad for brake temps, but good for getting SF25 tires in the window
High speed corners = good for Ferrari (imo)
25 laps per set = Could make a bigger LICO penalty since race will run at higher pace with 2 stops.
Beware of T-Rex
Paa
27 Nov 2025, 15:46
Yes. More or less favorable.
Mosin123
Mosin123
Andi76 wrote:
26 Nov 2025, 21:38
Mosin123 wrote:
26 Nov 2025, 14:35
Andi76 wrote:
26 Nov 2025, 09:01
Sorry, but that's not the case. On the contrary. He came into F1 and got into the best car, which was still the best the following year. And then things went downhill... and Hamilton was unable to improve either the car or the team over several years. Then he went to Mercedes, where they had spent several years developing the team, procedures, and technology with a view to 2014, and where many developments were tested in 2013. I think the "Mercedes advantage" is well known, so in terms of development, it won't really be relevant again until 2022 – and here we didn't see any real leaps in development. Just as they are lacking at Ferrari. And it is precisely in times like these that good "development drivers" show their quality. Not when the team puts out a car that is already good, but when it is not so good. And in these times, the teams Hamilton was in, whether McLaren, Mercedes, or Ferrari, have not made any leaps in development.
To say that drivers do not develop a car, as one response to your post says, is wrong. Of course, it is increasingly the engineers and the simulations and data, but even today, a driver still contributes a lot. The importance of the driver in this regard lies in identifying the areas that need improvement and that have the most potential for improvement. Here, the driver is still of immense importance today, and having a driver who is good at this determines whether you are competing for victories and titles or, at best, only for podiums or even less.
Unfortunately, Hamilton is not good in this regard, as history has sadly proven. Whenever the team he was in did not build a good car from the outset, it did not improve significantly. His behavior, characterized by constant complaints, whining, and criticism, is also the exact opposite of what you would call motivating a team, and in fact, it does not promote team spirit. It destroys it.
But anyway - sorry, Hamilton definitely does not have a strong track record in improving car performance. In fact, he has the opposite. Whenever it was necessary for the car to significantly improve its performance, nothing moved forward. Whether at McLaren from 2009 to 2012, at Mercedes from 2022 to 2024, or at Ferrari in 2025.
That is a bit of a fried take on things, He did start in a good car, he also had to go against a 2 time world champion, and was a match for the champion. Then you forget about the fall out from spygate, which seriously damaged Mclaren, it caused the split with the Mercedes engine partnership and was the main driver in Mercedes buying Brawn to begin with.
Also dont remember Mercedes being a title challenger in LH first season either, They became champions after LH joined the team. Infact, Every body in the world was saying he had made a mistake signing for Mercedes, blah blah blah..... The W11 was also the best f1 car Mercedes ever made, Some say it is the best F1 car ever made, 6 years after LH joined, But lets just pretend it didnt happen yes?.
Michael Schumacher did the work in his bed while in a coma apparently..
An injured Hamilton fan, obviously... because emotion seems to make it impossible to read correctly. What does his performance as a development driver have to do with the fact that he was able to keep up with a two-time world champion? Nothing. Nor does Spygate or the split from Mercedes have anything to do with how he is as a development driver. As for Mercedes, when Hamilton arrived, you were obviously unable to see through the same emotions that the technical and personnel decisions had already been made years in advance... as is actually known... whether Haug and Brawn's decision to start with the new engine well ahead of everyone else, to recruit the right people and put them in the right positions, to focus on 2014, and to try out and prepare a lot with the 2013 car, which laid the technical foundation for this earlier (incidentally the fact you mention that Hamilton was a title contender in his first year at Mercedes – you are aware that the car and technology of the 2013 car were developed in 2012? Hamilton had nothing to do with that). Ultimately, we are seeing a long-prepared dominance that in many ways had the advantage of long-term preparation and planning, which did not require any major, costly development, compared to the years at McLaren 2009-2012, Mercedes 2022-2024, and Ferrari 2025, where real, immense development was/is necessary. And here, no one can claim that Hamilton has ever stood out as a strong development driver. Even if it may hurt as a fan, one should accept these very clear facts. And not grasp at straws (that he was a title contender in a car developed before his time, or that he was able to keep up with a two-time world champion, or the fallout from a scandal) that have nothing to do with it.
