2026 Drama: Alleged engine loophole
sucof
37
Re: 2026 Drama: Alleged engine loophole
If the materials allowed are not very good for modifying compression ratio, then what about metamaterials?
Are they allowed?
Does a meta material piece count as a moving mechanical complication, or just a single piece of metal?
Richard C
29 Dec 2025, 04:48
The regulations say the only moving parts allowed in the cylinder are the pistons, and the intake and exhaust valves.
Thanks. I think it’s fair to expect me to review the rules to find this vs. asking you to specify where it spells this out. I just spent some time trying to find where exactly in the rules this is defined. I understand it may not be worded exactly that way. I unfortunately can’t find anything that limits the only moving items in the cylinder (and by extension the combustion chamber) to be the piston and valves). If you (or anyone else) have the reference handy, I would appreciate it.
I have tried to list what I think might be the relevant regulations with my commentary…
5.1.5 Displacement defined by movement of pistons within cylinders
5.1.6 Defines the area for combustion. Poppet valves are mentioned, but no other exclusions
5.3.1 Says pistons must reciprocate, but nothing about anything else moving or not moving.
5.3.4 Specifies intake and exhaust particulars, but nothing about other potential moving objects in the combustion chamber. By extension you can say anything requiring a sealing surface in the combustion chamber must be circular. This is meant for the intake and exhaust valves but could apply to a dynamic compression ratio device.
5.3.7 Specifies “inserts” for the head. This is restrictive, but (IMHO) there is plenty of room here to implement something. Note, insert use is not totally free and is subject to limits and approval/review. One interesting rule is that “none of these inserts can be exposed to the combustion” meaning that any sealing surface for a dynamic compression ratio device must not use an “insert”. I think this might be the most significant challenge.
5.6.4 is the rule in question that specifies the CR
5.6.14 Specifies various dimensions around intake and exhaust valves, but another mechanism (if not intake or exhaust) is not regulated here.
5.9.3 Variable geometry is not allowed, but rules don’t apply after air passes past the cylinder inlet.
15.7.* Depending upon how a dynamic compression ratio device might be classified, it would fall into one or more area here for allowable materials. Note that “cylinder head” material falls in “static”. Is a dynamic device a “static device”? If not, it may not be limited to just aluminum or iron-based alloy as the head would be required to use. Regardless, material restrictions is "probably" not an issue.
15.8.8 Requires the head to be made from “a single piece of material” Can you not create multiple components from a single piece of material? This might be pushing the intent of the regulations.
I may be wrong (am open to being wrong) but I can’t find anything that precludes a device in the head that can adjust compression ratio and ensure that it measures 16:1 when at rest/cold.
Richard
To paraphrase Mark Twain... "I'm sorry I wrote such a long post; I didn't have time to write a short one."
Rodak
Rodak
37
I disagree with you comment about Section 5.3.7, Inserts, and the opportunity 'to do something'. The FIA has total approval control of the inserts.
5.3.7 In a Cylinder Head, only inserts approved by the FIA Technical Department will be allowed.
The total volume of the inserts listed in a. to c. below cannot be more than 3% of the total
volume of each Cylinder Head and these must be confined to:
a. Conventional valve seat inserts
b. Conventional valve guide inserts
c. An insert concentric to the spark plug axis with a maximum outside diameter of 15mm
An additional allowance of 1% of the total volume of each cylinder head is permitted for
inserts other than those mentioned above, but none of these inserts can be exposed to the
combustion.
670
so a steel or other iron-based engine block is possible ie 6 ppm/deg F expansion
for the rods established iron-based alloys (and mandated iron-based piston alloy) will give 9 ppm
these will do the '16-18 trick' (as I said a week ago)
the crank & rods & piston are hotter and more expansive than the block
about a million British motorcycles had Al alloy rods and iron cylinders - so did the same 'trick'
TEST
piast9
piast9
I have a question. Where did 18:1 effective compression ratio figure came from? Who did report it? I only saw some media speculation about that value.
Bence
Bence
Are variable displacement engines explicitly banned?
hollus
piast9 wrote:
29 Dec 2025, 22:54
18:1 was in the old regulation set.
And if you are a newspaper looking for drama, it makes a nice villain and sounds optimal and hence dooms-day-y. IMHO.
The real target may also be 16.3, and the real gain might be 2-3 hp, if any.
Or not, of course.
AFAICT there is zero solid sources for restoring 18:1.
¡Puxa Sporting!
Richard C
Rodak wrote:
29 Dec 2025, 21:22
As I mentioned in my post (new bold by me)...
