2026 Audi Revolut F1 Team
bauc
35
Re: 2026 Audi Revolut F1 Team
More AI enhancements?
Peter Ian Staker
Peter Ian Staker
michl420 wrote:
10 Jan 2026, 14:19
10 Jan 2026, 05:13
Something that surprises me is how small the rear wing is for a circuit like Barcelona. This looks like a Spa or Monza spec wing. You would expect to see larger wings than before because there is no longer a penalty on the straights due to active aero.
https://i.postimg.cc/KjVCZVZB/image.png
That is more or less the new maximal allowed rear wing size. And that make me think they will run this max rear wings at ~70% of all circuits.
Interesting thought, though I don't know how much to read into a high downforce wing being brought to a high downforce track.
Does active aero negate the advantages of a trimmed down rear wing this much? Especially with how important we expect straight efficiency to be with these engines.
Emag
Emag
137
bauc wrote:
10 Jan 2026, 21:30
https://pbs.twimg.com/media/G-T5QLmXwAA ... name=large
I think it's pointless to make any sort of "analysis" based on images like these. The overall contour of the car is accurate, but any detail between the lines is pretty much entirely hallucinated.
Developer of F1InsightsHub
F1NAC
173
bauc wrote:
10 Jan 2026, 21:30
Bottom pic is AI for sure. Wtf is happening around front wheels? And front wheel deflectors are gone in ‘26
sucof
37
bauc wrote:
10 Jan 2026, 21:30
Grow up: AI does not ENHANCE the image!! Enhancing is making it better. AI only hallucinates made up things and adds it to the image. This is NOT enhancement, this is destruction!
Pleas no more AI images! Thank you!
mzso
mzso
76
Ah, it got un-paywalled.
Roman
Roman
German Media reported that they used an "A" version of the car and that it was mainly to check that everything works.
For Melbourne there is supposed to be a B Version of the car. So I wouldn't read too much into the pictures, be it with or without AI Slop.
I don't think I saw this posted? Has it been AI enhanced? I'm not sure.
lighting trick or curved rear control arm?
Beware of T-Rex
icantride
icantride
15 Jan 2026, 21:41
https://pbs.twimg.com/media/G-uIfa9bMAA ... name=large
https://i.postimg.cc/g0McnhJ4/image.png
Looks enhanced, it's hallucinated a '22-25 spec front wing end plate as well as the high raised floor inlet. There aren't any images of 2026 cars to train on so it's coming up with what it knows
icantride wrote:
16 Jan 2026, 08:30
15 Jan 2026, 21:41
Good spots. I agree. I also noticed the asymmetry of the rear wing endplates where it meets the wing. It looks like there is a hole on the left side. That isn't right.
Beware of T-Rex
edu2703
edu2703
37
Brazilian journalist for Motorsports.com Brazil
“After digging around here and there, a source told me that Audi's shakedown in Barcelona was extremely problematic. Apparently, they brought three power units, and some of those engines couldn't last more than a few laps.”
This, and Cadillac's problems, explain why the Barcelona tests will be private.
ME4ME
82
If true that implies two engine changes in a day. You don't do that for fun.
You'd do it only if you knew with some certainty that it is necessary. Metal particals in the oil, that kind of thing.
mzso
mzso
76
edu2703 wrote:
17 Jan 2026, 23:30
What was in the tweet? That sentence? (Only?)
FW17
184
ME4ME wrote:
18 Jan 2026, 00:04
These engine would have spent a xxxxx hours in the engine dyno. The engine likely is not coming apart, more to do with installation and cooling.
Audi probably had half the car on a dyno before coming to the circuit.
JRodrigues
JRodrigues
It would take a ridiculous amount of work (and hours) to remove and install 2 new engines.
