AriaanGert
AriaanGert
Wasn't this the result of that new engine, that they didn't use in Qatar? I would have expected him to be quicker on the straights and that's where he had the advantage.
f1isgood
f1isgood
AriaanGert wrote:
06 Dec 2025, 17:25
Wasn't this the result of that new engine, that they didn't use in Qatar? I would have expected him to be quicker on the straights and that's where I had the advantage.
Lol no. He was also quick in S3. How do people still think new engines give much more power in big 2025?
FNTC
FNTC
Max with fresh engine and good top speed. I have a feeling that if he leads after the first corner we might see a 20 car DRS train for a while to get Lando in trouble, lol.
Juzh
161
In the end S3 deficit was only half a tenth. Decent effort from Max.
MYsee
MYsee
Oscar at T1 is in an interesting spot. He needs a win and for Lando to fall to 6th. It is in his interest to be aggressive against Lando.
Badger
Badger
46
FNTC wrote:
06 Dec 2025, 17:27
His set-up is quite optimal for high levels of strategic f*ckery :lol: Gonna be very hard to pass unless the tyres fall off completely.
f1isgood
f1isgood
MYsee wrote:
06 Dec 2025, 17:37
He probably gets told today to follow "Papaya Rules".
CHT
CHT
-7
Oscar WDC race is over, he will likely play second fiddle to make sure Lando finish on podium tomorrow because Oscar cant win the WDC if Max is leading the race.
And one driver that can spoil Lando race will perhaps be Russell
f1isgood
f1isgood
CHT wrote:
06 Dec 2025, 17:48
Russell botched his laps to be a factor. Going to need a miracle. Nothing changes in that regard.
Valeo
Valeo
The very few times you want George up there he bottles it (already happened last week)...
But of course he won his two races right in front of Max :roll: :D
Benson has a weekend he will never forget. I hope we will have a GP tomorrow we will never forget. :mrgreen:
Video:
venkyhere
43
venkyhere wrote:
05 Dec 2025, 16:45
From the data, Norris was in lower engine mode than Max in FP2, and still faster by 4 tenths in Q and around 5-6 tenths in R simulations. RB21 also showing much bigger 'deg' than the McL39. In the real Q and R, I think this gap is going to be 5 tenths and 8-9 tenths, respectively. The difference in the off camber corners of Sector3 is almost comical. I think this is too much a gap for Redbull to bridge. I can't see beyond a pole to flags victory for Norris this weekend. The advantage over the 'next best' car on this track, is even bigger than it was in 2024. Norris will win his 1st WDC with a cool P1 with some 30s margin over P2.
Piastri looks lost.
How wrong I was about S3 !!!
Max was only a few hundreths slower than both Mclarens in S3. It can only be one/both of two things :
- Max was hiding pace (as much as 4 tenths) in S3 throughout the weekend, until Q3 (he did show a sub 30s in the second Q2 run, but 29.6 in Q3 is an insane sector time, gaining 0.55 w.r.t FP2)
- Redbull actually fixed the understeer overnight.
For all the talk of Vmax, the 'tow' that Max got, what the lap traces (F1insightshub.com) show, is that his Vmax gain was 2kph only. The Mclarens were nearly equal in top speed to the Redbull, Where Max 'gained' his S2 time, it was in the slow corners T5 and the T6-7 chicane.
For all the 'it's close in quali' talk, and the fact that both Mclarens didn't make a mistake and drove optimally, the pole lap was 2 tenths faster. This is not a man, it's a machine.
Badger
Badger
46
Max has done what he needed to do. All he can do now is invite Norris to make a mistake, and hope to get lucky. Odds are still heavily in favour of Lando but stranger things have happened.
euv2
euv2
venkyhere wrote:
05 Dec 2025, 16:45
To be honest that tow was very weak, it's like Yuki did the bare minimum there. He was simply too far out; he should be much closer coming out of the chicane to have made a sizeable difference. Would have been better off doing 2 qualy laps.
Its good Max ended up improving on the 2nd run, otherwise too many people would have attribute the lap to the 'tow'.
euv2
euv2
Badger wrote:
06 Dec 2025, 19:19
Might need to bait Lando into having a go into turn 1 and then hold the inside and make Norris yield. Otherwise, he'll mostly have to rely on Lando having a terrible start or contact. Not sure how much backing the drivers behind and forming a train is going to help things.