Injured Hamilton fan? No, I am a Mercedes Fan - An old Brawn fan - once a Honda Racing fan - who started it all out supporting Tyrrell Racing and carried on following BAR and following and following till today, who would have thought that....... Please.....
you can say all you want, But a quick google can show the real facts in interviews, Team mate interviews, you know people that ACTUALLY worked with him - Not some one on a forum that thinks they know more than alot of the F1 grid, its funny :wtf: .
Best ever f1 racing car was one LH was lead driver for and had been involved in, year after year after year of continued improvements from his first app as a Mercedes driver in 2013 and all the way untill 2020 in which the best ever f1 car was born, Records was broken, and Mercedes won title after title after title..... must hurt so much.
Andi76
Andi76
476
Mosin123 wrote:
27 Nov 2025, 20:37
Andi76 wrote:
26 Nov 2025, 21:38
Mosin123 wrote:
26 Nov 2025, 14:35
I don't think broken records hurt anyone. It's the natural order of things that records are broken. And what's much more important is how and under what circumstances they are achieved anyway.
Incidentally, I just did a Google search—even with Chat GPT—and couldn't find a single source that actually names Hamilton as a strong development driver. Not from one Single engineer or driver who worked with him. So sorry... the reality is obviously not what you would like it to be and say. Especially since, as has been said many times, the McLaren era, the Mercedes era after they could no longer capitalize on their dominance and carry on a lead acquired without Hamilton, and Ferrari 2025 are facts that speak for themselves. Good development drivers don't even move the car forward, and never again before or after. The Definition of a strong development driver is definetely something else.
ScuderiaLeo
I don't know how you guys can be arguing over this driver development topic after 3 weeks. The same thing over and over, are you not bored of this?? It must be at least 60% of the last 100 posts here :lol:
Anyways, Hamilton said in today's press interviews the team is expecting Qatar to be much better than the last few tracks, and that they think it suits the car. However, still not on the level of RBR.
Leclerc answered questions about 2026:
I really hope we'll turn the situation in our favor in 2026, but to be completely honest, I'm not sure. There are so many changes between this year and next. Of course, our goal is to get everything right, but there are so many little details that can make the difference in terms of competitiveness that we'll have to do everything perfectly. For now, that's what we're focusing on.
This year, we've sacrificed the end of the season to focus fully on next year. So all the elements lead me to believe that we're working in the right direction and in an appropriate way. However, every team probably shares that feeling, and only time will tell next year. I don't think much about the outcome; I think more about the process and what we can do to be as well-prepared as possible.
2026? I like the challenge of having to think differently about driving. I think that first very strange session on the simulator raised a lot of questions in everyone's mind at the factory. The process of thinking as a group about the smart ways we can find to solve certain problems we'll have with the 2026 car has been very interesting, and I think that's also been the case for the drivers, because it involves a lot of our sensations and the tools we need to manage different types of situations, like the battling that will be quite critical with the other cars during the race. As for the pleasure of driving, I'll have to wait until I've driven the real car to give my verdict. On the simulator, it's hard to really feel those sensations, but there will certainly be a lot more to think about while driving and especially during the race to manage the energy we'll have added next year.
ScuderiaLeo wrote:
27 Nov 2025, 22:17
They think they can match Mclaren or is he just saying Mclaren > RBR > Ferrari or RBR > Mclaren = Ferrari?