Richard C wrote:
29 Dec 2025, 18:36
We can disagree on how much freedom exists here. Is not this entire thread about trying to understand how this might be done within the current rules? If a design is otherwise legal, why not approve it? But yes, FIA might not approve a specific design, even one that might be otherwise legal. Or maybe they might approve it! :wink:
I also wanted to provide a more recent link for the regulations. The prior link is over a year old and out of date. I think there are differences. My earlier post is based off that 2024 document, so there might be something in the newer document that invalidates some of my thoughts. I haven't looked through deeply yet. I only noticed after posting that the document was old and out of date.
One easy thing to point out is that the June 24th 2024 version does not include the text regarding measuring compression ratio while the October 12th 2025 document does. Also, given the recent edits are included in pink and the call out for ambient temperature is not in pink, I assume a version between June 2024 and October 2025 included the "ambient temperature" edit and then this newest one includes more specifics.
https://www.fia.com/system/files/docume ... 2-10_0.pdf
Richard
Richard C
Bence wrote:
29 Dec 2025, 22:56
Displacement seems to be defined by swept volume of cylinders. Which should be generally static and not variable. Combustion chamber size is undefined outside of the compression ratio rule which may (or may not) be an area for interpretation. For example, the compression ratio can't be higher than 16:1. Might you create a variable volume combustion chamber that allows for a lower compression ratio (not that you would want to do this). It sounds like maybe you could? The question is... can you go higher than 16:1 in some conditions if this is only measured (and you ensure it is legal/16:1) at ambient temperature (whatever that means).
Richard
PS: I welcome anyone pointing out errors in my interpretation of the rules. :) It's all about sharing ideas (even if crazy) and learning things. We all have to think out of the box to explore where exploitable gaps exist in the rules. And some of those ideas might be very dumb or illegal in ways I haven't seen yet.
vorticism
vorticism
449
Tommy Cookers wrote:
29 Dec 2025, 21:35
FDD wrote:
28 Dec 2025, 19:30
Every alloy has its code (as I wrote), so they are precisely defind for sure.
every alloy doesn't have its code and isn't precisely defined
only in uses outside the PU perimeter are the alloys restricted (and iron-based alloys are unrestricted anyway)
inside the PU perimeter (apart from the piston etc) there is no such restriction
ie the cars can use any alloy ie an alloy made to the team's design or choice
the con-rods can be any iron-based or any titanium-based alloy and the crankshaft can be any iron-based alloy
(eg by iron-based the rules mean only that iron must be the biggest single ingredient)
the crank & rods & piston are taller and hotter and more expansive than the block
Correct, the crankcase is limited only to iron or aluminium alloys (C15.7.8). So too can the cylinder heads and cam covers be made of iron based alloys. Developing an all-steel engine would not be an overnight thing, so finding out that a competitor did could cause some worry. Yours is the best case I've seen in favor of the TE alteration of CR rumor.
Additive manufacturing is permitted for the crankcase/block, heads, and covers, afaict, which would help with the weight penalty (steel being 3x denser). Pairing Fe alloy blocks with Al heads is done in road car engines, but as a stressed-member racing engine I'm not sure what's been done in the past in terms of dissimilar metals. The Audi Le Mans diesels had both aluminium blocks and heads.
At this point, I would separate potentially two different rumors at play here:
--steel or Fe-alloy engine altering the compression ratio (still a maybe to me)
--"second combustion chamber" (Nunes's description and the one I'm more interested in; doesn't invoke TE effects)
Rodak
Rodak
37
Richard C wrote:
30 Dec 2025, 01:28
Rodak wrote:
29 Dec 2025, 21:22
Richard C wrote:
29 Dec 2025, 18:36
Richard
2026 is a new engine formula, so it would be useful to address the 2026 regulations, not the 2024, which is no longer valid.
Richard C
Rodak wrote:
30 Dec 2025, 03:56
Maybe poor explanation on my end. The prior document (technical specification) that was linked was dated 2024, but was for the 2026 regulations. They have changed some since then. The link I provided was for the most recent 2026 regulations. And that document will eventually be replaced at some point as well by a newer revision. I was not calling out specifics from the previous era technical specifications.
Richard
atanatizante
133
This topic is a load of bollocks! And I'm not the one who is telling this thing but rather real enginners with lots of expertize in this area: (use CC to translate)
Jesus
atanatizante wrote:
30 Dec 2025, 12:45
The guy didn't say it is bollocks. He said they could use a layered cylinder head to create bulging into the combustion chamber at operating temperature. What did you take from it?
#ReleasetheADUO
sucof
37
atanatizante wrote:
30 Dec 2025, 12:45
I did not hear him saying this topic is a load of bollocks... Instead he suggested an other way to do it, which might make sense.
I still think it is worth to think about meta materials.
Also, Toto is a guy who would likely spread believable rumours just to distract the opposition from something else they really did, or just to make the opposition loose time investigating an area they know does not work.
