2026 Mercedes-AMG Petronas F1 Team
Home of the 8x WCs. The legend of the Silver Arrows returns for the 2026 Formula One World Championship.
Season 17 | Starring:
Team Principal: Toto Wolff
Technical Director: James Allison
Car #63: George Russell 🇬🇧
Car #12: Kimi Antonelli 🇮🇹
Headquarters: Brackley, England 🇬🇧
#ReleasetheADUO
Re: 2026 Mercedes-AMG PETRONAS F1 Team
#ReleasetheADUO
Drivers seems positive about the car.
Antonelli:
“I’ve been spending quite a lot of time at the factory, seeing the progress in the wind tunnel, also going to HPP [High Performance Powertrains], seeing the progress on the dyno.
“So definitely, it looks promising, but we don’t know what the others are doing, and I think the most important [thing], when we go for the first test in Barcelona, [is] having a reliable car, being able to put the laps in, and then make the most learning.
https://www.planetf1.com/news/kimi-anto ... m-scenario
#ReleasetheADUO
Lasssept
122
Matt2725
Matt2725
Reads like the car will be perhaps less developed than rivals initially, but they're going with a strong foundation instead of doing something radical out the gate.
Probably sensible but could mean they may be giving away performance early on.
OverheatedTurbo
OverheatedTurbo
Please don’t be a tyre shredder. I don’t want to look at the weather app prior to the race weekend.
f1isgood
f1isgood
As long as Merc is not 1s a lap behind, they will do just fine. They are very good at in season development.
Mansell89
Mansell89
Interesting if that is the Merc approach. I recall McLaren saying the same thing in 2014- I’m sure Button did an interview talking about a car that “works out of the box” with no big gremlins and then “bolting on downforce”.
Didn’t work out for them and I’m sure the did that because they also got lost with their tech direction in the prior cycle (remember 2013 when they tried a whole new development path in the final year of regs?)
Not saying this will be a repeat but I’d be surprised if Merc did not have a pretty advanced car relative to competition- but that’s why it’s an interesting time!
Lasssept
122
[-o<
HungarianRacer
HungarianRacer
37
Lasssept wrote:
03 Jan 2026, 20:52
The question is whether there will be an identifiable area of development that can be "mined" for consistent, continuous performance gains like mass flow between the rear tyre and the side of the diffuser was from pretty much 2009 to 2021 (what the ever-tightening "coke bottle" rear ends and slanted sidepods were aiming to improve [less bodywork volume = better, to put it without nuance]), if yes, then an "extreme" design is very much desired and should not be compromised upon in the pursuit of seizing the opportunity to get a head start on others (the ability to do this better is what the main advantage of being a works team will once again -initially - be in the new rules set, IF there is such an area of development that is pinponted by someone early)....
Hopefully, this time around they'll have the understanding and the right tools to validate that they are putting their eggs in the right basket(s)...
Lasssept
122
Re: 2026 Mercedes-AMG Petronas F1 Team
Lasssept wrote:
09 Jan 2026, 10:53
From what I've heard #Mercedes does NOT have plans in the coming days to hit the track for a filming session in Barcelona with the W17
interesting...
#ReleasetheADUO
WardenOfTheNorth
That would fit with what I know as well....and you'll have to read into that what you will....
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
Lasssept
122
MotorsportMagazine
- McLaren's big fear: why factory power could prove crucial in F1's 2026 reset
With more factory-backed teams than customers and a ruleset that rewards integration, 2026 could mark Formula 1's return to a manufacturers' championship
..But the unintended consequence is that chassis teams dependent on a third-party supplier will face an uphill task. Every interaction between power unit and aero will become more decisive, and nothing defines a works team more than the ability to design these elements as a single product rather than two separate systems bolted together.
Why the 2026 rules may amplify factory advantages
Two pillars define the 2026 chassis-power unit relationship: active aero and energy management. Both reward integration and close cooperation between design departments, and expose the limits of customer structures.
Active aero compounds this effect. Cars will alternate between two aerodynamic modes, forcing teams to design cars whose cooling and bodywork work just as well in both. Works teams can design their power unit cooling, battery placement and exhaust routing with those transitions in mind. Customer teams must instead adapt their aero philosophy to a power unit conceived around someone else’s priorities.
Energy deployment is also no longer an isolated performance tool. In 2026 it becomes structurally linked to aero behaviour, with electric power compensating for drag reduction and shaping how aggressively teams can run low-drag modes. That places battery cooling and MGU-K integration at the heart of aerodynamic performance – an area where factory teams hold a decisive coordination advantage.
There is also a strategic dimension: factory teams can plan power unit improvements with specific chassis upgrades in mind, while customers must adapt to whatever update cycle the manufacturer chooses. In a tightly regulated environment with limited testing, that developmental synchronicity will matter.
link
lio007
327
That's a big one: Dan Milner, Chief Engineer Research and Development has left the team.
