2026 Aerodynamic & Chassis Regulations
vorticism
vorticism
449
Re: 2026 Aerodynamic & Chassis Regulations
carisi2k wrote:
04 Jan 2026, 06:56
vorticism wrote:
04 Jan 2026, 01:49
TeamKoolGreen wrote:
03 Jan 2026, 07:23
Look at those inwash boards. The whole claim to fame of these regs is inwash and yet they couldn't even manage to get these boards to actually inwash. Air just goes right through them.
https://i.postimg.cc/5N82Lbnw/q11.jpg
They are still inwashing. It's only a general term. The legality box for the floor board forces an inward angle regardless of interpretation. Even if that box wasn't angled inward, say the box was straight or even slightly turned outward, the presence of vertical bodywork in that location will be impeding outward flow through that area (generally speaking, paired with a typical outwashing sidepod). "Impeding outwash" would be another way of saying inwash, ultimately.
That inboard will be useless when the teams power up the sidepod outwash. If they truly wanted to get rid of outwash they needed to square the sidepod from the inwash flap all the way to the rear wheels.
In fact, that's where I was going with the concept I presented earlier. Maximize sidepod outwash to power the floor board and foot.
People keep implying "the FIA's inwash concept" as though the FIA ever used these terms to describe the concept. Now they are condemning this same terminology. The FIA place a fin behind the front wheel. The fin impedes airflow through that area. That's "an inwash concept" only in part. Might even be more accurate to say that it's a "front tyre wake energizer" rather than think of it as a magic wing that pushes all air into a place where it can't go anyway: the center of the car, which is occupied by... the car.
mzso
mzso
76
03 Jan 2026, 07:23
Qvist design worked on this car for over a year and is the closest representation. Look at those inwash boards. The whole claim to fame of these regs is inwash and yet they couldn't even manage to get these boards to actually inwash. Air just goes right through them.
Why did they go away from the no endplate rear wing ? It is an Indycar wing. Did all the research into 2022 mean nothing ? Say what you want about the 2022 car but they could follow without burning off their tires. And that was the whole point.
Judging by the BSport video it will be worse than that. Mostly outwashing even from the shape. Also the nose can be lifted a fair bit by the looks of it. I don't think that was intentional.
03 Jan 2026, 07:44
But the underbody downforce had to go because the power units couldn't handle the drag. And that is also why we have active aero. And F1 is trying to cover it all up. They don't like admitting that all of this is because of the 50% electric gimmick. They are even saying now, that the underbody downforce kicked up too much water. As if any car going 300+ km/h isn't going to kick up water. Or even this driver comfort thing. Yes, the 2022 cars were low and stiff. And seemed to cross a line for the drivers in certain situations. But all F1 cars are low and stiff. All circuit race cars are low and stiff ffs.
I think the "low and stiff" issue is a very solvable problem with that style of car.
djos wrote:
03 Jan 2026, 09:52
Underbody downforce has the least drag penalty of any downforce generating device. They got rid of it because the teams were pushing it too far and the cars became less nimble and much less raceable.
Adjustable wings should have less drag (and DF) in the straights. Though I guess you could make those adjustable as well.
They shouldn't have gotten rid of it. They should have improved it.
carisi2k
vorticism wrote:
05 Jan 2026, 16:23
I have a feeling that these cars will be as bad as the 2021 cars for dirty air. The 22 cars were great for dirty air but then they lifted the floor edge for 23 (because a certain team couldn't stop bouncing) allowing the teams to outwash with the underfloor and also those cut off rear wings. The FIA never learns and there always seemed to be some bias in favour of a certain team or team with a particular engine being given leeway while the other teams always got the hammer thrown at them.
mzso
mzso
76
djos wrote:
04 Jan 2026, 07:52
Ben S is a politician, he has no idea what he’s talking about. Here’s another article that’s only 7 days old and sums up the reason for the changes quite well.
But the cars it created ultimately became exactly what the rules set out to avoid, extremely difficult to race thanks to how difficult it became to follow.
They produced enormous levels of downforce and were seriously fast, and were challenging to drive even if they did take a big physical toll on the drivers. But they struggled to follow closely and created processional races.
So what went wrong?
The short answer is that the teams did everything they could to ‘break’ the regulations in their relentless pursuit of performance and race wins.
https://www.the-race.com/formula-1/how- ... ffect-era/
You saying this is ironic, because you just believe in the more blatant PR justification.
From the inception it was clear that the botched motor formula required the active areo. Maybe botched isn't even the right term, more like sabotaged, because initially it was supposed to have front wheel recovery. Before politics took over the design of the new formula.
04 Jan 2026, 14:52
De Wet wrote:
04 Jan 2026, 14:32
Why are the Aerodynamic Testing Restrictions in place for 2026 if everybody is starting with a clean slate ?
F1 uses balance of performance to make sure everybody wins.
No, it uses a slight negative feedback to prevent runaway successes. Even so the results were pretty modest so far. At least one team caught up to the dominant force, by the third year of the cycle.
In fairness it should have been more. But Mercedes was repeating its own blunders, and blundering the only thing what Ferrari does.
De Wet wrote:
04 Jan 2026, 21:51
04 Jan 2026, 21:31
What does the ruleset change have to do with it? A different team must win.
Why ? The best team must win. If it's Mclaren again, so be it.
Don't bother with his invented narrative...
04 Jan 2026, 19:25
Clearly the huge venturi floors produce more drag than a flat floor with a diffuser. Even if it is less relative drag than wings. And that is why the flat floor is back.