Beware of T-Rex
ScuderiaLeo
27 Nov 2025, 22:24
I would assume the former but he didn't specify
Mosin123
Mosin123
Andi76 wrote:
27 Nov 2025, 20:55
Mosin123 wrote:
27 Nov 2025, 20:37
Andi76 wrote:
26 Nov 2025, 21:38
What did you ask Chat GP?, cause when i ask a basic question like, "was hamilton a good development driver ", ChatGPT's response was good that LH was big reason Mercedes was so dominate!!!!!!!!!!!!!!!! Funny RIGHT??? LOL.
Let me guess, you know more than chat GPT now? or is Chat GPT now wrong? or cant be used?
" Yes, Lewis Hamilton is widely regarded as an excellent development driver, and his contributions to the development of Formula 1 cars, particularly at Mercedes, are often highlighted as one of his key strengths.
Here are a few reasons why Hamilton has been such a valuable development driver:
1. Exceptional Feedback and Communication
Hamilton has a unique ability to provide precise and clear feedback to his engineers. This allows the team to make adjustments to the car based on his input, whether it's related to balance, handling, tire wear, or other aspects of performance. His technical understanding of the car and how it reacts under different conditions has been crucial for Mercedes.
2. Adapting to New Regulations and Car Changes
Over the course of his career, Hamilton has adapted to multiple changes in car regulations and technological shifts. From the shift to hybrid engines in 2014 to changes in aerodynamics, Hamilton has been instrumental in helping his team understand how to optimize the car within the constraints of new rules.
3. Consistency and Performance
Hamilton’s consistency in terms of performance gives engineers valuable data to refine and develop the car. When the car isn’t performing well, his ability to push its limits while staying within the car's limits makes it easier for the team to identify areas needing improvement.
4. Success Across Different Cars
Even when Mercedes was not the dominant force in Formula 1 (such as in his earlier years with the team), Hamilton still managed to extract the maximum from cars that weren't always the best on the grid. His success in 2008 with McLaren and later with Mercedes in 2014 and beyond proves his adaptability and understanding of car development.
5. Collaboration with Engineers
In addition to his driving talent, Hamilton has always been a team player when it comes to car development. His collaboration with Mercedes’ engineers, including key figures like James Allison and Toto Wolff, has helped the team build cars that are consistently fast, reliable, and competitive.
6. Bringing Out the Best in the Car
Hamilton’s ability to get the best performance out of the car in difficult conditions—such as wet weather, tire management, or under pressure in races—has been a key factor in developing the car’s strengths. His ability to test and refine setups has contributed to making the car more versatile and adaptable.
Conclusion:
Hamilton's work as a development driver is a big reason why Mercedes has been so dominant in the turbo-hybrid era. While the team had the resources and technical leadership to design competitive cars, Hamilton’s feedback, work ethic, and ability to adapt to evolving technology and rules were all critical in making the Mercedes F1 car so successful. His role went beyond just being a driver to becoming a vital part of the development process."
LOL.. =D>
leblanc
Mosin123 wrote:
28 Nov 2025, 01:19
Andi76 wrote:
27 Nov 2025, 20:55
Mosin123 wrote:
27 Nov 2025, 20:37
Conclusion:
LOL.. =D>
this boomer-tier discourse has devolved into ai copypasta
Kipck
Kipck
Time to retire
ScuderiaLeo
Surprised and not surprised at the same time.
Not surprised because I didn't expect them both to do well especially after that disastrous FP1
Surprised because I half expected the one to go out early to be Leclerc. He usually treats sprints like FP sessions.
At least it's just the sprint. Hopefully they can get good data from it
matt_b
matt_b
I knew Lewis was out the moment he was doing a double cooldown lap, he did the same in Brazil, and I knew he was going out there also :wtf:
DGP123
DGP123
Kipck wrote:
28 Nov 2025, 19:45
Time to retire
Yeah, the designers. Embarrassing dog of a car, and there’s nothing on the horizon which suggests things will change. Just a mess
