Aston Martin Honda AMR26 speculation thread
theriusDR3
theriusDR3
Official AMR26 Hardware and Development thread
Just renders of the AMR26 today, Aston Martin will be doing their launch on 9 February 2026!
Mod edit note: So let's wait until there is actual hardware, as usual, with theofficial car thread.
Free hand to dream, speculate and mix a bit of team stuff in this thread until then.
Speculation car thread here.
This thread stickied until then.
FNTC
FNTC
Re: Aston Martin Honda AMR26
Damn that sounds nice (for a 1.6l turbo V6)!
zoroastar
Re: Aston Martin Honda AMR26 speculation thread
FNTC wrote:
12 Dec 2025, 20:45
yeah that sounds good. is it just me, or does it sound better than the one redbull has been using for the last few years? i have been curious to hear if the sound would chnge much under the new regs.
FNTC
FNTC
https://www.the-race.com/formula-1/hond ... ne-launch/
Aston Martin’s 2026 F1 car will be launched in Saudi Arabia on February 9 but three weeks before that Honda will host a unique event in Tokyo on January 20.
The manufacturer says it will “reveal” its engine alongside sharing its aspirations and explaining the new regulations.
Honda president and CEO Toshihiro Mibe, Aston Martin F1 team chairman Lawrence Stroll, and F1 president and CEO Stefano Domenicali will all speak at the Tokyo event, which will be livestreamed on YouTube in English and Japanese.
collindsilva
collindsilva
FNTC wrote:
16 Dec 2025, 13:08
Honda seems to be very confident about their engines, all signs pointing to be very positive, expecting regular podiums
hollus
Will they forfeit the test in Montmelo in January?!
¡Puxa Sporting!
Holm86
261
hollus wrote:
16 Dec 2025, 20:51
That's a closed private test, why would they unveil the car before that?
hollus
Closed and private. Fair enough!
¡Puxa Sporting!
TyreSlip
TyreSlip
Wild rumour if true... solid-state batteries for the new Honda power unit?
https://it.motorsport.com/f1/news/f1-ho ... /10784997/
This would be a game changer if it worked. Without additional anode material, there would be weight and size savings with a solid-state design.
bananapeel23
34
FNTC wrote:
12 Dec 2025, 20:45
Wow!
The MGU-H must've been muffling the sound A LOT. This sounds a lot more raw.
TyreSlip wrote:
17 Dec 2025, 15:51
Am I right that there is no battery weight limit, only a weight limit for the PU as a whole?
Still. Batteries are very dense and sit extremely far down in the car. If it's easy to hit the engine weight floor without solid state, the benefits of the battery being replaced by a solid-state one would only really be minor packaging implications, since you can't really ballast any further down than the battery already sits.
You could theoretically load the car up with lead or tungsten ballast as far down as possible and perhaps move it around a little during setup to change the overall weight distribution, and the smaller battery would perhaps allow slightly tighter packaging, but it probably isn't a massive upgrade.
Still, it would be amazing to see solid state batteries make their way out of labs at last. If the engine weight floor is difficult to hit while maximising performance, solid state would also be a really big deal and offer huge benefits.
vas_04614
vas_04614
I have this question on 2026 cars w.r.t movable FW
In High downforce mode, air from FW will hit car a certain place/angle.
In low downforce mode, it'll be different angle and will hit different part of car.
How will this be handled?
matteosc
matteosc
32
vas_04614 wrote:
17 Dec 2025, 17:17
I think that is the main challenge from an aerodynamic standpoint. Not to mention how the transition between the two modes is handled.
vas_04614
vas_04614
If they push low downforce mode air from FW to under the floor, would the floor generate more downforce?
FNTC
FNTC
vas_04614 wrote:
18 Dec 2025, 15:46
In low drag mode I would think it would be beneficial to make the floor stall instead.
f1316
89
bananapeel23 wrote:
17 Dec 2025, 16:19
FNTC wrote:
12 Dec 2025, 20:45
Wow!
TyreSlip wrote:
17 Dec 2025, 15:51
Maybe a slight tangent but it’s a major flaw in the regs imho to have a minimum weight limit for the PU … at all tbh but certainly one that’s easily met. Given the objective is to reduce the overall car weight - and even the modest reduction for 2026 is apparently difficult to hit - incentivising the PU manufacturers to find weight reductions seems a particularly good way to drive this down.
Imho the biggest single weight increase problem we’ve seen (anything for safety is not a ‘problem’, since that’s necessary) is the introduction of the 2014 hybrids. Perhaps, if these rumours about solid state batteries are true, Honda would instead introduce ballast to meet the regs and have an optimal weight distribution, but - again, if true, which it may well not be - really the FIA should look into reducing the minimum weight of the PU (or, indeed, abolishing altogether in order to create a real incentive for weight reduction on the engine side).