Everything , including the narrower car and narrower tires, flat floor and active aero was introduced because the new PU's could not handle the drag after the simulations were done in late 2023.
Can you show me anywhere where it says that the chassis regulations were up for renewal in 2026 ?
I don't think this is true as such. If they removed the strakes I think the difference would be minimal. But you'd probably still need to implements some form of active aero for it, which might not be as simple as flapping a wing.
djos
130
mzso wrote:
06 Jan 2026, 12:09
djos wrote:
04 Jan 2026, 07:52
So what went wrong?
04 Jan 2026, 14:52
De Wet wrote:
04 Jan 2026, 14:32
De Wet wrote:
04 Jan 2026, 21:51
04 Jan 2026, 21:31
04 Jan 2026, 19:25
Yes they botched the engine formula, but getting rid of the Venturi tunnels has nothing to do with reducing drag.
"In downforce we trust"
SiLo
144
Not sure if this has been posted here yet?
Seems like outwash will still be a big thing, and team will easily find ways around the intention of the rules.
Felipe Baby!
mzso
mzso
76
djos wrote:
06 Jan 2026, 12:33
That's debatable. It may have been a factor, misguided or not.
It seems easier to shed drag merely by flipping wings. I'm quite sure down-force can be decreased of the undersiside by manipulating the leading a trailing edges, however I'm not sure it would result in significant energy savings.
As for comparing wings in straight line mode with the hypothetical floors in low downforce mode, I have no idea what would the values turn out to be.
My best guess is, going for active wings, might have been a qick and dirty way of fixing low ride heights and lowering drag at the same time. Meanwhile completely ignoring the reason venturi tunnels were introduced in the first place.
Probably to horrible results for racing quality. Depending how extra power mode turns out. Whether it is powerful enough to compensate, and whether it will result in simple drive-by overtakes.
mzso
mzso
76
SiLo wrote:
06 Jan 2026, 13:41
It was, at least in one of the 2026 topics. People didn't respond much to it. It's not a huge surprise that the FIA fails even in their basic goals, if teams figure out how to use for good effect.
I wonder more about the higher stubby nose, driver-forward design proposed in the other video. Whether it has any merits. It's rather unlike the models people made for 2026, including the Qvist one.
SiLo wrote:
06 Jan 2026, 13:41
This is how you generate outwash that destroys folllowing:
The "workaround" that is illustrated in that video is a cheap imitation at best and it will be far less effective. That is the point.
Beware of T-Rex
SiLo
144
06 Jan 2026, 17:39
Yes but it's still nullifying the point of the rules quite easily. I give it a year and teams will have figured out how to generate outwash again anyway and we will be back to square one.
The only way to combat this truly would probably be to have some standard CFD runs and say they can't have higher than a specific ratio of air being pushed X amount of distance from the car.
Felipe Baby!
mzso
mzso
76
SiLo wrote:
07 Jan 2026, 11:51
I think competent regulation writing would also work.
SiLo wrote:
07 Jan 2026, 11:51
I see your point but square one will not be the same square one as late 2021. The cars are smaller and have fewer downforce generating surfaces. As long as these cars remain slower than the pre-2022 cars, then they will not produce anywhere near the dirty air either.
2026 will be the best year but it logically follows that following will degrade in 2027 and beyond. It's the result of creating more downforce. Outwash is not the only cause of that.
Beware of T-Rex
TeamKoolGreen
TeamKoolGreen
07 Jan 2026, 18:12
SiLo wrote:
07 Jan 2026, 11:51
Do you seriously expect the new car in 2026 to follow anything close to the 2022 car ?
It has a conventional rear wing , a 2009 era front wing and a flat floor. It's just physics.
Until 2022 , there was no visible improvement in following at all. Even on the first day of any new regulation. In early 2022 , the driver's said it was like go karts again
TeamKoolGreen
TeamKoolGreen
mzso wrote:
07 Jan 2026, 17:37
SiLo wrote:
07 Jan 2026, 11:51
They had no time. There was no intention of changing the chassis or aero at all in 2026 until they discovered a year after ratifying them that the power unit wasn't even close to having enough energy to power the 2022 chassis and aero around a lap. This thread did not even start until October 2023.
Here is the first F1. com article after they passed the 2026 PU regs from August 2022
This is the only part where they mention any changes to the car itself.
With the MGU-K set to be enclosed within the chassis, next to the battery and control electronics, all high-voltage equipment will now be contained within the safety cell – making for a safer car.
And this is the only part where they mention how 2026 will be different for the drivers
With the removal of complexities such as the MGU-H, turbo lag might return and that could make the cars harder to control on corner exit.
It could also provide more of a challenge for the drivers and strategists too, as they will need to decide when the driver should sit back, and when they should attack using the power unit’s electrical potential.
Nothing about shorter or narrower cars , nothing about smaller tires , nothing about active aero, nothing about different wings , nothing about different floors, nothing about push to pass. Nothing about getting rid of DRS.
Push to pass was another afterthought that they added because they knew they had to get rid of DRS to make way for active aero. And they know that they'll need another passing aid because the venturi floor is gone and a passing aid will be needed more than ever.
https://www.formula1.com/en/latest/arti ... 8QO7jtFxQR
TeamKoolGreen
TeamKoolGreen
What we have is a glorified Formula E power unit, mated to a glorified Formula 2 chassis , with an Indycar floor, Indycar rear wing and push to pass system.
